[Liblas-commits] libpc: moved isActive into the Field,
but it is still isn't a cl...
liblas-commits at liblas.org
Tue Feb 8 19:31:45 EST 2011
details: http://hg.liblas.orglibpc/rev/3f38e4333773
changeset: 15:3f38e4333773
user: Michael P. Gerlek <mpg at flaxen.com>
date: Tue Feb 08 14:48:46 2011 -0800
description:
moved isActive into the Field, but it is still isn't a clean concept; checkpoint here, before removing it
Subject: libpc: removed isActive (I feel better now)
details: http://hg.liblas.orglibpc/rev/4101f814698f
changeset: 16:4101f814698f
date: Tue Feb 08 14:51:21 2011 -0800
description:
Subject: libpc: remove unused index
details: http://hg.liblas.orglibpc/rev/099246b5c27e
changeset: 17:099246b5c27e
date: Tue Feb 08 16:31:41 2011 -0800
description:
remove unused index
diffstat:
include/libpc/Field.hpp | 7 ++++++-
include/libpc/PointData.hpp | 24 +++++++++++++++++++-----
include/libpc/PointLayout.hpp | 25 ++++++++++++-------------
include/libpc/Reader.hpp | 3 +--
include/libpc/Stage.hpp | 4 ++++
include/libpc/Writer.hpp | 9 ++++++++-
src/ColorFilter.cpp | 10 +++-------
src/FauxReader.cpp | 14 ++++----------
src/Field.cpp | 8 ++++----
src/PointData.cpp | 43 +++++++++++++++----------------------------
src/PointLayout.cpp | 29 +----------------------------
11 files changed, 77 insertions(+), 99 deletions(-)
diffs (truncated from 448 to 300 lines):
diff -r a7608f689f74 -r 099246b5c27e include/libpc/Field.hpp
--- a/include/libpc/Field.hpp Tue Feb 08 13:08:59 2011 -0800
+++ b/include/libpc/Field.hpp Tue Feb 08 16:31:41 2011 -0800
@@ -79,12 +79,17 @@
Field& operator=(const Field&);
bool operator==(const Field& other) const;
+ // what the field represents
DataItem getItem() const { return m_item; }
+ // the datatype of the field
DataType getType() const { return m_type; }
+ // what byte the field starts at, within the raw bytes of the point
int getOffset() const { return m_offset; }
void setOffset(int offset) { m_offset = offset; }
+ // number of bytes needed for the datatype
int getNumBytes() const;
void dump() const;
@@ -92,7 +97,7 @@
private:
DataItem m_item;
DataType m_type;
- int m_offset;// byte offset within a point buffer
+ int m_offset; // byte offset within a point buffer
#endif
diff -r a7608f689f74 -r 099246b5c27e include/libpc/PointData.hpp
--- a/include/libpc/PointData.hpp Tue Feb 08 13:08:59 2011 -0800
+++ b/include/libpc/PointData.hpp Tue Feb 08 16:31:41 2011 -0800
@@ -51,24 +51,35 @@
class PointData
public:
+ // note that when we make a PointData object all the fields are initialized to inactive,
+ // regardless of what the passed-in layout says -- this is because the field object
+ // represents the state within the owning object, which in this case is a completely
+ // empty buffer (similarly, all the points in the buffer are marked "invalid")
PointData(const PointLayout&, int numPoints);
- byte* getData(int pointIndex) const;
+ // number of points in this buffer
int getNumPoints() const;
+ // layout (number and kinds of fields) for a point in this buffer
const PointLayout& getLayout() const;
+ // "valid" means the data for the point can be used; if invalid, the point should
+ // be ignored or skipped. (This is done for efficiency; we don't want to have to
+ // modify the buffer's size just to "delete" a point.)
