[Liblas-commits] laszip: add osgeo4w packaging script
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Jan 3 13:20:44 EST 2011
details:   http://hg.liblas.orglaszip/rev/5702cc183fe5
changeset: 109:5702cc183fe5
user:      Howard Butler <hobu.inc at gmail.com>
date:      Mon Jan 03 12:20:33 2011 -0600
description:
diffstat:
 cmake/modules/BuildOSGeo4W.cmake |  125 +++++++++++++++++++++++++++++++++++++++
 1 files changed, 125 insertions(+), 0 deletions(-)
diffs (129 lines):
diff -r 5ea850338ed1 -r 5702cc183fe5 cmake/modules/BuildOSGeo4W.cmake
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/cmake/modules/BuildOSGeo4W.cmake	Mon Jan 03 12:20:33 2011 -0600
@@ -0,0 +1,125 @@
+# OSGeo4W packaging
+set(OSGEO4W_DIR osgeo4w)
+set(OSGEO4W_LIB_DIR ${OSGEO4W_DIR}/lib)
+set(OSGEO4W_ETC_DIR ${OSGEO4W_DIR}/etc)
+set(OSGEO4W_ETC_INI_DIR ${OSGEO4W_DIR}/etc/ini)
+set(OSGEO4W_ETC_POSTINSTALL_DIR ${OSGEO4W_DIR}/etc/postinstall)
+set(OSGEO4W_LIB_BIN_DIR ${OSGEO4W_DIR}/lib/bin)
+set(OSGEO4W_BIN_DIR ${OSGEO4W_DIR}/bin)
+set(OSGEO4W_DEVEL_DIR ${OSGEO4W_DIR}/devel)
+set(OSGEO4W_DEVEL_INCLUDE_DIR ${OSGEO4W_DEVEL_DIR}/include)
+set(OSGEO4W_DEVEL_INCLUDE_LASZIP_DIR ${OSGEO4W_DEVEL_INCLUDE_DIR}/laszip)
+set(OSGEO4W_DEVEL_LIB_DIR ${OSGEO4W_DEVEL_DIR}/lib)
+set(OSGEO4W_DEVEL_BIN_DIR ${OSGEO4W_DEVEL_DIR}/bin)
+set(OSGEO4W_PACKAGES ${OSGEO4W_DIR}/packages)
+set(OSGEO4W_DIRECTORIES
+    ${OSGEO4W_DIR}
+    ${OSGEO4W_ETC_DIR}
+    ${OSGEO4W_ETC_INI_DIR}
+    ${OSGEO4W_ETC_POSTINSTALL_DIR}
+    ${OSGEO4W_LIB_DIR}
+    ${OSGEO4W_LIB_BIN_DIR}
+    ${OSGEO4W_DEVEL_DIR}
+    ${OSGEO4W_DEVEL_INCLUDE_DIR}
+    ${OSGEO4W_DEVEL_INCLUDE_LASZIP_DIR}
+    ${OSGEO4W_DEVEL_LIB_DIR}
+    ${OSGEO4W_DEVEL_BIN_DIR}
+    ${OSGEO4W_PACKAGES}
+    ${OSGEO4W_BIN_DIR})
+add_custom_target(make_osgeo4w_directories
+  COMMAND ${CMAKE_COMMAND} -E echo "Building OSGeo4W install directories")
+foreach(utility ${LASZIP_UTILITIES})
+    add_dependencies(  make_osgeo4w_directories  ${utility} )
+endforeach()
+macro (make_directories)
+    add_custom_command(
+        TARGET make_osgeo4w_directories
+        COMMAND ${CMAKE_COMMAND} -E  remove_directory  ${laszip_SOURCE_DIR}/osgeo4w DEPENDS osgeo4w
+    foreach(directory ${OSGEO4W_DIRECTORIES})
+    STRING(REGEX REPLACE "/" "_" target "${directory}" )
+        COMMAND ${CMAKE_COMMAND} -E make_directory ${directory}
+    endforeach()
+endmacro(make_directories)
+add_custom_target(copy ALL COMMENT "Copying OSGeo4W files")
+add_dependencies( copy make_osgeo4w_directories  )
+macro(copy_files GLOBPAT DESTINATION  )
+    file(GLOB_RECURSE COPY_FILES
+         RELATIVE ${CMAKE_CURRENT_SOURCE_DIR}
+        ${GLOBPAT})
+    foreach(FILENAME ${COPY_FILES})
+        set(SRC "${FILENAME}")
+        set(DST "${DESTINATION}")
+            TARGET copy
+            COMMAND ${CMAKE_COMMAND} -E copy ${SRC} ${DST}
+    endforeach(FILENAME)
+endmacro(copy_files)
+macro(copy_directory SOURCE DESTINATION  )
+            TARGET copy
+            COMMAND ${CMAKE_COMMAND} -E copy_directory ${SOURCE} ${DESTINATION}
+endmacro(copy_directory)
+add_custom_target(tar
+  COMMAND ${CMAKE_COMMAND} -E echo "Tarring OSGeo4W install")
+add_dependencies( tar copy  )
+macro (tar_directories source destination base_paths)
+        TARGET tar
+        COMMAND ${CMAKE_COMMAND} -E chdir ${source} cmake -E tar cjf  ${destination} ${base_paths}
+endmacro(tar_directories)
+make_directories()
+copy_files(${LASZIP_BUILD_OUTPUT_DIRECTORY}/laszip.dll ${OSGEO4W_BIN_DIR}/  )
+copy_files(${LASZIP_BUILD_OUTPUT_DIRECTORY}/laszip.lib ${OSGEO4W_DEVEL_LIB_DIR}/  )
+copy_directory(./include/laszip/ ${OSGEO4W_DEVEL_INCLUDE_LASZIP_DIR}/  )
+tar_directories(${OSGEO4W_DIR} ${libLAS_SOURCE_DIR}/${OSGEO4W_PACKAGES}/laszip-${VERSION}.tar.bz2 "bin/")
+tar_directories(${OSGEO4W_DIR}/devel ${libLAS_SOURCE_DIR}/${OSGEO4W_PACKAGES}/laszip-devel-${VERSION}.tar.bz2 "lib/;include")
+add_custom_target(osgeo4w
+    COMMAND ${CMAKE_COMMAND} -E echo "Making OSGeo4W build")
+add_dependencies( osgeo4w tar   )
More information about the Liblas-commits mailing list
