[Liblas-commits] libpc: add FP compare support
liblas-commits at liblas.org
Wed Feb 23 20:59:24 EST 2011
details: http://hg.liblas.orglibpc/rev/13177ebbdcd8
changeset: 82:13177ebbdcd8
user: Michael P. Gerlek <mpg at flaxen.com>
date: Wed Feb 23 17:59:11 2011 -0800
description:
diffstat:
include/libpc/Utils.hpp | 10 +++++++++-
test/unit/UtilsTest.cpp | 30 +++++++++++++++++++++++-------
2 files changed, 32 insertions(+), 8 deletions(-)
diffs (71 lines):
diff -r 5b9465f9d5ad -r 13177ebbdcd8 include/libpc/Utils.hpp
--- a/include/libpc/Utils.hpp Wed Feb 23 17:22:36 2011 -0800
+++ b/include/libpc/Utils.hpp Wed Feb 23 17:59:11 2011 -0800
@@ -52,13 +52,21 @@
static void Utils::random_seed(unsigned int seed);
static double random(double minimum, double maximum);
+ // compares two values to within the datatype's epsilon
template<class T>
static bool compare_distance(const T& actual, const T& expected)
const T epsilon = std::numeric_limits<T>::epsilon();
+ return compare_approx<T>(actual, expected, epsilon);
+ // compares two values to within a given tolerance
+ template<class T>
+ static bool compare_approx(const T& actual, const T& expected, const T& tolerance)
const T diff = actual - expected;
- if ( !((diff <= epsilon) && (diff >= -epsilon )) )
+ if ( !((diff <= tolerance) && (diff >= -tolerance )) )
return false;
diff -r 5b9465f9d5ad -r 13177ebbdcd8 test/unit/UtilsTest.cpp
--- a/test/unit/UtilsTest.cpp Wed Feb 23 17:22:36 2011 -0800
+++ b/test/unit/UtilsTest.cpp Wed Feb 23 17:59:11 2011 -0800
@@ -38,18 +38,34 @@
-BOOST_AUTO_TEST_CASE(test_eps)
+BOOST_AUTO_TEST_CASE(test_comparators)
bool ok;
- ok = Utils::compare_distance<float>(1.000001f, 1.0f);
- BOOST_CHECK(!ok);
+ ok = Utils::compare_distance<float>(1.000001f, 1.0f);
+ BOOST_CHECK(!ok);
- ok = Utils::compare_distance<float>(1.0000001f, 1.0f);
- BOOST_CHECK(ok);
+ ok = Utils::compare_distance<float>(1.0000001f, 1.0f);
+ BOOST_CHECK(ok);
- ok = Utils::compare_distance<float>(1.00000001f, 1.0f);
- BOOST_CHECK(ok);
+ ok = Utils::compare_distance<float>(1.00000001f, 1.0f);
+ BOOST_CHECK(ok);
+ ok = Utils::compare_approx<float>(1.001f, 1.0f, 0.0001);
+ BOOST_CHECK(!ok);
+ ok = Utils::compare_approx<float>(1.001f, 1.0f, 0.001);
+ BOOST_CHECK(!ok);
+ ok = Utils::compare_approx<float>(1.001f, 1.0f, 0.01);
+ BOOST_CHECK(ok);
+ ok = Utils::compare_approx<float>(1.001f, 1.0f, 0.1);
+ BOOST_CHECK(ok);
More information about the Liblas-commits
