[Liblas-commits] libpc: checkpoint - Schema work
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Feb 15 11:28:49 EST 2011
details:   http://hg.liblas.orglibpc/rev/cf28d93f0b27
changeset: 54:cf28d93f0b27
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Mon Feb 14 14:57:34 2011 -0800
description:
Subject: libpc: checkpoint - schema work
details:   http://hg.liblas.orglibpc/rev/9be53f618e67
changeset: 55:9be53f618e67
date:      Mon Feb 14 17:33:43 2011 -0800
description:
Subject: libpc: added Vector, to back up Range and Bounds
details:   http://hg.liblas.orglibpc/rev/4985de87a2fe
changeset: 56:4985de87a2fe
date:      Mon Feb 14 18:25:48 2011 -0800
description:
Subject: libpc: added SpatialReference, Metadata; split out LasSchema
details:   http://hg.liblas.orglibpc/rev/931718485dda
changeset: 57:931718485dda
date:      Mon Feb 14 21:14:06 2011 -0800
description:
diffstat:
 apps/pc2pc.cpp                     |   52 ++-
 include/libpc/Bounds.hpp           |  149 +++---
 include/libpc/CropFilter.hpp       |    4 +-
 include/libpc/Dimension.hpp        |  221 ++++------
 include/libpc/Field.hpp            |  121 -----
 include/libpc/Header.hpp           |   25 +-
 include/libpc/LasSchema.hpp        |   91 ++++
 include/libpc/Metadata.hpp         |   79 +++
 include/libpc/PointData.hpp        |   15 +-
 include/libpc/PointLayout.hpp      |   91 ----
 include/libpc/Range.hpp            |    6 +
 include/libpc/Schema.hpp           |  139 +----
 include/libpc/SpatialReference.hpp |   69 +++
 include/libpc/Vector.hpp           |  173 ++++++++
 include/libpc/Writer.hpp           |    2 +-
 src/CMakeLists.txt                 |   13 +-
 src/ColorFilter.cpp                |   18 +-
 src/CropFilter.cpp                 |   36 +-
 src/Dimension.cpp                  |  283 ++++++++++---
 src/FauxReader.cpp                 |   41 +-
 src/FauxWriter.cpp                 |    4 +-
 src/Field.cpp                      |  193 --------
 src/Header.cpp                     |   65 ++-
 src/LasSchema.cpp                  |  274 ++++++++++++
 src/Metadata.cpp                   |  117 +++++
 src/MosaicFilter.cpp               |    4 +-
 src/PointData.cpp                  |   92 +--
 src/PointLayout.cpp                |  162 -------
 src/Schema.cpp                     |  795 +++++-------------------------------
 src/SpatialReference.cpp           |   98 ++++
 src/Vector.cpp                     |   33 +
 31 files changed, 1699 insertions(+), 1766 deletions(-)
diffs (truncated from 4294 to 300 lines):
diff -r 9ffe2a363128 -r 931718485dda apps/pc2pc.cpp
--- a/apps/pc2pc.cpp	Mon Feb 14 08:42:55 2011 -0800
+++ b/apps/pc2pc.cpp	Mon Feb 14 21:14:06 2011 -0800
@@ -17,9 +17,53 @@
 #include "libpc/Color.hpp"
 #include "libpc/Dimension.hpp"
 #include "libpc/Schema.hpp"
+#include "libpc/LasSchema.hpp"
+#include "libpc/CropFilter.hpp"
+#include "libpc/ColorFilter.hpp"
+#include "libpc/MosaicFilter.hpp"
+#include "libpc/FauxReader.hpp"
+#include "libpc/FauxWriter.hpp"
 using namespace libpc;
+static void test1()
+  // we are faking the reader, so we need to describe it here
+  // the faux reader only supports fields (X,Y,Z,T)
+  const Bounds<double> bounds(0, 0, -100, 200, 200, 100);
+  const int numPoints = 30;
+  FauxReader reader(bounds, numPoints);
+  CropFilter cropper(reader, Bounds<double>(0, 0, 0, 100, 100, 100));
