[Liblas-commits] hg: default to using reinterpret_cast and assuming
the data are ...
liblas-commits at liblas.org
Fri Jan 7 10:54:13 EST 2011
details: http://hg.liblas.orghg/rev/8034511a1aff
changeset: 2703:8034511a1aff
user: Howard Butler <hobu.inc at gmail.com>
date: Fri Jan 07 09:54:07 2011 -0600
description:
default to using reinterpret_cast and assuming the data are in little endian order instead of using bitsToInt and friends. You can use the other, more proper approach by defining WITH_ENDIANAWARE in your cmake configuration
diffstat:
CMakeLists.txt | 5 ++
src/point.cpp | 117 +++++++++++++++++++++++++++++++++++++++++---------------
2 files changed, 91 insertions(+), 31 deletions(-)
diffs (230 lines):
diff -r b345fa32dc3d -r 8034511a1aff CMakeLists.txt
--- a/CMakeLists.txt Fri Jan 07 09:25:10 2011 -0600
+++ b/CMakeLists.txt Fri Jan 07 09:54:07 2011 -0600
@@ -56,6 +56,8 @@
set(WITH_PKGCONFIG FALSE CACHE BOOL
"Choose whether a pkgconfig file (libLAS.pc) should be installed")
+set(WITH_ENDIANAWARE FALSE CACHE BOOL "Choose whether or not libLAS should do runtime endianness switching. Note that this can slow things down considerably if enabled by default")
# Enable CTest and submissions to libLAS dashboard at CDash
# http://my.cdash.org/index.php?project=libLAS
set(ENABLE_CTEST FALSE CACHE BOOL
@@ -306,6 +308,9 @@
endif()
endif()
+if(WITH_ENDIANAWARE)
+ add_definitions(-DLIBLAS_ENDIAN_AWARE=1)
+endif()
# Installation settings
diff -r b345fa32dc3d -r 8034511a1aff src/point.cpp
--- a/src/point.cpp Fri Jan 07 09:25:10 2011 -0600
+++ b/src/point.cpp Fri Jan 07 09:54:07 2011 -0600
@@ -479,9 +479,15 @@
// std::vector<boost::uint8_t>::size_type pos = GetDimensionPosition("X");
// std::vector<boost::uint8_t>::size_type pos = GetDimensionBytePosition(0);
std::vector<boost::uint8_t>::size_type pos = 0;
+#ifdef LIBLAS_ENDIAN_AWARE
boost::int32_t output = liblas::detail::bitsToInt<boost::int32_t>(output, m_data, pos);
- return output;
+ return output
+#else
+ boost::uint8_t* data = const_cast<boost::uint8_t*>(&m_data[0] + pos);
+ boost::int32_t* output = reinterpret_cast<boost::int32_t*>(data);
+ return *output;
+#endif
boost::int32_t Point::GetRawY() const
@@ -489,20 +495,31 @@
// std::vector<boost::uint8_t>::size_type pos = GetDimensionPosition("Y");
// std::vector<boost::uint8_t>::size_type pos = GetDimensionBytePosition(1);
std::vector<boost::uint8_t>::size_type pos = 4;
- return output;
+ return output
+#else
+ return *output;
+#endif
boost::int32_t Point::GetRawZ() const
- boost::int32_t output;
// std::vector<boost::uint8_t>::size_type pos = GetDimensionPosition("Z");
// std::vector<boost::uint8_t>::size_type pos = GetDimensionBytePosition(2);
std::vector<boost::uint8_t>::size_type pos = 8;
- output = liblas::detail::bitsToInt<boost::int32_t>(output, m_data, pos);
- return output;
+ boost::int32_t output = liblas::detail::bitsToInt<boost::int32_t>(output, m_data, pos);
+ return output
+#else
+ return *output;
+#endif
void Point::SetRawX( boost::int32_t const& value)
@@ -533,12 +550,17 @@
// Intensity's position is always the 4th dimension
// std::vector<boost::uint8_t>::size_type pos = GetDimensionBytePosition(3);
- std::vector<boost::uint8_t>::size_type pos = 12;
- boost::uint16_t output =
