[Liblas-commits] hg: enable Seek and ReadAt, though slowly
liblas-commits at liblas.org
Wed Jan 5 11:23:23 EST 2011
details: http://hg.liblas.orghg/rev/52f6184926f8
changeset: 2688:52f6184926f8
user: Michael P. Gerlek <mpg at flaxen.com>
date: Wed Jan 05 08:18:43 2011 -0800
description:
Subject: hg: added disclaimer
details: http://hg.liblas.orghg/rev/2eb36567790c
changeset: 2689:2eb36567790c
date: Wed Jan 05 08:22:59 2011 -0800
description:
added disclaimer
Subject: hg: pull-merge
details: http://hg.liblas.orghg/rev/439c024e009f
changeset: 2690:439c024e009f
date: Wed Jan 05 08:23:09 2011 -0800
description:
pull-merge
diffstat:
apps/lasblock.cpp | 41 ++++++------
include/liblas/detail/reader/zipreader.hpp | 8 ++-
src/detail/reader/zipreader.cpp | 97 ++++++++++++++++++++++-------
test/unit/zipreader_test.cpp | 78 ++++++++++++++++++-----
4 files changed, 159 insertions(+), 65 deletions(-)
diffs (truncated from 354 to 300 lines):
diff -r 86ba5e9da0dd -r 439c024e009f apps/lasblock.cpp
--- a/apps/lasblock.cpp Tue Jan 04 15:39:40 2011 -0800
+++ b/apps/lasblock.cpp Wed Jan 05 08:23:09 2011 -0800
@@ -102,35 +102,34 @@
for ( boost::uint32_t i = 0; i < c.GetBlockCount(); ++i )
- OStreamPtr ofs(new std::ofstream);
- SummaryPtr summary(new::liblas::CoordinateSummary);
std::ostringstream name;
name << out << "-" << i <<".las";
+ SummaryPtr summary(new::liblas::CoordinateSummary);
- const liblas::chipper::Block& b = c.GetBlock(i);
- header.SetExtent(b.GetBounds());
+ OStreamPtr ofs(new std::ofstream);
- WriterPtr writer = start_writer(ofs, name.str(), header);
+ const liblas::chipper::Block& b = c.GetBlock(i);
+ header.SetExtent(b.GetBounds());
+ WriterPtr writer = start_writer(ofs, name.str(), header);
+ std::vector<boost::uint32_t> ids = b.GetIDs();
+ for ( boost::uint32_t pi = 0; pi < ids.size(); ++pi )
+ bool read = reader.ReadPointAt(ids[pi]);
+ if (read) {
+ liblas::Point const& p = reader.GetPoint();
+ summary->AddPoint(p);
+ writer->WritePoint(p);
- std::vector<boost::uint32_t> ids = b.GetIDs();
- for ( boost::uint32_t pi = 0; pi < ids.size(); ++pi )
- bool read = reader.ReadPointAt(pi);
- if (read) {
- liblas::Point const& p = reader.GetPoint();
- summary->AddPoint(p);
- writer->WritePoint(p);
- writer = WriterPtr();
- ofs = OStreamPtr();
liblas::Header hnew = FetchHeader(name.str());
RepairHeader(*summary, hnew);
diff -r 86ba5e9da0dd -r 439c024e009f include/liblas/detail/reader/zipreader.hpp
--- a/include/liblas/detail/reader/zipreader.hpp Tue Jan 04 15:39:40 2011 -0800
+++ b/include/liblas/detail/reader/zipreader.hpp Wed Jan 05 08:23:09 2011 -0800
@@ -72,6 +72,11 @@
void SetHeader(liblas::Header const& header);
liblas::Point const& GetPoint() const { return *m_point; }
void ReadNextPoint();
+ // Warning: seeking is not supporting in the laszip format, so
+ // ReadPointAt() and Seek() are implemented to rewind to the
+ // beginning of the file and read through all the N-1 previous
+ // point first. That is, these functions are SLOW.
liblas::Point const& ReadPointAt(std::size_t n);
void Seek(std::size_t n);
@@ -101,7 +106,8 @@
std::vector<liblas::TransformPtr> m_transforms;
private:
- void ReadIdiom();
+ void ReadIdiom(bool recordPoint);
+ void ResetUnzipper();
LASunzipper* m_unzipper;
ZipPoint* m_zipPoint;
diff -r 86ba5e9da0dd -r 439c024e009f src/detail/reader/zipreader.cpp
--- a/src/detail/reader/zipreader.cpp Tue Jan 04 15:39:40 2011 -0800
+++ b/src/detail/reader/zipreader.cpp Wed Jan 05 08:23:09 2011 -0800
@@ -194,7 +194,7 @@
m_header = HeaderPtr(new liblas::Header(header));
-void ZipReaderImpl::ReadIdiom()
+void ZipReaderImpl::ReadIdiom(bool recordPoint)
//////m_point_reader->read();
//////++m_current;
@@ -214,15 +214,20 @@
throw liblas_error("Error reading compressed point data (2)");
- std::vector<boost::uint8_t> v(m_zipPoint->m_lz_point_size);
- for (unsigned int i=0; i<m_zipPoint->m_lz_point_size; i++)
+ if (recordPoint)
- v[i] = m_zipPoint->m_lz_point_data[i];
- //printf("%d %d\n", v[i], i);
+ std::vector<boost::uint8_t> v(m_zipPoint->m_lz_point_size);
+ for (unsigned int i=0; i<m_zipPoint->m_lz_point_size; i++)
+ v[i] = m_zipPoint->m_lz_point_data[i];
+ //printf("%d %d\n", v[i], i);
+ m_point->SetData(v);
+ ++m_current;
- m_point->SetData(v);
- ++m_current;
+ return;
void ZipReaderImpl::ReadNextPoint()
@@ -237,7 +242,7 @@
throw std::out_of_range("ReadNextPoint: file has no more points to read, end of file reached");
- ReadIdiom();
+ ReadIdiom(true);
// Filter the points and continue reading until we either find
// one to keep or throw an exception.