+  ColorFilter colorizer(cropper);
+  FauxWriter writer(colorizer);
+  writer.write();
+  return;
+static void test2()
+  const int numPoints = 10;
+  const Bounds<double> bounds1(0, 0, 0, 100, 100, 100);
+  FauxReader reader1(bounds1, numPoints);
+  const Bounds<double> bounds2(100, 100, 100, 200, 200, 100);
+  FauxReader reader2(bounds2, numPoints);
+  MosaicFilter mosaicker(reader1, reader2);
+  FauxWriter writer(mosaicker);
+  writer.write();
+  return;
 int main(int, char* [])
@@ -40,17 +84,21 @@
-        Dimension dim("foo", 8);
+        Dimension dim("foo", Dimension::uint8_t);
         std::cout << dim << std::endl;
-        Schema schema(ePointFormat0);
+        LasSchema schema(LasSchema::ePointFormat0);
         std::cout << schema;
     Color c;
+    test1();
+    test2();
     return 0;
 #if 0
diff -r 9ffe2a363128 -r 931718485dda include/libpc/Bounds.hpp
--- a/include/libpc/Bounds.hpp	Mon Feb 14 08:42:55 2011 -0800
+++ b/include/libpc/Bounds.hpp	Mon Feb 14 21:14:06 2011 -0800
@@ -42,6 +42,7 @@
 #ifndef INCLUDED_BOUNDS_HPP
 #define INCLUDED_BOUNDS_HPP
+#include <cassert>
 #include <vector>
 #include <iostream>
 #include <sstream>
@@ -49,6 +50,7 @@
 #include <stdexcept>
 #include "libpc/export.hpp"
+#include "libpc/Vector.hpp"
 #include "libpc/Range.hpp"
 #include "libpc/Utils.hpp"
@@ -126,22 +128,22 @@
-    ////Bounds( const Point& min, const Point& max)
-    ////    m_ranges.resize(3);
-    ////    m_ranges[0].minimum = min.GetX();
-    ////    m_ranges[1].minimum = min.GetY();
-    ////    m_ranges[2].minimum = min.GetZ();
-    ////    m_ranges[0].maximum = max.GetX();
-    ////    m_ranges[1].maximum = max.GetY();
-    ////    m_ranges[2].maximum = max.GetZ();
-    ////#ifdef DEBUG
-    ////    verify();
-    ////#endif
+    Bounds(const Vector<T>& minimum, const Vector<T>& maximum)
+        assert(minimum.size() == maximum.size());
+        m_ranges.resize(minimum.size());
+        for (std::size_t i=0; i<minimum.size(); i++)
+            m_ranges[i].setMinimum(minimum.vN(i));
+            m_ranges[i].setMaximum(maximum.vN(i));
+    #ifdef DEBUG
+        verify();
+    #endif
     T minimum(std::size_t const& index) const
@@ -187,36 +189,29 @@
         m_ranges[index].setMaximum(v);
-    ////liblas::Point (min)() {
-    ////    liblas::Point p;
-    ////    try
-    ////        p.SetCoordinates(m_ranges[0].minimum, m_ranges[1].minimum, m_ranges[2].minimum);
-    ////    catch (std::runtime_error const& e)
-    ////        ::boost::ignore_unused_variable_warning(e);
-    ////        p.SetCoordinates(m_ranges[0].minimum, m_ranges[1].minimum, 0);
-    ////    return p;
-    ////liblas::Point (max)() {
-    ////    try
-    ////        p.SetCoordinates(m_ranges[0].maximum, m_ranges[1].maximum, m_ranges[2].maximum);
-    ////        p.SetCoordinates(m_ranges[0].maximum, m_ranges[1].maximum, 0);
-    ////    return p;
+    Vector<T> getMinimum()
+        std::vector<T> vec;
+        for (std::size_t i=0; i<m_ranges.size(); i++)
+            vec.push_back(m_ranges[i].minimum());
+        return Vector<T>(vec);
+    Vector<T> getMaximum()
+            vec.push_back(m_ranges[i].maximum());
     inline bool operator==(Bounds<T> const& rhs) const
@@ -290,8 +285,23 @@
         return intersects(other);
+    /// Does this Bounds contain a point?