bool isValid(int pointIndex) const;
void setValid(int pointIndex, bool value=true);
+ // accessors to a particular field of a particular point in this buffer
byte getField_U8(int pointIndex, int fieldIndex) const;
float getField_F32(int pointIndex, int fieldIndex) const;
double getField_F64(int pointIndex, int fieldIndex) const;
void setField_U8(int pointIndex, int fieldIndex, byte value);
void setField_F32(int pointIndex, int fieldIndex, float value);
void setField_F64(int pointIndex, int fieldIndex, double value);
- // some well-known fields
+ // handy functions to get at some some well-known fields
float getX(int pointIndex) const;
float getY(int pointIndex) const;
float getZ(int pointIndex) const;
@@ -85,14 +96,17 @@
void dump(int index, std::string indent="") const;
private:
- template<class T> T getField(int index, int itemOffset) const;
- template<class T> void setField(int index, int itemOffset, T value);
+ // access to the raw memory
+ byte* getData(int pointIndex) const;
+ template<class T> T getField(int fieldIndex, int itemOffset) const;
+ template<class T> void setField(int fieldIndex, int itemOffset, T value);
PointLayout m_layout;
byte* m_data;
int m_pointSize;
int m_numPoints;
- std::vector<bool> m_isValid;
+ std::vector<bool> m_isValid; // one bool for each point
PointData(const PointData&); // not implemented
PointData& operator=(const PointData&); // not implemented
diff -r a7608f689f74 -r 099246b5c27e include/libpc/PointLayout.hpp
--- a/include/libpc/PointLayout.hpp Tue Feb 08 13:08:59 2011 -0800
+++ b/include/libpc/PointLayout.hpp Tue Feb 08 16:31:41 2011 -0800
@@ -46,21 +46,21 @@
public:
PointLayout();
PointLayout(const PointLayout&);
- PointLayout& operator=(const PointLayout & other);
+ PointLayout& operator=(const PointLayout& other);
- bool operator==(const PointLayout & other) const;
- bool same(const PointLayout & other, bool ignoreActive=false) const;
+ bool operator==(const PointLayout& other) const;
- // returns the index of the field added
+ // adds a field to the end of the layout, and returns the index of the field added
int addField(const Field& field);
+ // returns a given field
const Field& getField(int fieldIndex) const { return m_fields[fieldIndex]; }
- bool isActive(int fieldIndex) const { return m_isActive[fieldIndex]; }
- void setActive(int fieldIndex, bool value=true) { m_isActive[fieldIndex] = value; }
- void copyActiveVector(const std::vector<bool>& other) { m_isActive = other; }
- const std::vector<bool>& getActiveVector() const { return m_isActive; }
+ Field& getField(int fieldIndex) { return m_fields[fieldIndex]; }
+ // total num bytes for all fields in the point
int getSizeInBytes() const;
+ // number of fields in the point
int getNumFields() const;
void dump(std::string indent="") const;
@@ -68,20 +68,19 @@
// returns -1 if not found
int findFieldIndex(Field::DataItem item) const;
bool hasField(Field::DataItem item) const;
- int findFieldOffset(Field::DataItem item) const;
// some well-known field types are always available
- // is this worth it?
+ // (is this worth it?)
int getFieldIndex_X() const { return m_fieldIndex_X; }
int getFieldIndex_Y() const { return m_fieldIndex_Y; }
int getFieldIndex_Z() const { return m_fieldIndex_Z; }
private:
- std::vector<Field> m_fields;
- std::vector<bool> m_isActive;
+ std::vector<Field> m_fields; // each of the fields
- int m_numBytes;
+ int m_numBytes; // num bytes required to store all fields
+ // local cache of handy values
int m_fieldIndex_X;
int m_fieldIndex_Y;
int m_fieldIndex_Z;
diff -r a7608f689f74 -r 099246b5c27e include/libpc/Reader.hpp
--- a/include/libpc/Reader.hpp Tue Feb 08 13:08:59 2011 -0800
+++ b/include/libpc/Reader.hpp Tue Feb 08 16:31:41 2011 -0800
@@ -38,13 +38,12 @@
#include "libpc/Stage.hpp"
#include "libpc/header.hpp"
class Reader : public Stage
public:
Reader();
- virtual void readNextPoints(PointData&) = 0;
protected:
int m_lastPointRead;
diff -r a7608f689f74 -r 099246b5c27e include/libpc/Stage.hpp
--- a/include/libpc/Stage.hpp Tue Feb 08 13:08:59 2011 -0800
+++ b/include/libpc/Stage.hpp Tue Feb 08 16:31:41 2011 -0800
@@ -45,6 +45,10 @@
public:
Stage();
+ // The layout of the PointData buffer we are given here might
+ // not match our own header's layout. That's okay, though: all
+ // that matters is that the buffer we are given has the fields
+ // we need to write into.
