[Liblas-commits] libpc: cmake work
liblas-commits at liblas.org
Fri Feb 18 15:07:30 EST 2011
details: http://hg.liblas.orglibpc/rev/82ffaac465a1
changeset: 70:82ffaac465a1
user: Michael P. Gerlek <mpg at flaxen.com>
date: Fri Feb 18 11:54:21 2011 -0800
description:
cmake work
diffstat:
CMakeLists.txt | 257 ++++++++++++++++++++--------------------
apps/CMakeLists.txt | 40 ++---
apps/pc2pc.cpp | 20 +-
include/libpc/Dimension.hpp | 1 -
include/libpc/libpc_config.hpp | 60 +++++++++
include/libpc/version.hpp | 87 -------------
libpc_defines.h.in | 36 +++++
mpg-config.bat | 32 ++--
src/CMakeLists.txt | 12 +-
src/FauxWriter.cpp | 2 +-
src/libpc_config.cpp | 155 ++++++++++++++++++++++++
src/version.cpp | 132 ---------------------
13 files changed, 488 insertions(+), 406 deletions(-)
diffs (truncated from 1228 to 300 lines):
diff -r 099c9b50efc1 -r 82ffaac465a1 CMakeLists.txt
--- a/CMakeLists.txt Thu Feb 17 12:35:44 2011 -0800
+++ b/CMakeLists.txt Fri Feb 18 11:54:21 2011 -0800
@@ -1,38 +1,58 @@
-# Main CMake configuration file for libPC
-# Author: Mateusz Loskot <mateusz at loskot.net>
+# top-level CMake configuration file for libPC
-# libPC general settings
+# (based originally on the libLAS files copyright Mateusz Loskot)
+cmake_minimum_required(VERSION 2.6.0)
project(libPC)
+# internal cmake settings
+set(CMAKE_COLOR_MAKEFILE ON)
+# Allow advanced users to generate Makefiles printing detailed commands
+mark_as_advanced(CMAKE_VERBOSE_MAKEFILE)
+# Path to additional CMake modules
+set(CMAKE_MODULE_PATH ${PROJECT_SOURCE_DIR}/cmake/modules ${CMAKE_MODULE_PATH})
+# libPC general settings
+# the next three lines are the ONLY place in the entire libpc system where
+# the version info is hard-coded
SET(LIBPC_VERSION_MAJOR "0")
SET(LIBPC_VERSION_MINOR "1")
SET(LIBPC_VERSION_PATCH "0")
-set(VERSION "${LIBPC_VERSION_MAJOR}.${LIBPC_VERSION_MINOR}.${LIBPC_VERSION_PATCH}")
-SET(LIBPC_LIB_SOVERSION "0.1.0")
-SET(LIBPC_C_LIB_SOVERSION "0.1.0")
-SET(OSGEO4W_UPSTREAM_RELEASE "1")
+set(LIBPC_VERSION_STRING "${LIBPC_VERSION_MAJOR}.${LIBPC_VERSION_MINOR}.${LIBPC_VERSION_PATCH}")
+SET(LIBPC_LIB_SOVERSION ${LIBPC_VERSION_MAJOR})
+SET(LIBPC_C_LIB_SOVERSION ${LIBPC_VERSION_MAJOR})
+# Name of C++ library
if(WIN32)
- # Name of C++ library
set(LIBPC_LIB_NAME libpc)
else()
set(LIBPC_LIB_NAME pc)
endif()
-# Name of test suite runner
-set(LIBPC_UNIT_TEST libpc_test)
set(CMAKE_INCLUDE_DIRECTORIES_PROJECT_BEFORE ON)
+# misc user options
# Choose package components
-set(WITH_UTILITIES TRUE CACHE BOOL "Choose if libPC utilities should be built")
+set(WITH_APPS TRUE CACHE BOOL "Choose if libPC utilities should be built")
set(WITH_TESTS TRUE CACHE BOOL "Choose if libPC unit tests should be built")
# Choose to use pkg-config or not
@@ -40,39 +60,42 @@
"Choose whether a pkgconfig file (libPC.pc) should be installed")
set(WITH_ENDIANAWARE FALSE CACHE BOOL "Choose whether or not libPC should do runtime endianness switching. Note that this can slow things down considerably if enabled by default")
