[Liblas-commits] libpc: first las output achieved
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Feb 17 12:22:18 EST 2011
details:   http://hg.liblas.orglibpc/rev/ce87b62c31a1
changeset: 66:ce87b62c31a1
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Thu Feb 17 09:22:01 2011 -0800
description:
diffstat:
 apps/pc2pc.cpp               |   6 ------
 include/libpc/FauxWriter.hpp |   2 +-
 include/libpc/LasWriter.hpp  |   2 +-
 include/libpc/Writer.hpp     |   2 +-
 src/FauxWriter.cpp           |   2 +-
 src/LasWriter.cpp            |  15 ++++++++-------
 src/Writer.cpp               |   8 ++++----
 7 files changed, 16 insertions(+), 21 deletions(-)
diffs (130 lines):
diff -r 3f400151fa35 -r ce87b62c31a1 apps/pc2pc.cpp
--- a/apps/pc2pc.cpp	Wed Feb 16 14:22:44 2011 -0800
+++ b/apps/pc2pc.cpp	Thu Feb 17 09:22:01 2011 -0800
@@ -78,12 +78,6 @@
   std::cout << (const LasHeader&)header;
-  //boost::uint32_t numPoints = (boost::uint32_t)header.getNumPoints();
-  //PointData pointData(header.getSchema(), numPoints);
-  //reader.readPoints(pointData);
-//  std::cout << pointData;
   std::ostream* ofs = Utils::Create("temp.las");
   LasWriter lasWriter(reader, *ofs);
diff -r 3f400151fa35 -r ce87b62c31a1 include/libpc/FauxWriter.hpp
--- a/include/libpc/FauxWriter.hpp	Wed Feb 16 14:22:44 2011 -0800
+++ b/include/libpc/FauxWriter.hpp	Thu Feb 17 09:22:01 2011 -0800
@@ -50,7 +50,7 @@
 private:
     int m_numPointsWritten;
-    void writeBegin();
+    void writeBegin(std::size_t totalNumPoints);
     void writeBuffer(const PointData&);
     void writeEnd();
diff -r 3f400151fa35 -r ce87b62c31a1 include/libpc/LasWriter.hpp
--- a/include/libpc/LasWriter.hpp	Wed Feb 16 14:22:44 2011 -0800
+++ b/include/libpc/LasWriter.hpp	Thu Feb 17 09:22:01 2011 -0800
@@ -49,7 +49,7 @@
 protected:
     // this is called once before the loop with the writeBuffer calls
-    virtual void writeBegin();
+    virtual void writeBegin(std::size_t totalNumPoints);
     // called repeatedly, until out of data
     virtual void writeBuffer(const PointData&);
diff -r 3f400151fa35 -r ce87b62c31a1 include/libpc/Writer.hpp
--- a/include/libpc/Writer.hpp	Wed Feb 16 14:22:44 2011 -0800
+++ b/include/libpc/Writer.hpp	Thu Feb 17 09:22:01 2011 -0800
@@ -51,7 +51,7 @@
 protected:
-    virtual void writeBegin() = 0;
+    virtual void writeBegin(std::size_t totalNumPoints) = 0;
     virtual void writeBuffer(const PointData&) = 0;
diff -r 3f400151fa35 -r ce87b62c31a1 src/FauxWriter.cpp
--- a/src/FauxWriter.cpp	Wed Feb 16 14:22:44 2011 -0800
+++ b/src/FauxWriter.cpp	Thu Feb 17 09:22:01 2011 -0800
@@ -50,7 +50,7 @@
-void FauxWriter::writeBegin()
+void FauxWriter::writeBegin(std::size_t totalNumPoints)
     cout << "FauxWriter::writeBegin()" << endl;
     cout << endl;
diff -r 3f400151fa35 -r ce87b62c31a1 src/LasWriter.cpp
--- a/src/LasWriter.cpp	Wed Feb 16 14:22:44 2011 -0800
+++ b/src/LasWriter.cpp	Thu Feb 17 09:22:01 2011 -0800
@@ -48,21 +48,22 @@
     LasHeader* lasHeader = new LasHeader;
     setHeader(lasHeader);
-    // need to set properties of the header here, based on this->getHeader() and on the user's preferences
-    const Header& baseHeader = getHeader();
-    lasHeader->setBounds( baseHeader.getBounds() );
-    lasHeader->SetOffset(0,0,0);
-    lasHeader->SetScale(1,1,1);
     return;
-void LasWriter::writeBegin()
+void LasWriter::writeBegin(std::size_t totalNumPoints)
     LasHeader& lasHeader = (LasHeader&)baseHeader;
+    // need to set properties of the header here, based on this->getHeader() and on the user's preferences
+    lasHeader.setBounds( baseHeader.getBounds() );
+    lasHeader.SetOffset(0,0,0);
+    lasHeader.SetScale(1,1,1);
+    lasHeader.SetPointRecordsCount(totalNumPoints);
     LasHeaderWriter lasHeaderWriter(lasHeader, m_ostream);
     lasHeaderWriter.write();
diff -r 3f400151fa35 -r ce87b62c31a1 src/Writer.cpp
--- a/src/Writer.cpp	Wed Feb 16 14:22:44 2011 -0800
+++ b/src/Writer.cpp	Thu Feb 17 09:22:01 2011 -0800
@@ -49,9 +49,9 @@
 void Writer::write()
-    writeBegin();
+    boost::uint64_t numPoints = m_prevStage.getHeader().getNumPoints();
-    boost::uint64_t numPoints = m_prevStage.getHeader().getNumPoints();
+    writeBegin(numPoints);
     const boost::uint32_t chunkSize = 100;
@@ -60,7 +60,7 @@
     if (numChunks > 0)
-        PointData buffer(getHeader().getSchema(), chunkSize);
+        PointData buffer(m_prevStage.getHeader().getSchema(), chunkSize);
         for (boost::uint64_t i=0; i<numChunks; i++)
             m_prevStage.readPoints(buffer);
@@ -71,7 +71,7 @@
     if (remainder > 0)
         if (remainder != (boost::uint32_t)remainder) throw;
-        PointData buffer(getHeader().getSchema(), (boost::uint32_t)remainder);
+        PointData buffer(m_prevStage.getHeader().getSchema(), (boost::uint32_t)remainder);
         this->writeBuffer(buffer);
More information about the Liblas-commits mailing list
