[Liblas-commits] libpc: improved version tests
liblas-commits at liblas.org
Thu Feb 24 13:58:53 EST 2011
details: http://hg.liblas.orglibpc/rev/fa34b7e642ee
changeset: 93:fa34b7e642ee
user: Michael P. Gerlek <mpg at flaxen.com>
date: Thu Feb 24 10:58:48 2011 -0800
description:
diffstat:
test/unit/ConfigTest.cpp | 10 ++++++++--
1 files changed, 8 insertions(+), 2 deletions(-)
diffs (28 lines):
diff -r e3294e88851a -r fa34b7e642ee test/unit/ConfigTest.cpp
--- a/test/unit/ConfigTest.cpp Thu Feb 24 10:55:38 2011 -0800
+++ b/test/unit/ConfigTest.cpp Thu Feb 24 10:58:48 2011 -0800
@@ -46,16 +46,22 @@
BOOST_AUTO_TEST_CASE(test_version)
- // just verify it is a string, don't worry about the contents
+ // just verify these functions can be called, don't worry about the values
std::string version = GetVersionString();
+ BOOST_CHECK(!version.empty());
std::string fullVersion = GetFullVersionString();
+ BOOST_CHECK(!fullVersion.empty());
int major = GetVersionMajor();
+ BOOST_CHECK(major >= 0);
int minor = GetVersionMinor();
+ BOOST_CHECK(minor >= 0);
int patch = GetVersionPatch();
+ BOOST_CHECK(patch >= 0);
- int x = GetVersionInteger();
+ int bignum = GetVersionInteger();
+ BOOST_CHECK(bignum > 0);
return;
More information about the Liblas-commits