+if (WITH_ENDIANAWARE)
+ set(LIBPC_ENDIAN_AWARE 1)
+endif()
+# test harness settings
+# Name of test suite runner
+set(LIBPC_UNIT_TEST libpc_test)
# Enable CTest and submissions to libPC dashboard at CDash
# http://my.cdash.org/index.php?project=libPC
set(ENABLE_CTEST FALSE CACHE BOOL
"Enable CTest to support submissions of results to CDash at http://cdash.org")
-# CMake settings
-cmake_minimum_required(VERSION 2.6.0)
-set(CMAKE_COLOR_MAKEFILE ON)
-# Allow advanced users to generate Makefiles printing detailed commands
-mark_as_advanced(CMAKE_VERBOSE_MAKEFILE)
+# General build settings
-# Path to additional CMake modules
-set(CMAKE_MODULE_PATH ${libPC_SOURCE_DIR}/cmake/modules ${CMAKE_MODULE_PATH})
-# General build settings
-# Default to debug mode until final 1.6.0 release
+# note we default to debug mode
if(NOT MSVC_IDE)
if(NOT CMAKE_BUILD_TYPE)
set(CMAKE_BUILD_TYPE Debug CACHE STRING
"Choose the type of build, options are: None Debug Release RelWithDebInfo MinSizeRel" FORCE)
endif()
- message(STATUS "Setting libPC build type - ${CMAKE_BUILD_TYPE}")
+ message(STATUS "Setting libPC build type - ${CMAKE_BUILD_TYPE}")
endif()
+set(LIBPC_BUILD_TYPE ${CMAKE_BUILD_TYPE})
# TODO: Still testing the output paths --mloskot
-set(LIBPC_BUILD_OUTPUT_DIRECTORY ${PROJECT_BINARY_DIR}/bin/${CMAKE_BUILD_TYPE})
+set(LIBPC_BUILD_OUTPUT_DIRECTORY ${PROJECT_BINARY_DIR}/bin)
# Output directory in which to build RUNTIME target files.
set(CMAKE_RUNTIME_OUTPUT_DIRECTORY ${LIBPC_BUILD_OUTPUT_DIRECTORY})
@@ -84,8 +107,9 @@
set(CMAKE_ARCHIVE_OUTPUT_DIRECTORY ${LIBPC_BUILD_OUTPUT_DIRECTORY})
# Platform and compiler specific settings
if(WIN32)
if (MSVC)
@@ -102,20 +126,13 @@
else()
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} /W4")
endif()
- # Generate dot-user file with user-specific settings for
- # Visual Studio project
- set(MSVC_ENVIRONMENT_PATH "" CACHE STRING
- "Custom PATH for Environment property in Visual Studio for project")
- mark_as_advanced(MSVC_ENVIRONMENT_PATH)
- set(VCPROJ_USER_ENVIRONMENT_PATH_DEBUG "${ENVIRONMENT_PATH}")
- mark_as_advanced(VCPROJ_USER_ENVIRONMENT_PATH_DEBUG)
endif()
set(CMAKE_INCLUDE_PATH c:/osgeo4w/include;$ENV{CMAKE_INCLUDE_PATH})
set(CMAKE_LIBRARY_PATH c:/osgeo4w/lib;$ENV{CMAKE_LIBRARY_PATH})
else()
+ # not WIN32
# Recommended C++ compilation flags
# -Weffc++
@@ -143,11 +160,11 @@
set(SO_EXT so)
endif(APPLE)
-# Search for dependencies
-# Boost C++ Libraries support - required
-message(STATUS "Searching for Boost 1.38+ - done")
+# settings for Boost dependencies
# Default to using static, multithreaded libraries for
# linking under MSVC. This is because we show users how to
@@ -160,8 +177,8 @@
endif(MSVC)
endif(WIN32)
-# NOTE: Add iostreams to COMPONENTS list to enable bigfile_boost_iostreams_test
-find_package(Boost 1.38 COMPONENTS program_options thread REQUIRED)
+# BUG: are there other Boost components we're using?