@@ -245,11 +250,11 @@
bool bLastPoint = false;
if (!FilterPoint(*m_point))
- ReadIdiom();
+ ReadIdiom(true);
while (!FilterPoint(*m_point))
- ReadIdiom();
+ ReadIdiom(true);
if (m_current == m_size)
bLastPoint = true;
@@ -258,7 +263,6 @@
if (!m_transforms.empty())
TransformPoint(*m_point);
@@ -270,6 +274,34 @@
+// laszip doesn't support seeking, or any want to do a reset, so we do it manually instead
+void ZipReaderImpl::ResetUnzipper()
+ PointFormatName format = m_header->GetDataFormatId();
+ if (!m_unzipper)
+ throw liblas_error("Error resetting uncompression engine (1)");
+ unsigned int stat = 1;
+ try
+ m_unzipper->close();
+ stat = m_unzipper->open(m_ifs, m_zipPoint->m_num_items, m_zipPoint->m_items, LASzip::COMPRESSION_DEFAULT);
+ catch(...)
+ throw liblas_error("Error resetting uncompression engine (2)");
+ if (stat != 0)
+ throw liblas_error("Error resetting uncompression engine (3)");
+ return;
liblas::Point const& ZipReaderImpl::ReadPointAt(std::size_t n)
if (m_size == n) {
@@ -280,27 +312,36 @@
throw std::runtime_error(msg.str());
- if (n!=0)
- throw not_yet_implemented("not yet implemented");
- std::streamsize const pos = /*(static_cast<std::streamsize>(n) * m_header->GetDataRecordLength()) +*/ m_header->GetDataOffset();
+ std::streamsize const pos = m_header->GetDataOffset();
m_ifs.clear();
m_ifs.seekg(pos, std::ios::beg);
- ReadIdiom();
- --m_current; // undo what was done in Idiom
+ ResetUnzipper();
+ // skip over a whole bunch
+ if (n > 0)
+ for (std::size_t idx = 0; idx < n; idx++)
+ ReadIdiom(false);
+ // read the one we want (and undo the counter update)
+ ReadIdiom(true);
+ --m_current;
std::cout << "Should be transforming point" << std::endl;
return *m_point;
void ZipReaderImpl::Seek(std::size_t n)
if (m_size == n) {
@@ -311,16 +352,22 @@
- if (n!=0)
- std::streamsize pos = /*(static_cast<std::streamsize>(n) * m_header->GetDataRecordLength()) +*/ m_header->GetDataOffset();
+ std::streamsize pos = m_header->GetDataOffset();
m_ifs.clear();
+ ResetUnzipper();
+ if (n > 0)
+ ReadIdiom(false);
m_current = n;
diff -r 86ba5e9da0dd -r 439c024e009f test/unit/zipreader_test.cpp
--- a/test/unit/zipreader_test.cpp Tue Jan 04 15:39:40 2011 -0800
+++ b/test/unit/zipreader_test.cpp Wed Jan 05 08:23:09 2011 -0800
@@ -110,27 +110,69 @@
liblas::Reader reader_las = factory.CreateWithStream(ifs_las);
liblas::Reader reader_laz = factory.CreateWithStream(ifs_laz);
- reader_las.ReadNextPoint();
- liblas::Point p0_las = reader_las.GetPoint();
- liblas::Point p1_las = reader_las.GetPoint();
- liblas::Point p2_las = reader_las.GetPoint();
+ // test ReadPointAt()
+ reader_las.ReadPointAt(2);
+ liblas::Point p2_las = reader_las.GetPoint();
+ reader_las.ReadPointAt(1);
+ liblas::Point p1_las = reader_las.GetPoint();
+ reader_las.ReadPointAt(0);
+ liblas::Point p0_las = reader_las.GetPoint();
- //reader_laz.ReadPointAt(2);
- //liblas::Point p2_laz = reader_laz.GetPoint();
- //reader_laz.ReadPointAt(1);
- //liblas::Point p1_laz = reader_laz.GetPoint();
- reader_laz.ReadPointAt(0);
- liblas::Point p0_laz = reader_laz.GetPoint();
+ test_file_12Color_point0(p0_las);
+ test_file_12Color_point1(p1_las);
+ test_file_12Color_point2(p2_las);
+ reader_laz.ReadPointAt(2);
+ liblas::Point p2_laz = reader_laz.GetPoint();
+ reader_laz.ReadPointAt(1);
+ liblas::Point p1_laz = reader_laz.GetPoint();
+ reader_laz.ReadPointAt(0);
More information about the Liblas-commits
