[Liblas-commits] hg: account for LASzip's rename of
DEFAULT_COMPRESSION
liblas-commits at liblas.org
Wed Jan 5 22:35:33 EST 2011
details: http://hg.liblas.orghg/rev/f797616d8827
changeset: 2699:f797616d8827
user: Howard Butler <hobu.inc at gmail.com>
date: Wed Jan 05 21:35:25 2011 -0600
description:
account for LASzip's rename of DEFAULT_COMPRESSION
diffstat:
src/detail/reader/zipreader.cpp | 4 +-
src/detail/writer/zipwriter.cpp | 44 ++--
src/detail/zippoint.cpp | 316 ++++++++++++++++++++--------------------
3 files changed, 182 insertions(+), 182 deletions(-)
diffs (truncated from 486 to 300 lines):
diff -r ddba37c0a960 -r f797616d8827 src/detail/reader/zipreader.cpp
--- a/src/detail/reader/zipreader.cpp Wed Jan 05 16:10:05 2011 -0800
+++ b/src/detail/reader/zipreader.cpp Wed Jan 05 21:35:25 2011 -0600
@@ -121,7 +121,7 @@
unsigned int stat = 1;
try
- stat = m_unzipper->open(m_ifs, m_zipPoint->m_num_items, m_zipPoint->m_items, LASzip::COMPRESSION_DEFAULT);
+ stat = m_unzipper->open(m_ifs, m_zipPoint->m_num_items, m_zipPoint->m_items, LASzip::DEFAULT_COMPRESSION);
catch(...)
@@ -281,7 +281,7 @@
try
m_unzipper->close();
catch(...)
diff -r ddba37c0a960 -r f797616d8827 src/detail/writer/zipwriter.cpp
--- a/src/detail/writer/zipwriter.cpp Wed Jan 05 16:10:05 2011 -0800
+++ b/src/detail/writer/zipwriter.cpp Wed Jan 05 21:35:25 2011 -0600
@@ -2,7 +2,7 @@
* $Id$
* Project: libLAS - http://liblas.org - A BSD library for LAS format data.
- * Purpose: laszip writer implementation for C++ libLAS
+ * Purpose: laszip writer implementation for C++ libLAS
* Author: Michael P. Gerlek (mpg at flaxen.com)
@@ -46,9 +46,9 @@
#include <liblas/detail/writer/header.hpp>
#include <liblas/detail/writer/point.hpp>
#include <liblas/detail/private_utility.hpp>
-#include <liblas/detail/zippoint.hpp>
-// laszip
-#include <laszip/laszipper.hpp>
+#include <liblas/detail/zippoint.hpp>
+// laszip
+#include <laszip/laszipper.hpp>
// std
#include <vector>
#include <fstream>
@@ -115,13 +115,13 @@
throw liblas_error("Error opening compression engine (1)");
- PointFormatName format = m_header->GetDataFormatId();
+ PointFormatName format = m_header->GetDataFormatId();
m_zipPoint = new ZipPoint(format);
try
- stat = m_zipper->open(m_ofs, m_zipPoint->m_num_items, m_zipPoint->m_items, LASzip::COMPRESSION_DEFAULT);
+ stat = m_zipper->open(m_ofs, m_zipPoint->m_num_items, m_zipPoint->m_items, LASzip::DEFAULT_COMPRESSION);
catch(...)
@@ -132,27 +132,27 @@
throw liblas_error("Error opening compression engine (2)");
- const std::vector<boost::uint8_t>& v = point.GetData();
- for (unsigned int i=0; i<m_zipPoint->m_lz_point_size; i++)
- m_zipPoint->m_lz_point_data[i] = v[i];
- //printf("%d %d\n", v[i], i);
+ const std::vector<boost::uint8_t>& v = point.GetData();
+ for (unsigned int i=0; i<m_zipPoint->m_lz_point_size; i++)
+ m_zipPoint->m_lz_point_data[i] = v[i];
+ //printf("%d %d\n", v[i], i);
bool ok = false;
try
- ok = m_zipper->write(m_zipPoint->m_lz_point);
- catch(...)
- throw liblas_error("Error writing compressed point data (1)");
- if (!ok)
- throw liblas_error("Error writing compressed point data (2)");
+ ok = m_zipper->write(m_zipPoint->m_lz_point);
+ catch(...)