const Header& getHeader() const;
diff -r a7608f689f74 -r 099246b5c27e include/libpc/Writer.hpp
--- a/include/libpc/Writer.hpp Tue Feb 08 13:08:59 2011 -0800
+++ b/include/libpc/Writer.hpp Tue Feb 08 16:31:41 2011 -0800
@@ -38,7 +38,8 @@
#include "libpc/Filter.hpp"
-// a Writer is a Filter (and so it has a previous stage and a header), but generally they do not implement their readNextPoints method
+// a Writer is a Filter, because it has a previous stage and a header
+// however, Writers generally do not implement the readNextPoints method
class Writer : public Filter
public:
@@ -47,11 +48,17 @@
void write();
protected:
+ // this is called once before the loop with the writeBuffer calls
virtual void writeBegin() = 0;
+ // called repeatedly, until out of data
virtual void writeBuffer(const PointData&) = 0;
+ // called once, after the writeBuffer calls
virtual void writeEnd() = 0;
private:
+ // not generally used in Writer objects
virtual void readNextPoints(PointData&) { throw; }
Writer& operator=(const Writer&); // not implemented
diff -r a7608f689f74 -r 099246b5c27e src/ColorFilter.cpp
--- a/src/ColorFilter.cpp Tue Feb 08 13:08:59 2011 -0800
+++ b/src/ColorFilter.cpp Tue Feb 08 16:31:41 2011 -0800
@@ -43,13 +43,9 @@
PointLayout& layout = getHeader().getLayout();
// add the three u8 fields
- int index;
- index = layout.addField(Field(Field::Zred, Field::U8));
- layout.setActive(index);
- index = layout.addField(Field(Field::Zgreen, Field::U8));
- index = layout.addField(Field(Field::Zblue, Field::U8));
+ layout.addField(Field(Field::Zred, Field::U8));
+ layout.addField(Field(Field::Zgreen, Field::U8));
+ layout.addField(Field(Field::Zblue, Field::U8));
return;
diff -r a7608f689f74 -r 099246b5c27e src/FauxReader.cpp
--- a/src/FauxReader.cpp Tue Feb 08 13:08:59 2011 -0800
+++ b/src/FauxReader.cpp Tue Feb 08 16:31:41 2011 -0800
@@ -50,16 +50,10 @@
header.setNumPoints(numPoints);
header.setBounds(bounds);
- int index;
- index = layout.addField(Field(Field::XPos, Field::F32));
- index = layout.addField(Field(Field::YPos, Field::F32));
- index = layout.addField(Field(Field::ZPos, Field::F32));
- index = layout.addField(Field(Field::Time, Field::F64));
+ layout.addField(Field(Field::XPos, Field::F32));
+ layout.addField(Field(Field::YPos, Field::F32));
+ layout.addField(Field(Field::ZPos, Field::F32));
+ layout.addField(Field(Field::Time, Field::F64));
header.dump();
diff -r a7608f689f74 -r 099246b5c27e src/Field.cpp
--- a/src/Field.cpp Tue Feb 08 13:08:59 2011 -0800
+++ b/src/Field.cpp Tue Feb 08 16:31:41 2011 -0800
@@ -60,10 +60,10 @@
-Field::Field(const Field& field)
- : m_item(field.m_item),
- m_type(field.m_type),
- m_offset(field.m_offset)
+Field::Field(const Field& other)
+ : m_item(other.m_item),
+ m_type(other.m_type),
+ m_offset(other.m_offset)
return;
diff -r a7608f689f74 -r 099246b5c27e src/PointData.cpp
--- a/src/PointData.cpp Tue Feb 08 13:08:59 2011 -0800
+++ b/src/PointData.cpp Tue Feb 08 16:31:41 2011 -0800
@@ -51,6 +51,7 @@
m_pointSize = m_layout.getSizeInBytes();
m_data = new byte[m_pointSize * m_numPoints];
+ // the points will all be set to invalid here
m_isValid.resize(m_numPoints);
return;
@@ -92,8 +93,6 @@
template <class T>
void PointData::setField(int pointIndex, int fieldIndex, T value)
- assert(m_layout.isActive(fieldIndex));
int offset = (pointIndex * m_pointSize) + m_layout.getField(fieldIndex).getOffset();
assert(offset + (int)sizeof(T) <= m_pointSize * m_numPoints);
byte* p = m_data + offset;
@@ -105,8 +104,6 @@
template <class T>
T PointData::getField(int pointIndex, int fieldIndex) const
More information about the Liblas-commits
