[Liblas-commits] laszip: update ChangeLog
liblas-commits at liblas.org
Fri Jan 7 14:59:03 EST 2011
details: http://hg.liblas.orglaszip/rev/618fc13a15a4
changeset: 125:618fc13a15a4
user: Howard Butler <hobu.inc at gmail.com>
date: Fri Jan 07 13:56:34 2011 -0600
description:
update ChangeLog
Subject: laszip: packaging
details: http://hg.liblas.orglaszip/rev/d057f0b36994
changeset: 126:d057f0b36994
date: Fri Jan 07 13:58:53 2011 -0600
description:
packaging
diffstat:
CMakeLists.txt | 17 +-
ChangeLog | 1057 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++
2 files changed, 1067 insertions(+), 7 deletions(-)
diffs (truncated from 1097 to 300 lines):
diff -r 7ff2569cc64a -r d057f0b36994 CMakeLists.txt
--- a/CMakeLists.txt Fri Jan 07 09:45:52 2011 -0800
+++ b/CMakeLists.txt Fri Jan 07 13:58:53 2011 -0600
@@ -127,22 +127,25 @@
SET(CPACK_PACKAGE_VERSION_PATCH ${LASZIP_VERSION_MINOR})
SET(OSGEO4W_UPSTREAM_RELEASE "1")
-SET(CPACK_SOURCE_GENERATOR "TGZ;ZIP;TBZ2")
+SET(CPACK_SOURCE_GENERATOR "TGZ;ZIP")
SET(CPACK_CMAKE_GENERATOR "Unix Makefiles")
-SET(CPACK_RESOURCE_FILE_LICENSE "${laszip_SOURCE_DIR}/COPYING")
+#SET(CPACK_RESOURCE_FILE_LICENSE "${laszip_SOURCE_DIR}/COPYING")
set(CPACK_SOURCE_PACKAGE_FILE_NAME
"${CMAKE_PROJECT_NAME}-${VERSION}")
list(APPEND CPACK_SOURCE_IGNORE_FILES "_CPack_Packages")
list(APPEND CPACK_SOURCE_IGNORE_FILES ".gz")
-list(APPEND CPACK_SOURCE_IGNORE_FILES ".bz2")
-list(APPEND CPACK_SOURCE_IGNORE_FILES ".zip")
+list(APPEND CPACK_SOURCE_IGNORE_FILES "CMakeFiles")
+list(APPEND CPACK_SOURCE_IGNORE_FILES "bin")
+list(APPEND CPACK_SOURCE_IGNORE_FILES "hobu-config.bat")
+# list(APPEND CPACK_SOURCE_IGNORE_FILES ".bz2")
+# list(APPEND CPACK_SOURCE_IGNORE_FILES ".zip")
list(APPEND CPACK_SOURCE_IGNORE_FILES ".hg")
list(APPEND CPACK_SOURCE_IGNORE_FILES "CMakeCache.txt")
-list(APPEND CPACK_SOURCE_IGNORE_FILES "CPackConfig.cmake")
+# list(APPEND CPACK_SOURCE_IGNORE_FILES "CPackConfig.cmake")
include(CPack)
diff -r 7ff2569cc64a -r d057f0b36994 ChangeLog
--- a/ChangeLog Fri Jan 07 09:45:52 2011 -0800
+++ b/ChangeLog Fri Jan 07 13:58:53 2011 -0600
@@ -0,0 +1,1057 @@
+2011-01-07 isenburg <isenburg>
+ * src/mydefs.hpp:
+ more efficient big endian handling
+ [7ff2569cc64a] [tip]
+ * src/lasreaditemraw.hpp, src/lasreadpoint.cpp,
+ src/laswriteitemraw.hpp, src/laswritepoint.cpp:
+ [7ae269f43dde]
+2011-01-07 Howard Butler <hobu.inc at gmail.com>
+ * CMakeLists.txt:
+ turn off osgeo4w building by default
+ [c544849de62f]
+2011-01-06 Michael P. Gerlek <mpg at flaxen.com>
+ * src/lasunzipper.cpp, src/laszipper.cpp:
+ do need to delete martin's stream (but not ours)
+ [71658514f280]
+2011-01-06 isenburg <isenburg>
+ * src/lasreaditemraw.hpp, src/laswriteitemraw.hpp:
+ for testing if extra freads/fwrites affect performance
+ [a8ad11ceb54b]
+2011-01-06 Howard Butler <hobu.inc at gmail.com>
+ * include/laszip/lasunzipper.hpp:
