[Liblas-commits] hg: point to custom readme for Python so it renders properly in ...
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Feb 2 11:15:52 EST 2011
details:   http://hg.liblas.orghg/rev/da19fa233a37
changeset: 2846:da19fa233a37
user:      Howard Butler <hobu.inc at gmail.com>
date:      Wed Feb 02 10:15:24 2011 -0600
description:
point to custom readme for Python so it renders properly in PyPI
diffstat:
 python/README.txt |  77 +++++++++++++++++++++++++++++++++++++++++++++++++++++++
 python/setup.py   |   2 +-
 2 files changed, 78 insertions(+), 1 deletions(-)
diffs (94 lines):
diff -r 12230c12cca9 -r da19fa233a37 python/README.txt
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/python/README.txt	Wed Feb 02 10:15:24 2011 -0600
@@ -0,0 +1,77 @@
+libLAS - LAS 1.0/1.1/1.2 ASPRS LiDAR data translation toolset
+libLAS is a C/C++ library for reading and writing the very common `LAS`
+`LiDAR`_ format. The `ASPRS LAS format`_ is a sequential binary format used to
+store data from LiDAR sensors and by LiDAR processing software for data
+interchange and archival.
+libLAS' initial development was supported in 2007-2008 by the `IGSB`_ of the
+Iowa DNR for use in its state-wide `LIDAR`_ project.  Ongoing support for
+libLAS is provided by a number of organizations including the
+`U.S. Army Cold Regions Research and Engineering Laboratory`_.
+.. _`U.S. Army Cold Regions Research and Engineering Laboratory` : http://www.crrel.usace.army.mil/
+Pre-requisites
+The Python bindings require the libLAS base C and C++ libraries be installed.
+Obtain a source copy of the library from http://liblas.org/download.html and
+follow the compilation instructions at http://liblas.org/compilation.html to
+build and install the library.
+News
+02/02/2011
+libLAS 1.6.0 adds a number of new features:
+* Compression/decompression support via `LASzip`_
+* Octree indexing
+* Tiling support via `lasblock`_
+* Loading data to `Oracle Point Cloud`_ via `las2oci`_
+* Horizontal and vertical reprojection
+* XML summary output via `lasinfo`_
+Updates to the Python API include support for manipulating raw point data,
+rescaling support through manipulation of `point.header`, and a number of
+additions to bring things in line with the libLAS C++ API.
+Documentation
+A `tutorial`_ and `class documentation`_ are provided for working
+License
+libLAS is available under the terms of the `BSD License`_.
+See `License`_ for a copy.
+.. _`lasblock`: http://liblas.org/utilities/lasblock.html
+.. _`LASzip`: http://laszip.org
+.. _`las2oci`: http://liblas.org/utilities/las2oci.html
+.. _`lasinfo`: http://liblas.org/utilities/lasinfo.html
+.. _`Oracle Point Cloud`: http://download.oracle.com/docs/cd/B28359_01/appdev.111/b28400/sdo_pc_pkg_ref.htm"
+.. _`class documentation`: http://liblas.org/python.html
+.. _`tutorial`: http://liblas.org/tutorial/python.html
+.. _`LIDAR`: http://en.wikipedia.org/wiki/LIDAR
+.. _`IGSB`: http://www.igsb.uiowa.edu/
+.. _`Martin Isenburg`: http://www.cs.unc.edu/~isenburg/
+.. _`LAStools`: http://www.cs.unc.edu/~isenburg/lastools/
+.. _`Martin Isenburg and Jonathan Shewchuk`: http://www.cs.unc.edu/~isenburg/lastools/
+.. _`LAS Format`: http://www.lasformat.org/
+.. _`ASPRS Standards Committee`: http://www.asprs.org/society/committees/standards/lidar_exchange_format.html
+.. _`ASPRS LAS format`: http://www.asprs.org/society/committees/standards/lidar_exchange_format.html
+.. _`BSD license`: http://www.opensource.org/licenses/bsd-license.php
+.. _`OSGeo4W`: http://wiki.osgeo.org/wiki/OSGeo_Win32_Installer
+.. _`License`: http://liblas.org/copyright.html#license
\ No newline at end of file
diff -r 12230c12cca9 -r da19fa233a37 python/setup.py
--- a/python/setup.py	Tue Feb 01 13:40:39 2011 -0600
+++ b/python/setup.py	Wed Feb 02 10:15:24 2011 -0600
@@ -10,7 +10,7 @@
 from sys import version_info
 try:
-    readme = file('../doc/index.txt','rb').read()
+    readme = file('README.txt','rb').read()
 except:
     readme = ''
More information about the Liblas-commits mailing list
