[Liblas-commits] libpc: checkpoint (still need to set isActive)
liblas-commits at liblas.org
Mon Feb 7 21:39:11 EST 2011
details: http://hg.liblas.orglibpc/rev/7ac0fe222e37
changeset: 9:7ac0fe222e37
user: Michael P. Gerlek <mpg at flaxen.com>
date: Mon Feb 07 18:39:05 2011 -0800
description:
diffstat:
include/libpc/ColorFilter.hpp | 2 +
include/libpc/CropFilter.hpp | 10 +++-
include/libpc/FauxReader.hpp | 2 +
include/libpc/FauxWriter.hpp | 2 +
include/libpc/Field.hpp | 22 ++++++-
include/libpc/Filter.hpp | 3 +-
include/libpc/Header.hpp | 1 +
include/libpc/PointData.hpp | 16 +++---
include/libpc/PointLayout.hpp | 26 ++++++---
include/libpc/Reader.hpp | 3 +-
include/libpc/Stage.hpp | 6 +-
include/libpc/Writer.hpp | 2 +
src/ColorFilter.cpp | 55 +++++++++-----------
src/CropFilter.cpp | 28 +++++++++-
src/FauxReader.cpp | 30 +++++++----
src/FauxWriter.cpp | 16 ++++-
src/Field.cpp | 41 ++++++++++-----
src/Header.cpp | 6 ++
src/PointData.cpp | 90 +++++++++++++++++++--------------
src/PointLayout.cpp | 111 +++++++++++++++++++++++++----------------
src/main.cpp | 4 +-
21 files changed, 302 insertions(+), 174 deletions(-)
diffs (truncated from 1011 to 300 lines):
diff -r d1e630d22d83 -r 7ac0fe222e37 include/libpc/ColorFilter.hpp
--- a/include/libpc/ColorFilter.hpp Mon Feb 07 13:53:54 2011 -0800
+++ b/include/libpc/ColorFilter.hpp Mon Feb 07 18:39:05 2011 -0800
@@ -46,6 +46,8 @@
ColorFilter(Stage& prevStage);
void initialize();
+ void updateLayout();
void readNextPoints(PointData&);
private:
diff -r d1e630d22d83 -r 7ac0fe222e37 include/libpc/CropFilter.hpp
--- a/include/libpc/CropFilter.hpp Mon Feb 07 13:53:54 2011 -0800
+++ b/include/libpc/CropFilter.hpp Mon Feb 07 18:39:05 2011 -0800
@@ -38,16 +38,22 @@
#include "libpc/Filter.hpp"
-// removes any points outside of the given Z range
+// removes any points outside of the given range
class CropFilter : public Filter
public:
- CropFilter(Stage& prevStage, float minZ, float maxZ);
+ CropFilter(Stage& prevStage, float minX, float maxX, float minY, float maxY, float minZ, float maxZ);
void initialize();
private:
+ float m_minX;
+ float m_maxX;
+ float m_minY;
+ float m_maxY;
float m_minZ;
float m_maxZ;
diff -r d1e630d22d83 -r 7ac0fe222e37 include/libpc/FauxReader.hpp
--- a/include/libpc/FauxReader.hpp Mon Feb 07 13:53:54 2011 -0800
+++ b/include/libpc/FauxReader.hpp Mon Feb 07 18:39:05 2011 -0800
@@ -43,6 +43,8 @@
FauxReader(std::string file);
void initialize();
void readNextPoints(PointData& data);
private:
diff -r d1e630d22d83 -r 7ac0fe222e37 include/libpc/FauxWriter.hpp
--- a/include/libpc/FauxWriter.hpp Mon Feb 07 13:53:54 2011 -0800
+++ b/include/libpc/FauxWriter.hpp Mon Feb 07 18:39:05 2011 -0800
@@ -45,6 +45,8 @@
FauxWriter(std::string filename, Stage& prevStage);
void initialize();
private:
int m_numPointsWritten;
diff -r d1e630d22d83 -r 7ac0fe222e37 include/libpc/Field.hpp
--- a/include/libpc/Field.hpp Mon Feb 07 13:53:54 2011 -0800
+++ b/include/libpc/Field.hpp Mon Feb 07 18:39:05 2011 -0800
@@ -48,6 +48,9 @@
YPos,
ZPos,
Time,
+ Zred,
+ Zgreen,
+ Zblue
static std::string getName(DataItem);
@@ -70,14 +73,21 @@
public:
Field();
- Field(DataItem item, int offset, DataType type);
+ Field(DataItem item, DataType type);
Field(const Field&);
Field& operator=(const Field&);
- DataItem item() const { return m_item; }
- int offset() const { return m_offset; }
- DataType type() const { return m_type; }
+ DataItem getItem() const { return m_item; }
+ DataType getType() const { return m_type; }
+ int getOffset() const { return m_offset; }
+ void setOffset(int offset) { m_offset = offset; }