+find_package(Boost 1.45 COMPONENTS program_options thread iostreams unit_test_framework REQUIRED)
if(Boost_FOUND AND Boost_PROGRAM_OPTIONS_FOUND)
include_directories(${Boost_INCLUDE_DIRS})
@@ -173,47 +190,20 @@
link_directories(${Boost_LIBRARY_DIRS})
-# libxml2 support - optional, default=ON
-set(WITH_LIBXML2 FALSE CACHE BOOL "Choose if libxml2 support should be built ")
-if(WITH_LIBXML2)
- find_package(LibXml2)
- mark_as_advanced(CLEAR LIBXML2_INCLUDE_DIR)
- mark_as_advanced(CLEAR LIBXML2_LIBRARIES)
- if(LIBXML2_FOUND)
- include_directories(${LIBXML2_INCLUDE_DIR})
- add_definitions(-DHAVE_LIBXML2=1)
- endif()
-endif()
+# settings for GDAL & related dependencies
# GDAL/OGR support - optional, default=OFF
set(WITH_GDAL FALSE CACHE BOOL "Choose if GDAL support should be built")
if(WITH_GDAL)
find_package(GDAL 1.6.0)
- # if(GDAL_FOUND)
- # # Confirm required API is available
- # include(CheckFunctionExists)
- # set(CMAKE_REQUIRED_LIBRARIES ${GDAL_LIBRARY})
- # check_function_exists(OSRSetEquirectangular2 HAVE_OSRSETEQUIRECTANGULAR2)
- # if(NOT HAVE_OSRSETEQUIRECTANGULAR2)
- # # Reset to NOT found for GDAL/OGR
- # set(GDAL_FOUND)
- # message(FATAL_ERROR
- # "Unable to find OSRSetEquirectangular2 within GDAL library at ${GDAL_INCLUDE_DIR} ${GDAL_LIBRARY}")
- # else()
- include_directories(${GDAL_INCLUDE_DIR})
- add_definitions(-DHAVE_GDAL=1)
- # endif()
- # endif()
+ set(LIBPC_HAVE_GDAL 1)
+ include_directories(${GDAL_INCLUDE_DIR})
mark_as_advanced(CLEAR GDAL_INCLUDE_DIR)
mark_as_advanced(CLEAR GDAL_LIBRARY)
endif()
# GeoTIFF support - optional, default=OFF
@@ -221,26 +211,15 @@
if(WITH_GEOTIFF)
find_package(GeoTIFF 1.2.5)
if(GEOTIFF_FOUND)
- # Confirm required API is available
set(CMAKE_REQUIRED_LIBRARIES ${GEOTIFF_LIBRARY})
- # check_function_exists(ST_Create HAVE_ST_CREATE)
- # if(NOT HAVE_ST_CREATE)
- # set(GEOTIFF_FOUND) # Reset to NOT found for GeoTIFF
- # message(FATAL_ERROR "GeoTIFF support requires libgeotiff 1.2.5 or newer.")
- # else()
include_directories(${GEOTIFF_INCLUDE_DIR})
- add_definitions(-DHAVE_LIBGEOTIFF=1)
- # endif()
+ set(LIBPC_HAVE_LIBGEOTIFF 1)
endif()
# Determine libTIFF availability, required
if (GEOTIFF_FOUND)
mark_as_advanced(CLEAR TIFF_INCLUDE_DIR)
mark_as_advanced(CLEAR TIFF_LIBRARY)
if (WIN32)
@@ -262,6 +241,23 @@
+# settings for other 3rd party dependencies
+# libxml2 support - optional, default=ON
+set(WITH_LIBXML2 FALSE CACHE BOOL "Choose if libxml2 support should be built ")
+if(WITH_LIBXML2)
+ find_package(LibXml2)
+ mark_as_advanced(CLEAR LIBXML2_INCLUDE_DIR)
+ mark_as_advanced(CLEAR LIBXML2_LIBRARIES)
+ if(LIBXML2_FOUND)
+ include_directories(${LIBXML2_INCLUDE_DIR})
+ set(LIBPC_HAVE_LIBXML2 1)
+ endif()
More information about the Liblas-commits
