[Liblas-commits] laszip: refactor to remove triplicated code paths
liblas-commits at liblas.org
Thu Jan 13 14:21:14 EST 2011
details: http://hg.liblas.orglaszip/rev/d2d8b98c7960
changeset: 144:d2d8b98c7960
user: Michael P. Gerlek <mpg at flaxen.com>
date: Thu Jan 13 10:51:08 2011 -0800
description:
Subject: laszip: consolidate still more, so can add infinite loop
details: http://hg.liblas.orglaszip/rev/e3ff0a074d82
changeset: 145:e3ff0a074d82
date: Thu Jan 13 11:20:44 2011 -0800
description:
diffstat:
tools/laszippertest.cpp | 774 ++++++++++++++++++++++-------------------------
1 files changed, 356 insertions(+), 418 deletions(-)
diffs (truncated from 794 to 300 lines):
diff -r d464a9150b13 -r e3ff0a074d82 tools/laszippertest.cpp
--- a/tools/laszippertest.cpp Wed Jan 12 13:55:19 2011 -0800
+++ b/tools/laszippertest.cpp Thu Jan 13 11:20:44 2011 -0800
@@ -59,434 +59,372 @@
#include <time.h>
#include <stdio.h>
+//#define LASZIP_HAVE_RANGECODER
static double taketime()
return (double)(clock())/CLOCKS_PER_SEC;
+// abstractions for doing I/O, which support VC6 streams, modern streams, and FILE*
+struct OStream
+public:
+ OStream(bool use_iostream, const char* filename) :
+ m_use_iostream(use_iostream),
+ m_filename(filename),
+ ofile(NULL),
+ ostream(NULL)
+ if (m_use_iostream)
+#ifdef LZ_WIN32_VC6
+ ofb.open(filename, ios::out);
+ ofb.setmode(filebuf::binary);
+ ostream = new ostream(&ofb);
+#else
+ ostream = new ofstream();
+ ostream->open(filename, std::ios::out | std::ios::binary );
+#endif
+ else
+ ofile = fopen(filename, "wb");
+ return;
+ ~OStream()
+ delete ostream;
+ ofb.close();
+#endif
+ else
+ if (ofile)
+ fclose(ofile);
+public:
+ bool m_use_iostream;
+ const char* m_filename;
+ FILE* ofile;
+ filebuf ofb;
+ ostream* ostream;
+#else
+ ofstream* ostream;
+#endif
+struct IStream
+public:
+ IStream(bool use_iostream, const char* filename) :
+ ifile(NULL),
+ istream(NULL)
+ ifb.open(filename, ios::in);
+ ifb.setmode(filebuf::binary);
+ istream = new istream(&ifb);
+#else
+ istream = new ifstream();
+ istream->open(filename, std::ios::in | std::ios::binary );
+#endif
+ else
+ ifile = fopen(filename, "rb");
+ ~IStream()
+ delete istream;
+ ifb.close();
+#endif
+ else
+ if (ifile)
+ fclose(ifile);
+public:
+ FILE* ifile;
+ filebuf ifb;
+ istream* istream;
+#else
+ ifstream* istream;
+#endif
+class Data
+public:
+ Data(unsigned int num_pts, bool random) :
+ num_points(num_pts),
+ use_random(random)
+ items[0].type = LASitem::POINT10;
+ items[0].size = 20;
+ items[0].version = 0;
+ items[1].type = LASitem::GPSTIME11;
+ items[1].size = 8;
+ items[1].version = 0;
+ items[2].type = LASitem::RGB12;
+ items[2].size = 6;
+ items[2].version = 0;
+ items[3].type = LASitem::WAVEPACKET13;
+ items[3].size = 29;
+ items[3].version = 0;
+ items[4].type = LASitem::BYTE;
+ items[4].size = 7;
+ items[4].version = 0;
+ unsigned int i;
+ // compute the point size
+ point_size = 0;
+ for (i = 0; i < num_items; i++) point_size += items[i].size;
+ // create the point data
+ unsigned int point_offset = 0;
+ point = new unsigned char*[num_items];
+ point_data = new unsigned char[point_size];
+ point[i] = &(point_data[point_offset]);
+ point_offset += items[i].size;
+ return;
+ ~Data()
+ delete[] point;
+ delete[] point_data;
+ return;
+ static const unsigned int num_items = 5;
+ LASitem items[num_items];
+ unsigned int point_size;
+ unsigned char* point_data;
+ unsigned char** point;
+ unsigned num_points;
+ bool use_random;
+static LASzipper* make_zipper(OStream* ost, Data& data, LASzip::Algorithm alg)
+#ifndef LASZIP_HAVE_RANGECODER
+ if (alg == LASzip::POINT_BY_POINT_RANGE)
+ fprintf(stderr, "(skipping range encoder test)\n");
+ return NULL;
+#endif
+ LASzipper* zipper = new LASzipper();
+ int stat = 0;
+ if (ost->m_use_iostream)
+ stat = zipper->open(*ost->ostream, data.num_items, data.items, alg);
+ else
+ stat = zipper->open(ost->ofile, data.num_items, data.items, alg);
+ if (stat != 0)
+ fprintf(stderr, "ERROR: could not open laszipper with %s\n", ost->m_filename);
+ exit(1);
+ return zipper;
+static LASunzipper* make_unzipper(IStream* ist, Data& data, LASzip::Algorithm alg)
+ return NULL;
+#endif
+ LASunzipper* unzipper = new LASunzipper();
+ int stat = 0;
+ if (ist->m_use_iostream)
+ stat = unzipper->open(*ist->istream, data.num_items, data.items, alg);
+ else
+ stat = unzipper->open(ist->ifile, data.num_items, data.items, alg);
+ if (stat != 0)
+ fprintf(stderr, "ERROR: could not open lasunzipper with %s\n", ist->m_filename);
+ exit(1);
+ return unzipper;
+static void write_points(LASzipper* zipper, Data& data)
+ if (zipper==NULL) // range coder test
+ return;
+ double start_time, end_time;
+ unsigned char c;
+ unsigned int i,j;
+ start_time = taketime();
+ c = 0;
+ for (i = 0; i < data.num_points; i++)
+ for (j = 0; j < data.point_size; j++)
+ data.point_data[j] = c;
+ c++;
+ zipper->write(data.point);
+ unsigned int num_bytes = zipper->close();
+ end_time = taketime();
+ fprintf(stderr, "laszipper wrote %d bytes in %g seconds\n", num_bytes, end_time-start_time);
+ return;
+static void read_points(LASunzipper* unzipper, Data& data)
+ if (unzipper==NULL) // range coder test
+ return;
+ unsigned char c;
+ unsigned int i,j;
+ unsigned int num_errors, num_bytes;
More information about the Liblas-commits