+ int getIndex() const { return m_index; }
+ void setIndex(int index) { m_index = index; }
+ int getNumBytes() const;
static const std::vector<Field>& standardFields();
@@ -85,9 +95,11 @@
private:
DataItem m_item;
- int m_offset;
DataType m_type;
+ int m_offset;// byte offset within a point buffer
+ int m_index; // 0..n-1, where n is number of fields in layout
static std::vector<Field>* s_standardFields;
diff -r d1e630d22d83 -r 7ac0fe222e37 include/libpc/Filter.hpp
--- a/include/libpc/Filter.hpp Mon Feb 07 13:53:54 2011 -0800
+++ b/include/libpc/Filter.hpp Mon Feb 07 18:39:05 2011 -0800
@@ -44,7 +44,8 @@
virtual void initialize() = 0;
- // from Stage
+ virtual void updateLayout() = 0;
virtual void readNextPoints(PointData&) = 0;
protected:
diff -r d1e630d22d83 -r 7ac0fe222e37 include/libpc/Header.hpp
--- a/include/libpc/Header.hpp Mon Feb 07 13:53:54 2011 -0800
+++ b/include/libpc/Header.hpp Mon Feb 07 18:39:05 2011 -0800
@@ -53,6 +53,7 @@
const PointLayout& getConstPointLayout() const;
PointLayout& getPointLayout();
+ void setLayout(const PointLayout&);
int getNumPoints() const;
void setNumPoints(int);
diff -r d1e630d22d83 -r 7ac0fe222e37 include/libpc/PointData.hpp
--- a/include/libpc/PointData.hpp Mon Feb 07 13:53:54 2011 -0800
+++ b/include/libpc/PointData.hpp Mon Feb 07 18:39:05 2011 -0800
@@ -61,13 +61,13 @@
void setValid(int index);
void setInvalid(int index);
- byte getField_U8(int index, int itemOffset) const;
- float getField_F32(int index, int itemOffset) const;
- double getField_F64(int index, int itemOffset) const;
+ byte getField_U8(int pointIndex, int fieldIndex) const;
+ float getField_F32(int pointIndex, int fieldIndex) const;
+ double getField_F64(int pointIndex, int fieldIndex) const;
- void setField_U8(int index, int itemOffset, byte value);
- void setField_F32(int index, int itemOffset, float value);
- void setField_F64(int index, int itemOffset, double value);
+ void setField_U8(int pointIndex, int fieldIndex, byte value);
+ void setField_F32(int pointIndex, int fieldIndex, float value);
+ void setField_F64(int pointIndex, int fieldIndex, double value);
// some well-known fields
float getX(int index) const;
@@ -77,8 +77,8 @@
void setY(int index, float value);
void setZ(int index, float value);
- void dump() const;
- void dump(int index) const;
+ void dump(std::string indent="") const;
+ void dump(int index, std::string indent="") const;
private:
template<class T> T getField(int index, int itemOffset) const;
diff -r d1e630d22d83 -r 7ac0fe222e37 include/libpc/PointLayout.hpp
--- a/include/libpc/PointLayout.hpp Mon Feb 07 13:53:54 2011 -0800
+++ b/include/libpc/PointLayout.hpp Mon Feb 07 18:39:05 2011 -0800
@@ -49,26 +49,36 @@
void addField(const Field& field);
void addFields(const std::vector<Field>& fields);
- const Field& getField(int) const;
+ const Field& getField(int index) const { return m_fields[index]; }
+ bool isActive(int index) const { return m_isActive[index]; }
+ void setActive(int index) { m_isActive[index] = true; }
+ void setInactive(int index) { m_isActive[index] = false; }
int getSizeInBytes() const;
int getNumFields() const;
void dump() const;
- bool findField(Field::DataItem item, Field& ret) const;
+ // returns -1 if not found
+ int findFieldIndex(Field::DataItem item) const;
+ bool hasField(Field::DataItem item) const;
int findFieldOffset(Field::DataItem item) const;
// some well-known field types are always available
- int getFieldOffset_X() const { return m_offsetX; }
- int getFieldOffset_Z() const { return m_offsetY; }
- int getFieldOffset_Y() const { return m_offsetZ; }
+ // is this worth it?
