[Liblas-commits] hg: remove unused variable
liblas-commits at liblas.org
Tue Jan 11 11:55:56 EST 2011
details: http://hg.liblas.orghg/rev/361da5835f89
changeset: 2722:361da5835f89
user: Howard Butler <hobu.inc at gmail.com>
date: Tue Jan 11 10:50:24 2011 -0600
description:
Subject: hg: add filtering to ts2las
details: http://hg.liblas.orghg/rev/2dd81ebc17b3
changeset: 2723:2dd81ebc17b3
date: Tue Jan 11 10:55:37 2011 -0600
description:
diffstat:
apps/ts2las.cpp | 18 ++++++++++++++----
1 files changed, 14 insertions(+), 4 deletions(-)
diffs (53 lines):
diff -r 47ff872c9d5b -r 2dd81ebc17b3 apps/ts2las.cpp
--- a/apps/ts2las.cpp Tue Jan 11 10:49:21 2011 -0600
+++ b/apps/ts2las.cpp Tue Jan 11 10:55:37 2011 -0600
@@ -289,12 +289,11 @@
int main(int argc, char* argv[])
- int rc = 0;
std::string input;
std::string output;
bool verbose = false;
+ std::vector<liblas::FilterPtr> filters;
po::options_description ts2las_options("ts2las options");
po::options_description filtering_options = GetFilteringOptions();
po::positional_options_description p;
@@ -324,7 +323,16 @@
return 1;
+ if (input.empty())
+ std::cerr << "No input TerraSolid .bin file was specfied!" << std::endl;
+ OutputHelp(std::cout, options);
+ return 1;
+ filters = GetFilters(vm, verbose);
if (verbose)
std::cout << "input: " << input<< " output: " <<output<<std::endl;
@@ -334,7 +342,7 @@
bool opened = liblas::Open(istrm, input);
if (!opened)
- std::cerr << "Could not open file " << input << " to read TerraSolid .bin data! " << std::endl;
+ std::cerr << "Could not open file '" << input << "' to read TerraSolid .bin data! " << std::endl;
return 1;
@@ -358,6 +366,8 @@
liblas::Header header = CreateHeader(hdr, verbose);
liblas::Writer writer(ostrm, header);
+ writer.SetFilters(filters);
success = WritePoints(writer, istrm, hdr, verbose);
if (verbose)
More information about the Liblas-commits