+    bool contains(Vector<T> point) const
+        if (point.size() != size())
+            return false;
+        for (size_type i = 0; i < size(); i++)
+            // As soon as it is not contains, we're false
+            if (! m_ranges[i].contains(point.vN(i)) )
+                return false;
+        return true;
     /// Does this Bounds contain other?
-    bool contains(Bounds const& other) const
+    bool contains(Bounds<T> const& other) const
@@ -302,37 +312,6 @@
         return true;
-    /////// Does this Bounds this point other?
-    ////bool contains(Point const& point) const
-    ////    // std::cout << m_ranges[0].length() << std::endl;
-    ////    // std::cout << "x contain: " << m_ranges[0].contains(point.GetX())
-    ////    //           << " r.x.min: " << m_ranges[0].min
-    ////    //           << " r.x.max: " << m_ranges[0].max
-    ////    //           << " p.x: " << point.GetX() << std::endl;
-    ////    // std::cout << "y contain: " << m_ranges[1].contains(point.GetY())
-    ////    //           << " r.y.min: " << m_ranges[1].min
-    ////    //           << " r.y.max: " << m_ranges[1].max
-    ////    //           << " p.y: " << point.GetY() << std::endl;
-    ////    // std::cout << "z contain: " << m_ranges[2].contains(point.GetZ())
-    ////    //           << " r.z.min: " << m_ranges[2].min
-    ////    //           << " r.z.max: " << m_ranges[2].max
-    ////    //           << " p.z: " << point.GetZ() << std::endl;
-    ////    if (!m_ranges[0].contains(point.GetX()))
-    ////        return false;
-    ////    if (!m_ranges[1].contains(point.GetY()))
-    ////    // If our z bounds has no length, we'll say it's contained anyway.
-    ////    if (!m_ranges[2].contains(point.GetZ()))
-    ////        if (detail::compare_distance(m_ranges[2].length(), 0.0))
-    ////            return true;
-    ////    return true;
     /// Shift each dimension by a vector of detlas
     void shift(std::vector<T> deltas)
@@ -392,12 +371,14 @@
     /// Expand the liblas::Bounds to include this point
-    ////void grow(Point const& p)
-    ////    m_ranges[0].grow(p.GetX());
-    ////    m_ranges[1].grow(p.GetY());
-    ////    m_ranges[2].grow(p.GetZ());
+    void grow(Vector<T> const& point)
+        assert(point.size() == size());
+        for (size_type i = 0; i < size(); ++i)
+            m_ranges[i].grow(point.vN(i));
     T volume() const
diff -r 9ffe2a363128 -r 931718485dda include/libpc/CropFilter.hpp
--- a/include/libpc/CropFilter.hpp	Mon Feb 14 08:42:55 2011 -0800
+++ b/include/libpc/CropFilter.hpp	Mon Feb 14 21:14:06 2011 -0800
@@ -47,9 +47,9 @@
 class LIBPC_DLL CropFilter : public Filter
 public:
-    CropFilter(Stage& prevStage, const Bounds<double>& bounds);
+    CropFilter(Stage& prevStage, Bounds<double> const& bounds);
-    void readNextPoints(PointData&);
+    void readPoints(PointData&);
 private:
     Bounds<double> m_bounds;
diff -r 9ffe2a363128 -r 931718485dda include/libpc/Dimension.hpp
--- a/include/libpc/Dimension.hpp	Mon Feb 14 08:42:55 2011 -0800
More information about the Liblas-commits mailing list