- liblas::detail::bitsToInt<boost::uint16_t>(
- output, m_data, pos);
+ std::vector<boost::uint8_t>::size_type pos = 12;
- return output;
+ boost::uint16_t output = liblas::detail::bitsToInt<boost::int32_t>(output, m_data, pos);
+ return output
+#else
+ boost::uint16_t* output = reinterpret_cast<boost::uint16_t*>(data);
+ return *output;
+#endif
@@ -753,17 +775,20 @@
boost::uint16_t Point::GetPointSourceID() const
- boost::uint16_t output;
// "Point Source ID" is always the 12th dimension
// std::vector<boost::uint8_t>::size_type pos = GetDimensionBytePosition(11);
std::vector<boost::uint8_t>::size_type pos = 18;
- output = liblas::detail::bitsToInt<boost::uint16_t>(output,
- m_data,
- pos);
- return output;
+ return output
+#else
+ return *output;
+#endif
void Point::SetPointSourceID(boost::uint16_t const& id)
@@ -795,7 +820,7 @@
// std::vector<boost::uint8_t>::size_type pos = GetDimensionBytePosition(index_pos);
- std::vector<boost::uint8_t>::size_type pos = 20;
+ std::vector<boost::uint8_t>::size_type pos = 20;
detail::binary::endian_value<double> value(t);
value.store<detail::binary::little_endian_tag>(&m_data[0] + pos);
@@ -825,22 +850,29 @@
// std::size_t const index_pos = 12;
- detail::binary::endian_value<double> value;
- value.load<detail::binary::little_endian_tag>(&m_data[0] + pos);
- return value;
+ detail::binary::endian_value<double> output;
+ output.load<detail::binary::little_endian_tag>(&m_data[0] + pos);
+ return output;
+#else
+ double* output = reinterpret_cast<double*>(data);
+ return *output;
+#endif
Color Point::GetColor() const
- boost::uint16_t red(0);
- boost::uint16_t green(0);
- boost::uint16_t blue(0);
// "Color" starts at the 14th dimension if it exists
// std::size_t index_pos = 13;
+ Color color;
PointFormatName f;
if (m_header) {
f = m_header->GetDataFormatId();
} else {
@@ -848,12 +880,11 @@
if ( f == ePointFormat0 || f == ePointFormat1 ) {
- return Color(0, 0, 0);
+ return color;
assert(!(f == ePointFormat0 || f == ePointFormat1));
- using liblas::detail::bitsToInt;
std::size_t index_pos = 20;
@@ -869,12 +900,36 @@
assert(red_pos <= m_data.size());
assert(blue_pos <= m_data.size());
assert(green_pos <= m_data.size());
+ using liblas::detail::bitsToInt;
+ boost::uint16_t red(0);
+ boost::uint16_t green(0);
+ boost::uint16_t blue(0);
red = bitsToInt<boost::uint16_t>(red, m_data, red_pos);
green = bitsToInt<boost::uint16_t>(green, m_data, green_pos);
blue = bitsToInt<boost::uint16_t>(blue, m_data, blue_pos);
+ color[0] = red;
+ color[1] = green;
+ color[2] = blue;
+#else
+ boost::uint8_t* red_data = const_cast<boost::uint8_t*>(&m_data[0] + red_pos);
+ boost::uint16_t* p_red = reinterpret_cast<boost::uint16_t*>(red_data);
- return Color(red, green, blue);
+ boost::uint8_t* green_data = const_cast<boost::uint8_t*>(&m_data[0] + green_pos);
+ boost::uint16_t* p_green = reinterpret_cast<boost::uint16_t*>(green_data);
+ boost::uint8_t* blue_data = const_cast<boost::uint8_t*>(&m_data[0] + blue_pos);
+ boost::uint16_t* p_blue = reinterpret_cast<boost::uint16_t*>(blue_data);
+ color[0] = *p_red;
+ color[1] = *p_green;
+ color[2] = *p_blue;
+#endif
+ return color;
void Point::SetColor(Color const& value)
More information about the Liblas-commits