+ int getFieldIndex_X() const { return m_fieldIndex_X; }
+ int getFieldIndex_Y() const { return m_fieldIndex_Y; }
+ int getFieldIndex_Z() const { return m_fieldIndex_Z; }
private:
std::vector<Field> m_fields;
- int m_offsetX;
- int m_offsetY;
- int m_offsetZ;
+ std::vector<bool> m_isActive;
+ int m_numBytes;
+ int m_fieldIndex_X;
+ int m_fieldIndex_Y;
+ int m_fieldIndex_Z;
#endif
diff -r d1e630d22d83 -r 7ac0fe222e37 include/libpc/Reader.hpp
--- a/include/libpc/Reader.hpp Mon Feb 07 13:53:54 2011 -0800
+++ b/include/libpc/Reader.hpp Mon Feb 07 18:39:05 2011 -0800
@@ -46,7 +46,8 @@
// opens the file (or whatever) and sets m_layout
virtual void initialize();
- // from Stage
protected:
diff -r d1e630d22d83 -r 7ac0fe222e37 include/libpc/Stage.hpp
--- a/include/libpc/Stage.hpp Mon Feb 07 13:53:54 2011 -0800
+++ b/include/libpc/Stage.hpp Mon Feb 07 18:39:05 2011 -0800
@@ -46,8 +46,10 @@
Stage();
bool isInitialized() const;
- virtual void readNextPoints(PointData&) = 0;
+ virtual void readNextPoints(PointData&) = 0;
const Header& getConstHeader() const;
diff -r d1e630d22d83 -r 7ac0fe222e37 include/libpc/Writer.hpp
--- a/include/libpc/Writer.hpp Mon Feb 07 13:53:54 2011 -0800
+++ b/include/libpc/Writer.hpp Mon Feb 07 18:39:05 2011 -0800
@@ -45,6 +45,8 @@
Writer(Stage& prevStage);
void write();
protected:
diff -r d1e630d22d83 -r 7ac0fe222e37 src/ColorFilter.cpp
--- a/src/ColorFilter.cpp Mon Feb 07 13:53:54 2011 -0800
+++ b/src/ColorFilter.cpp Mon Feb 07 18:39:05 2011 -0800
@@ -48,44 +48,37 @@
-void ColorFilter::readNextPoints(PointData& currData)
+void ColorFilter::updateLayout()
- // This filter changes the layout: it adds three u8 fields
- // Therefore, we get the data from the prev stage using the prev stage's layout,
- // and then copy the contents into the layout for this stage (which was
- // passed in to us).
- const int chunk = currData.getNumPoints();
- int cnt = currData.getNumPoints();
- //const PointLayout& currLayout = getConstHeader().getConstPointLayout();
+ m_prevStage.updateLayout();
const PointLayout& prevLayout = m_prevStage.getConstHeader().getConstPointLayout();
- PointData prevData(prevLayout, chunk);
- m_prevStage.readNextPoints(prevData);
+ PointLayout myLayout(prevLayout);
+ // add the three u8 fields
+ myLayout.addField(Field(Field::Zred, Field::U8));
+ myLayout.addField(Field(Field::Zgreen, Field::U8));
+ getHeader().setLayout(myLayout);
+void ColorFilter::readNextPoints(PointData& data)
More information about the Liblas-commits