+ export LASunzipper too
+ [89e9ea2f8f7c]
+2011-01-05 Howard Butler <hobu.inc at gmail.com>
+ * src/CMakeLists.txt:
+ add install_name for OSX
+ [880013a5e96a]
+ * include/laszip/export.hpp, include/laszip/laszip.hpp,
+ include/laszip/laszipper.hpp:
+ put LASZIP_DLL back. Martin, please let me know your error
+ message(s) instead of removing this as I need it for the OSGeo4W
+ windows deployment
+ [057be33cd6db]
+2011-01-05 isenburg <isenburg>
+ * tools/laszippertest.cpp:
+ forgot to copy & commit
+ [daac63e565cf]
+2011-01-04 isenburg <isenburg>
+ * src/bytestreamin.hpp, src/bytestreamin_file.hpp,
+ src/bytestreamin_istream.hpp, src/bytestreamout.hpp,
+ src/bytestreamout_file.hpp, src/bytestreamout_ostream.hpp,
+ src/lasreaditemcompressed_v1.cpp, src/lasreaditemcompressed_v1.hpp,
+ src/lasreaditemraw.hpp, src/lasreadpoint.cpp, src/lasreadpoint.hpp,
+ src/lasunzipper.cpp, src/laswriteitemcompressed_v1.cpp,
+ src/laswriteitemcompressed_v1.hpp, src/laswriteitemraw.hpp,
+ src/laswritepoint.cpp, src/laswritepoint.hpp, src/laszip.cpp,
+ src/laszipper.cpp, src/rangemodel.cpp:
+ improved endianness again, renamed compression to algorithm,
+ improved wavepacket13 compressor
+ [dcd14845f9ed]
+ * include/laszip/lasunzipper.hpp, include/laszip/laszip.hpp,
+ mpg: the LAS_ZIP_DLL does not work with my code. can you ifdef it?
+ [a8aa0185aa63]
+2011-01-04 Howard Butler <hobu.inc at gmail.com>
+ * .hgignore:
+ add a few more ignores
+ [473e998d2955]
+ * cmake/modules/BuildOSGeo4W.cmake:
+ simplify to a single package install for osgeo4w
+ [14af050db188]
+2011-01-03 Howard Butler <hobu.inc at gmail.com>
+ * CMakeLists.txt, cmake/modules/BuildOSGeo4W.cmake:
+ fix osgeo4w dependency and add OSGEO4W_UPSTREAM_RELEASE usage
+ [6cfec438cea3]
+ osgeo4w packaging
+ [bb381252df0d]
+ add osgeo4w packaging script
+ [5702cc183fe5]
+ * tools/CMakeLists.txt, tools/laszip-config.in, tools/laszip.pc.in:
+ add laszip-config and laszip.pc packageconfig
+ [5ea850338ed1]
+ * include/laszip/Makefile.am:
+ bring in line with cmake setup
+ [03aa58b60bf5]
+ * configure.ac:
+ [0a245357c2cd]
+ * .hgignore:
+ ignore .lax test files and change location of laszip-config and
+ laszip.pc package config files
+ [3075e12e3a47]
+ * CMakeLists.txt, src/CMakeLists.txt:
+ add packaging and soname for dll
+ [43aa7323c711]
+ * laszip-config.in, tools/CMakeLists.txt, tools/laszip-config.in:
+ add a laszip-config target
+ [d48a54cc320b]
+ * .hgignore:
+ [f3729328ee77]
+ * src/CMakeLists.txt, src/lasreaditemrawendianswapped.hpp,
+ src/laswriteitemrawendianswapped.hpp:
+ these files are not used anymore according to Martin
+ [25aa62883097]
+2010-12-30 Howard Butler <hobu.inc at gmail.com>
+ * hobu-config.bat:
+ add my base config
+ [8fe8b5444dcf]
+ * src/CMakeLists.txt, tools/CMakeLists.txt:
+ export the laszip dll items
+ [799d195fe864]
