[Liblas-commits] laszip: forgot to copy & commit
liblas-commits at liblas.org
Wed Jan 5 12:56:58 EST 2011
details: http://hg.liblas.orglaszip/rev/daac63e565cf
changeset: 116:daac63e565cf
user: isenburg
date: Wed Jan 05 09:56:48 2011 -0800
description:
diffstat:
tools/laszippertest.cpp | 24 ++++++++++++------------
1 files changed, 12 insertions(+), 12 deletions(-)
diffs (105 lines):
diff -r dcd14845f9ed -r daac63e565cf tools/laszippertest.cpp
--- a/tools/laszippertest.cpp Tue Jan 04 15:57:54 2011 -0800
+++ b/tools/laszippertest.cpp Wed Jan 05 09:56:48 2011 -0800
@@ -154,7 +154,7 @@
ostream1 = new ofstream();
ostream1->open("test1.lax", std::ios::out | std::ios::binary );
#endif
- if (laszipper1->open(*ostream1, num_items, items, LASzip::COMPRESSION_NONE) != 0)
+ if (laszipper1->open(*ostream1, num_items, items, LASzip::POINT_BY_POINT_RAW) != 0)
fprintf(stderr, "ERROR: could not open laszipper1\n");
return 0;
@@ -168,7 +168,7 @@
ostream2 = new ofstream();
ostream2->open("test2.lax", std::ios::out | std::ios::binary );
#endif
- if (laszipper2->open(*ostream2, num_items, items, LASzip::COMPRESSION_ARITHMETIC) != 0)
+ if (laszipper2->open(*ostream2, num_items, items, LASzip::POINT_BY_POINT_ARITHMETIC) != 0)
fprintf(stderr, "ERROR: could not open laszipper2\n");
return 0;
@@ -182,7 +182,7 @@
ostream3 = new ofstream();
ostream3->open("test3.lax", std::ios::out | std::ios::binary );
#endif
- if (laszipper3->open(*ostream3, num_items, items, LASzip::COMPRESSION_RANGE) != 0)
+ if (laszipper3->open(*ostream3, num_items, items, LASzip::POINT_BY_POINT_RANGE) != 0)
fprintf(stderr, "ERROR: could not open laszipper3\n");
return 0;
@@ -191,21 +191,21 @@
else
ofile1 = fopen("test1.lax", "wb");
- if (laszipper1->open(ofile1, num_items, items, LASzip::COMPRESSION_NONE) != 0)
+ if (laszipper1->open(ofile1, num_items, items, LASzip::POINT_BY_POINT_RAW) != 0)
return 0;
ofile2 = fopen("test2.lax", "wb");
- if (laszipper2->open(ofile2, num_items, items, LASzip::COMPRESSION_ARITHMETIC) != 0)
+ if (laszipper2->open(ofile2, num_items, items, LASzip::POINT_BY_POINT_ARITHMETIC) != 0)
return 0;
ofile3 = fopen("test3.lax", "wb");
- if (laszipper3->open(ofile3, num_items, items, LASzip::COMPRESSION_RANGE) != 0)
+ if (laszipper3->open(ofile3, num_items, items, LASzip::POINT_BY_POINT_RANGE) != 0)
return 0;
@@ -295,7 +295,7 @@
istream1 = new ifstream();
istream1->open("test1.lax", std::ios::in | std::ios::binary );
#endif
- if (lasunzipper1->open(*istream1, num_items, items, LASzip::COMPRESSION_NONE) != 0)
+ if (lasunzipper1->open(*istream1, num_items, items, LASzip::POINT_BY_POINT_RAW) != 0)
fprintf(stderr, "ERROR: could not open lasunzipper1\n");
return 0;
@@ -308,7 +308,7 @@
istream2 = new ifstream();
istream2->open("test2.lax", std::ios::in | std::ios::binary );
#endif
- if (lasunzipper2->open(*istream2, num_items, items, LASzip::COMPRESSION_ARITHMETIC) != 0)
+ if (lasunzipper2->open(*istream2, num_items, items, LASzip::POINT_BY_POINT_ARITHMETIC) != 0)
fprintf(stderr, "ERROR: could not open lasunzipper2\n");
return 0;
@@ -321,7 +321,7 @@
istream3 = new ifstream();
istream3->open("test3.lax", std::ios::in | std::ios::binary );
#endif
- if (lasunzipper3->open(*istream3, num_items, items, LASzip::COMPRESSION_RANGE) != 0)
+ if (lasunzipper3->open(*istream3, num_items, items, LASzip::POINT_BY_POINT_RANGE) != 0)
fprintf(stderr, "ERROR: could not open lasunzipper3\n");
return 0;
@@ -330,19 +330,19 @@
else
ifile1 = fopen("test1.lax", "rb");
- if (lasunzipper1->open(ifile1, num_items, items, LASzip::COMPRESSION_NONE) != 0)
+ if (lasunzipper1->open(ifile1, num_items, items, LASzip::POINT_BY_POINT_RAW) != 0)
return 0;
ifile2 = fopen("test2.lax", "rb");
- if (lasunzipper2->open(ifile2, num_items, items, LASzip::COMPRESSION_ARITHMETIC) != 0)
+ if (lasunzipper2->open(ifile2, num_items, items, LASzip::POINT_BY_POINT_ARITHMETIC) != 0)
return 0;
ifile3 = fopen("test3.lax", "rb");
- if (lasunzipper3->open(ifile3, num_items, items, LASzip::COMPRESSION_RANGE) != 0)
+ if (lasunzipper3->open(ifile3, num_items, items, LASzip::POINT_BY_POINT_RANGE) != 0)
return 0;
More information about the Liblas-commits
