[Liblas-commits] hg: what the OStreamPtr stuff,
add boost-based I/O (under ifdef)
liblas-commits at liblas.org
Thu Jan 6 19:36:03 EST 2011
details: http://hg.liblas.orghg/rev/34a6bf617d88
changeset: 2701:34a6bf617d88
user: Michael P. Gerlek <mpg at flaxen.com>
date: Thu Jan 06 16:35:55 2011 -0800
description:
what the OStreamPtr stuff, add boost-based I/O (under ifdef)
diffstat:
apps/las2las.cpp | 102 ++++++++++++++++++++++++++++++++++++++++--------------
1 files changed, 76 insertions(+), 26 deletions(-)
diffs (195 lines):
diff -r 3ff92de69331 -r 34a6bf617d88 apps/las2las.cpp
--- a/apps/las2las.cpp Thu Jan 06 09:09:54 2011 -0600
+++ b/apps/las2las.cpp Thu Jan 06 16:35:55 2011 -0800
@@ -16,6 +16,14 @@
#include <boost/foreach.hpp>
#include <boost/shared_ptr.hpp>
+//#define USE_BOOST_IO
+#ifdef USE_BOOST_IO
+#include <ostream>
+#include <boost/iostreams/device/file.hpp>
+#include <boost/iostreams/stream.hpp>
+#include <boost/iostreams/stream_buffer.hpp>
+#endif
namespace po = boost::program_options;
using namespace liblas;
@@ -23,26 +31,59 @@
typedef boost::shared_ptr<liblas::Writer> WriterPtr;
typedef boost::shared_ptr<liblas::CoordinateSummary> SummaryPtr;
-typedef boost::shared_ptr<std::ofstream> OStreamPtr;
-WriterPtr start_writer( OStreamPtr strm,
+static std::ostream* FileCreate(std::string const& filename)
+ namespace io = boost::iostreams;
+ io::stream<io::file_sink>* ofs = new io::stream<io::file_sink>();
+ ofs->open(filename.c_str(), std::ios::out | std::ios::binary);
+ if (ofs->is_open() == false) return NULL;
+ return ofs;
+#else
+ std::ofstream* ofs = new std::ofstream();
+ return ofs;
+#endif
+static std::istream* FileOpen(std::string const& filename)
+ io::stream<io::file_source>* ifs = new io::stream<io::file_source>();
+ ifs->open(filename.c_str(), std::ios::in | std::ios::binary);
+ if (ifs->is_open() == false) return NULL;
+ return ifs;
+#else
+ std::ifstream* ifs = new std::ifstream();
+ return ifs;
+#endif
+WriterPtr start_writer( std::ostream*& ofs,
std::string const& output,
liblas::Header const& header)
- if (!liblas::Create(*strm, output.c_str()))
+ ofs = FileCreate(output);
+ if (!ofs)
std::ostringstream oss;
oss << "Cannot create " << output << "for write. Exiting...";
throw std::runtime_error(oss.str());
- WriterPtr writer( new liblas::Writer(*strm, header));
+ WriterPtr writer( new liblas::Writer(*ofs, header));
return writer;
-bool process( std::string const& input,
+bool process( std::istream& ifs,
liblas::Header & header,
std::vector<liblas::FilterPtr>& filters,
@@ -53,12 +94,7 @@
bool min_offset)
- std::ifstream ifs;
- if (!liblas::Open(ifs, input.c_str()))
- std::cerr << "Cannot open " << input << " for read. Exiting..." << std::endl;
- return false;
liblas::ReaderFactory f;
liblas::Reader reader = f.CreateWithStream(ifs);
@@ -99,7 +135,7 @@
reader.Reset();
- OStreamPtr ofs(new std::ofstream);
+ std::ostream* ofs = NULL;
std::string out = output;
WriterPtr writer;
@@ -148,8 +184,10 @@
// dereference the writer so it is deleted before the ofs
writer = WriterPtr();
- ofs = OStreamPtr(new std::ofstream);
+ delete ofs;
+ ofs = NULL;
ostringstream oss;
oss << out << "-"<< fileno <<".las";
@@ -176,8 +214,9 @@
+ delete ofs;
+ ofs = NULL;
ostringstream oss;
@@ -202,9 +241,9 @@
// cheap hackery. We need the Writer to disappear before the stream.
// Fix this up to not suck so bad.
- ofs->close();
- ofs = OStreamPtr();
+ delete ofs;
+ ofs = NULL;
if (!split_mb && !split_pts) {
reader.Reset();
@@ -297,17 +336,20 @@
if (verbose)
std::cout << "Opening " << input << " to fetch Header" << std::endl;
+ std::istream* ifs = FileOpen(input);
+ if (!ifs)
return 1;
// set_ifstream_buffer(ifs, default_buffer_size);
- liblas::ReaderFactory f;
- liblas::Reader reader = f.CreateWithStream(ifs);
- header = reader.GetHeader();
+ {// scope the reader, so it goes away before the stream does
+ liblas::ReaderFactory f;
+ liblas::Reader reader = f.CreateWithStream(*ifs);
+ header = reader.GetHeader();
+ delete ifs;
} else {
std::cerr << "Input LAS file not specified!\n";
OutputHelp(std::cout, options);
@@ -368,7 +410,14 @@
break;
- bool op = process( input,
+ if (!ifs)
+ std::cerr << "Cannot open " << input << " for read. Exiting..." << std::endl;
+ return 1;
+ bool op = process( *ifs,
output,
header,
filters,
@@ -382,6 +431,7 @@
return (1);
+ delete ifs;
catch(std::exception& e)
More information about the Liblas-commits