+ fix install target to LASZIP_LIB_DIR instead of _BIN, build shared
+ library by default
+ [f30dd5b85cdc]
+ * include/laszip/export.hpp, include/laszip/lasunzipper.hpp,
+ include/laszip/laszip.hpp, include/laszip/laszipper.hpp,
+ src/CMakeLists.txt:
+ start adding LASZIP_DLL exports definition in preparation for shared
+ library build/install/usage
+ [724ec4f2a7de]
+ * CMakeLists.txt:
+ add logic or setting CMAKE_BUILD_TYPE to Debug by default if not set
+ and not in the cache
+ [35628e849688]
+ add some missing header files
+ [adc903683a4b]
+2010-12-27 Michael P. Gerlek <mpg at flaxen.com>
+ * include/laszip/lasunzipper.hpp, include/laszip/laszipper.hpp:
+ explicit default param no longer needed
+ [16cbedc7335f]
+ include/laszip/laszipper.hpp, src/lasreadpoint.cpp,
+ src/lasreadpoint.hpp, src/lasunzipper.cpp, src/laswritepoint.cpp,
+ src/laswritepoint.hpp, src/laszipper.cpp, tools/laszippertest.cpp:
+ use an enum for the compression type, for type safety
+ [276b21e82629]
+ fix err checks on open()
+ [ce1bdb2a9e26]
+ * src/bytestreamin_file.hpp, src/bytestreamin_istream.hpp:
+ remove fprintf calls
+ [ba16595e644c]
+ * src/rangemodel.cpp:
+ remove calls to fprintf, exit
+ [7af78ceb3bfa]
+2010-12-23 isenburg <isenburg>
+ * src/lasreaditemcompressed_v1.cpp, src/lasreaditemcompressed_v1.hpp,
+ src/laswriteitemcompressed_v1.cpp,
+ src/laswriteitemcompressed_v1.hpp:
+ one last optimization to compress 1.5 percent better
+ [e815143ce051]
+ src/lasreadpoint.cpp, src/laswriteitemcompressed_v1.cpp,
+ fix of pointreader and small optimization of POINT10 compressor
+ [113c76a6708b]
+ added test for new WAVEPACKET13 compressor
+ [294dfaf3b0d3]
+ [30313ba06a38]
+ * src/arithmeticdecoder.cpp, src/arithmeticencoder.cpp,
+ src/laswriteitemcompressed_v1.hpp, src/laswritepoint.cpp:
+ updated RGB encoding to be endian neutral
+ [7770fdf9c7c2]
+2010-12-22 Michael P. Gerlek <mpg at flaxen.com>
+ * src/laszip.cpp:
+ sync up w/ Martin's versioning
+ [4daf73355dc6]
+ * src/lasreadpoint.cpp:
+ memleak
+ [aabe8bc36fb0]
+ * include/laszip/laszip.hpp, src/CMakeLists.txt, src/Makefile.am,
+ src/lasunzipper.cpp, src/laszip.cpp, src/laszipper.cpp:
+ move header functions into .cpp file
+ [b939bfb7bdf7]
+ sync w/ Martin's changes
+ [e8f5528c3d30]
+ * include/laszip/lasunzipper.hpp, include/laszip/laszipper.hpp,
+ src/lasunzipper.cpp, src/laszipper.cpp:
+ pull-merge
+ [e651d0722c7e]
+ src/bytestreamin_istream.hpp, src/bytestreamout_ostream.hpp,
+ src/lasunzipper.cpp, src/laszipper.cpp, tools/laszippertest.cpp:
+ pass streams by ref, not as pointers; return status code on open,
+ not bool; declare items parameter as an array
+ [3e5e0ec93ea6]
+2010-12-21 isenburg <isenburg>
+ src/laswritepoint.cpp:
+ renaming to GPSTIME11, RGB12, and WAVEPACKET13
+ [68e267d04b63]
+ * include/laszip/laszip.hpp:
+ added LASzip struct to be used as VLR data
More information about the Liblas-commits
