[Liblas-commits] laszip: put rangecoder tests under #ifdef
liblas-commits at liblas.org
Wed Jan 12 12:23:43 EST 2011
details: http://hg.liblas.orglaszip/rev/53f5dbd25856
changeset: 137:53f5dbd25856
user: Michael P. Gerlek <mpg at flaxen.com>
date: Wed Jan 12 09:23:39 2011 -0800
description:
diffstat:
tools/laszippertest.cpp | 45 ++++++++++++++++++++++++++++++++++++---------
1 files changed, 36 insertions(+), 9 deletions(-)
diffs (159 lines):
diff -r c8a501a14035 -r 53f5dbd25856 tools/laszippertest.cpp
--- a/tools/laszippertest.cpp Wed Jan 12 10:37:22 2011 -0600
+++ b/tools/laszippertest.cpp Wed Jan 12 09:23:39 2011 -0800
@@ -142,7 +142,10 @@
LASzipper* laszipper1 = new LASzipper(); // without compression
LASzipper* laszipper2 = new LASzipper(); // with arithmetic compression
- LASzipper* laszipper3 = new LASzipper(); // with range compression
+ LASzipper* laszipper3 = NULL;
+#ifdef LASZIP_HAVE_RANGECODER
+ laszipper3 = new LASzipper(); // with range compression
+#endif
if (use_iostream)
@@ -174,6 +177,7 @@
return 0;
#ifdef LZ_WIN32_VC6
ofb3.open("test3.lax", ios::out);
ofb3.setmode(filebuf::binary);
@@ -187,6 +191,9 @@
fprintf(stderr, "ERROR: could not open laszipper3\n");
return 0;
+#else
+ fprintf(stderr, "(skipping range coder test)\n");
+#endif
else
@@ -204,12 +211,16 @@
return 0;
ofile3 = fopen("test3.lax", "wb");
if (laszipper3->open(ofile3, num_items, items, LASzip::POINT_BY_POINT_RANGE) != 0)
return 0;
+#else
+#endif
// write / compress num_points with "random" data
@@ -244,6 +255,7 @@
end_time = taketime();
fprintf(stderr, "laszipper2 wrote %d bytes in %g seconds\n", num_bytes, end_time-start_time);
start_time = taketime();
c = 0;
for (i = 0; i < num_points; i++)
@@ -258,11 +270,11 @@
num_bytes = laszipper3->close();
fprintf(stderr, "laszipper3 wrote %d bytes in %g seconds\n", num_bytes, end_time-start_time);
+#endif
delete laszipper1;
delete laszipper2;
delete laszipper3;
if (use_iostream)
delete ostream1;
@@ -276,14 +288,20 @@
else
- fclose(ofile1);
- fclose(ofile2);
- fclose(ofile3);
+ if (ofile1)
+ fclose(ofile1);
+ if (ofile2)
+ fclose(ofile2);
+ if (ofile3)
+ fclose(ofile3);
LASunzipper* lasunzipper1 = new LASunzipper(); // without compression
LASunzipper* lasunzipper2 = new LASunzipper(); // with arithmetic compression
- LASunzipper* lasunzipper3 = new LASunzipper(); // with range compression
+ LASunzipper* lasunzipper3 = NULL;
+ lasunzipper3 = new LASunzipper(); // with range compression
+#endif
if (use_iostream)
@@ -313,6 +331,7 @@
fprintf(stderr, "ERROR: could not open lasunzipper2\n");
return 0;
#ifdef LZ_WIN32_VC6
ifb3.open("test3.lax", ios::in);
ifb3.setmode(filebuf::binary);
@@ -326,6 +345,7 @@
fprintf(stderr, "ERROR: could not open lasunzipper3\n");
return 0;
+#endif
else
@@ -341,12 +361,14 @@
return 0;
ifile3 = fopen("test3.lax", "rb");
if (lasunzipper3->open(ifile3, num_items, items, LASzip::POINT_BY_POINT_RANGE) != 0)
return 0;
+#endif
// read num_points with "random" data
@@ -411,6 +433,7 @@
// decompress num_points with "random" data
num_errors = 0;
c = 0;
@@ -438,6 +461,7 @@
fprintf(stderr, "SUCCESS: lasunzipper3 read %d bytes in %g seconds\n", num_bytes, end_time-start_time);
+#endif
delete lasunzipper1;
delete lasunzipper2;
@@ -456,9 +480,12 @@
else
- fclose(ifile1);
- fclose(ifile2);
- fclose(ifile3);
+ if (ifile1)
+ fclose(ifile1);
+ if (ifile2)
+ fclose(ifile2);
+ if (ifile3)
+ fclose(ifile3);
return 0;
More information about the Liblas-commits
