[Liblas-commits] laszip: these files are not used anymore according
to Martin
liblas-commits at liblas.org
Mon Jan 3 12:30:28 EST 2011
details: http://hg.liblas.orglaszip/rev/25aa62883097
changeset: 101:25aa62883097
user: Howard Butler <hobu.inc at gmail.com>
date: Mon Jan 03 11:30:22 2011 -0600
description:
these files are not used anymore according to Martin
diffstat:
src/CMakeLists.txt | 2 -
src/lasreaditemrawendianswapped.hpp | 102 -----------------------------------
src/laswriteitemrawendianswapped.hpp | 99 ---------------------------------
3 files changed, 0 insertions(+), 203 deletions(-)
diffs (225 lines):
diff -r 8fe8b5444dcf -r 25aa62883097 src/CMakeLists.txt
--- a/src/CMakeLists.txt Thu Dec 30 11:32:59 2010 -0600
+++ b/src/CMakeLists.txt Mon Jan 03 11:30:22 2011 -0600
@@ -27,12 +27,10 @@
integercompressor.hpp
lasreaditem.hpp
lasreaditemcompressed_v1.hpp
- lasreaditemrawendianswapped.hpp
lasreaditemraw.hpp
lasreadpoint.hpp
laswriteitem.hpp
laswriteitemcompressed_v1.hpp
- laswriteitemrawendianswapped.hpp
laswriteitemraw.hpp
laswritepoint.hpp
mydefs.hpp
diff -r 8fe8b5444dcf -r 25aa62883097 src/lasreaditemrawendianswapped.hpp
--- a/src/lasreaditemrawendianswapped.hpp Thu Dec 30 11:32:59 2010 -0600
+++ /dev/null Thu Jan 01 00:00:00 1970 +0000
@@ -1,102 +0,0 @@
- * Project: integrating laszip into liblas - http://liblas.org -
- * Purpose:
- * Author: Martin Isenburg
- * isenburg at cs.unc.edu
- * Copyright (c) 2010, Martin Isenburg
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
- FILE: LASitemreadrawendianswapped.hpp
- CONTENTS:
- Implementation of LASitemReadRaw for *all* items that compose a point.
- PROGRAMMERS:
- martin isenburg at cs.unc.edu
- COPYRIGHT:
- copyright (C) 2007-2010 martin isenburg at cs.unc.edu
- This software is distributed in the hope that it will be useful,
- but WITHOUT ANY WARRANTY; without even the implied warranty of
- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
- CHANGE HISTORY:
- 14 December 2010 -- at Starbucks in Offenbach before watching "Fair Game"
-#ifndef LAS_READ_ITEM_RAW_ENDIAN_SWAPPED_H
-#define LAS_READ_ITEM_RAW_ENDIAN_SWAPPED_H
-#include "lasreaditem.hpp"
-#include <assert.h>
-class LASreadItemRawEndianSwapped_POINT10 : public LASreadItemRaw
-public:
- LASreadItemRawEndianSwapped_POINT10(){};
- BOOL read(U8* item)
- U8 copy[20];
- BOOL flag = instream->getBytes(copy, 20);
- ENDIAN_SWAP_32(&(copy[ 0]), &(item[ 0])); // x
- ENDIAN_SWAP_32(&(copy[ 4]), &(item[ 4])); // y
- ENDIAN_SWAP_32(&(copy[ 8]), &(item[ 8])); // z
- ENDIAN_SWAP_16(&(copy[12]), &(item[12])); // intensity
- item[14] = copy[14]; // bitfield
- item[15] = copy[15]; // classification
- item[16] = copy[16]; // scan_angle_rank
- item[17] = copy[17]; // user_data
- ENDIAN_SWAP_16(&(copy[18]), &(item[18])); // point_source_ID
- return flag;
-class LASreadItemRawEndianSwapped_GPSTIME : public LASreadItemRaw
-public:
- LASreadItemRawEndianSwapped_GPSTIME(){};
- U8 copy[8];
- BOOL flag = instream->getBytes(copy, 8);
- ENDIAN_SWAP_64(copy, item);
- return flag;
-class LASreadItemRawEndianSwapped_RGB : public LASreadItemRaw
-public:
- LASreadItemRawEndianSwapped_RGB(){};
- U8 copy[6];
- BOOL flag = instream->getBytes(copy, 6);
- ENDIAN_SWAP_16(&(copy[0]), &(item[0]));
- ENDIAN_SWAP_16(&(copy[2]), &(item[2]));
- ENDIAN_SWAP_16(&(copy[4]), &(item[4]));
- return flag;
-#endif
diff -r 8fe8b5444dcf -r 25aa62883097 src/laswriteitemrawendianswapped.hpp
--- a/src/laswriteitemrawendianswapped.hpp Thu Dec 30 11:32:59 2010 -0600
@@ -1,99 +0,0 @@
- * Purpose:
- FILE: LASwriteitemrawendianswapped.hpp
- CONTENTS:
- Implementation of LASwriteItemRaw for *all* items that compose a point.
- PROGRAMMERS:
- COPYRIGHT:
- CHANGE HISTORY:
-#ifndef LAS_WRITE_ITEM_RAW_WITH_ENDIAN_SWAPPED_H
-#define LAS_WRITE_ITEM_RAW_WITH_ENDIAN_SWAPPED_H
-#include "laswriteitem.hpp"
-class LASwriteItemRawEndianSwapped_POINT10 : public LASwriteItemRaw
-public:
- LASwriteItemRawEndianSwapped_POINT10(){};
- BOOL write(U8* item)
- U8 copy[20];
- ENDIAN_SWAP_32(&(item[ 0]), &(copy[ 0])); // x
- ENDIAN_SWAP_32(&(item[ 4]), &(copy[ 4])); // y
- ENDIAN_SWAP_32(&(item[ 8]), &(copy[ 8])); // z
- ENDIAN_SWAP_16(&(item[12]), &(copy[12])); // intensity
- copy[14] = item[14]; // bitfield
- copy[15] = item[15]; // classification
- copy[16] = item[16]; // scan_angle_rank
- copy[17] = item[17]; // user_data
- ENDIAN_SWAP_16(&(item[18]), &(copy[18])); // point_source_ID
- return outstream->putBytes(copy, 20);
-class LASwriteItemRawEndianSwapped_GPSTIME : public LASwriteItemRaw
-public:
- LASwriteItemRawEndianSwapped_GPSTIME() {};
- U8 copy[8];
- ENDIAN_SWAP_64(item, copy);
- return outstream->putBytes(copy, 8);
-class LASwriteItemRawEndianSwapped_RGB : public LASwriteItemRaw
-public:
- LASwriteItemRawEndianSwapped_RGB(){}
- U8 copy[6];
- ENDIAN_SWAP_16(&(item[0]), &(copy[0]));
- ENDIAN_SWAP_16(&(item[2]), &(copy[2]));
- ENDIAN_SWAP_16(&(item[4]), &(copy[4]));
- return outstream->putBytes(copy, 6);
-#endif
More information about the Liblas-commits