+ throw liblas_error("Error writing compressed point data (1)");
+ if (!ok)
+ throw liblas_error("Error writing compressed point data (2)");
++m_pointCount;
diff -r ddba37c0a960 -r f797616d8827 src/detail/zippoint.cpp
--- a/src/detail/zippoint.cpp Wed Jan 05 16:10:05 2011 -0800
+++ b/src/detail/zippoint.cpp Wed Jan 05 21:35:25 2011 -0600
@@ -1,90 +1,90 @@
- * $Id$
- * Project: libLAS - http://liblas.org - A BSD library for LAS format data.
- * Purpose: laszip helper functions for C++ libLAS
- * Author: Michael P. Gerlek (mpg at flaxen.com)
- * Copyright (c) 2010, Michael P. Gerlek
- * All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following
- * conditions are met:
- * * Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer.
- * * Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in
- * the documentation and/or other materials provided
- * with the distribution.
- * * Neither the name of the Martin Isenburg or Iowa Department
- * of Natural Resources nor the names of its contributors may be
- * used to endorse or promote products derived from this software
- * without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
- * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
- * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
- * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
- * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
- * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
- * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
- * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
- * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
- * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
- * OF SUCH DAMAGE.
-#ifdef HAVE_LASZIP
-#include <liblas/liblas.hpp>
-#include <liblas/detail/private_utility.hpp>
+ * $Id$
+ * Project: libLAS - http://liblas.org - A BSD library for LAS format data.
+ * Purpose: laszip helper functions for C++ libLAS
+ * Author: Michael P. Gerlek (mpg at flaxen.com)
+ * Copyright (c) 2010, Michael P. Gerlek
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following
+ * conditions are met:
+ * * Redistributions of source code must retain the above copyright
+ * notice, this list of conditions and the following disclaimer.
+ * * Redistributions in binary form must reproduce the above copyright
+ * notice, this list of conditions and the following disclaimer in
+ * the documentation and/or other materials provided
+ * with the distribution.
+ * * Neither the name of the Martin Isenburg or Iowa Department
+ * of Natural Resources nor the names of its contributors may be
+ * used to endorse or promote products derived from this software
+ * without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+ * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+ * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+ * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+#ifdef HAVE_LASZIP
+#include <liblas/liblas.hpp>
+#include <liblas/detail/private_utility.hpp>
// laszip
#include <laszip/laszip.hpp>
-// std
-#include <vector>
-#include <fstream>
-#include <stdexcept>
-#include <cstdlib> // std::size_t
-#include <cassert>
-namespace liblas { namespace detail {
-static std::string laszip_userid("laszip encoded");
-static boost::uint16_t laszip_recordid = 22204;
-static std::string laszip_description = "encoded for sequential access";
-ZipPoint::ZipPoint(PointFormatName format) :
+// std
+#include <vector>
+#include <fstream>
+#include <stdexcept>
+#include <cstdlib> // std::size_t
+#include <cassert>
+namespace liblas { namespace detail {
+static std::string laszip_userid("laszip encoded");
+static boost::uint16_t laszip_recordid = 22204;
+static std::string laszip_description = "encoded for sequential access";
+ZipPoint::ZipPoint(PointFormatName format) :
m_num_items(0),
m_items(NULL),
m_lz_point(NULL),
m_lz_point_data(NULL),
m_lz_point_size(0)
- ConstructItems(format);
- return;
-ZipPoint::~ZipPoint()
+ ConstructItems(format);
+ return;
+ZipPoint::~ZipPoint()
m_num_items = 0;
delete[] m_items;
m_items = NULL;
delete[] m_lz_point;
delete[] m_lz_point_data;
- return;
-void ZipPoint::ConstructItems(PointFormatName format)
+ return;
+void ZipPoint::ConstructItems(PointFormatName format)
switch (format)
case ePointFormat0:
@@ -143,33 +143,33 @@
m_lz_point[i] = &(m_lz_point_data[point_offset]);
point_offset += m_items[i].size;
- return;
-template<class T>
-static inline boost::uint8_t* PutBytes(boost::uint8_t* p, T d)
- LIBLAS_SWAP_BYTES(d);
- memcpy(p, &d, sizeof(T));
- return p+sizeof(T);
-template<class T>
-static inline boost::uint8_t* GetBytes(boost::uint8_t* p, T& d)
- memcpy(&d, p, sizeof(T));
-void ZipPoint::ConstructVLR(VariableRecord& v) const
More information about the Liblas-commits
