[Liblas-commits] hg: 1.6.0b4 release location
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Jan 7 16:00:34 EST 2011
details:   http://hg.liblas.orghg/rev/4f209b4db0aa
changeset: 2709:4f209b4db0aa
user:      Howard Butler <hobu.inc at gmail.com>
date:      Fri Jan 07 15:00:24 2011 -0600
description:
diffstat:
 doc/download.txt |  48 ++++++++++++++++++++++++++++++++----------------
 1 files changed, 32 insertions(+), 16 deletions(-)
diffs (66 lines):
diff -r b0ed35f7bd07 -r 4f209b4db0aa doc/download.txt
--- a/doc/download.txt	Fri Jan 07 14:36:23 2011 -0600
+++ b/doc/download.txt	Fri Jan 07 15:00:24 2011 -0600
@@ -10,6 +10,38 @@
 * **2010-12-15**
+  - `libLAS-1.6.0b4-src.tar.gz`_
+    `(md5) <http://download.osgeo.org/liblas/libLAS-1.6.0b4.tar.gz.md5>`__
+  - `libLAS-1.6.0b4-src.zip <http://download.osgeo.org/liblas/libLAS-1.6.0b4.zip>`_
+    `(md5) <http://download.osgeo.org/liblas/libLAS-1.6.0b4.zip.md5>`__
+  - See `OSGeo4W <http://trac.osgeo.org/osgeo4w>`__ for Windows release.
+  - `Release Notes <http://lists.osgeo.org/pipermail/liblas-devel/2010-December/001108.html>`__
+.. note::
+    You may also want :ref:`laszip` for compression support.
+.. seealso::
+    :ref:`source`
+.. seealso::
+    A `sample library <http://liblas.org/samples>`__ is also available to provide
+    data to test your tools.
+.. seealso::
+    See :ref:`start` for information
+    how to get started using the tools once they are installed.
+Past Releases
+* **2010-12-15**
   - `libLAS-1.6.0b3-src.tar.gz`_
     `(md5) <http://download.osgeo.org/liblas/libLAS-1.6.0b3.tar.gz.md5>`__
@@ -22,23 +54,6 @@
 .. _`libLAS-1.6.0b3-src.tar.gz`: http://download.osgeo.org/liblas/libLAS-1.6.0b3.tar.gz
-.. note::
-    You may also want :ref:`laszip` for compression support.
-.. seealso::
-    :ref:`source`
-.. seealso::
-    A `sample library <http://liblas.org/samples>`__ is also available to provide
-    data to test your tools.
-.. seealso::
-    See :ref:`start` for information
-    how to get started using the tools once they are installed.
-Past Releases
 * **2010-11-05**
More information about the Liblas-commits mailing list
