[Liblas-commits] hg: Trying to get support for compression in C API.
liblas-commits at liblas.org
Thu Jan 13 15:08:36 EST 2011
details: http://hg.liblas.orghg/rev/be743211cab9
changeset: 2752:be743211cab9
user: William Angley <angley_william at bah.com>
date: Thu Jan 13 12:04:34 2011 -0500
description:
Subject: hg: Updated C API implementation file to expose Header::Compressed and Header::SetCompressed.
details: http://hg.liblas.orghg/rev/1b45ba8eaed7
changeset: 2753:1b45ba8eaed7
date: Thu Jan 13 12:35:13 2011 -0500
description:
Subject: hg: Updating the Python API to expose the new C API for compression control.
details: http://hg.liblas.orghg/rev/026b287f49b9
changeset: 2754:026b287f49b9
date: Thu Jan 13 12:46:11 2011 -0500
description:
Subject: hg: Exposing header compression settings as a property in the Python API.
details: http://hg.liblas.orghg/rev/ceb37b6e5fd8
changeset: 2755:ceb37b6e5fd8
date: Thu Jan 13 12:49:04 2011 -0500
description:
Subject: hg: Simplified LASHeader_Compressed by removing an unneeded assignment.
details: http://hg.liblas.orghg/rev/103d6d89dad0
changeset: 2756:103d6d89dad0
date: Thu Jan 13 13:03:07 2011 -0500
description:
Subject: hg: Fixed an error in ctypes value checking that caused python to crash.
details: http://hg.liblas.orghg/rev/35200958a1da
changeset: 2757:35200958a1da
date: Thu Jan 13 13:05:15 2011 -0500
description:
Subject: hg: Tweaked LASHeader_SetCompressed to bring it more in-line with other setters exposed through the C API.
details: http://hg.liblas.orghg/rev/ac9870dd6cca
changeset: 2758:ac9870dd6cca
date: Thu Jan 13 13:06:18 2011 -0500
description:
Subject: hg: Added the option to oci2las.py to generate compressed output.
details: http://hg.liblas.orghg/rev/29581fdc442b
changeset: 2759:29581fdc442b
date: Thu Jan 13 13:42:37 2011 -0500
description:
Subject: hg: Automated merge with http://hg.liblas.org/main
details: http://hg.liblas.orghg/rev/700fd86f446a
changeset: 2760:700fd86f446a
date: Thu Jan 13 15:07:46 2011 -0500
description:
diffstat:
csharp-new/liblas_swig_cpp/liblas.i | 86 ++++++++++++-
csharp-new/liblas_swig_cpp/liblas_swig_cpp.vcxproj | 14 +-
csharp-new/liblas_swig_test/Program.cs | 132 +++++++++++---------
csharp-new/liblas_swig_test/TestHeader.cs | 2 +-
csharp-new/liblas_swig_test/TestVariableRecord.cs | 3 +-
include/liblas/capi/liblas.h | 12 +
python/liblas/core.py | 8 +
python/liblas/header.py | 15 ++
python/scripts/oci2las.py | 7 +-
src/c_api.cpp | 22 +++
10 files changed, 225 insertions(+), 76 deletions(-)
diffs (truncated from 601 to 300 lines):
diff -r f21cf1799b09 -r 700fd86f446a csharp-new/liblas_swig_cpp/liblas.i
--- a/csharp-new/liblas_swig_cpp/liblas.i Thu Jan 13 10:20:53 2011 -0600
+++ b/csharp-new/liblas_swig_cpp/liblas.i Thu Jan 13 15:07:46 2011 -0500
@@ -83,9 +83,12 @@
typedef signed int int32_t;
+// BUG: how do I do a rename such that "SWIGTYPE_p_std__istream" can
+// become something like "IStreamHandle"?
namespace liblas
+typedef Header HeaderPtr;
@@ -107,6 +110,7 @@
public:
guid(char const* const str);
+ ~guid();
std::string to_string() const;
@@ -141,7 +145,18 @@
class Point
public:
- enum ClassificationType
+ enum DataMemberFlag
+ eReturnNumber = 1,
+ eNumberOfReturns = 2,
+ eScanDirection = 4,
+ eFlightLineEdge = 8,
+ eClassification = 16,
+ eScanAngleRank = 32,
+ eTime = 64
+ enum ClassificationType
eCreated = 0,
eUnclassified,
@@ -159,15 +174,44 @@
// = 13-31 // reserved for ASPRS Definition
+ Point();
+ Point(HeaderPtr header);
+ Point(Point const& other);
double GetX() const;
double GetY() const;
double GetZ() const;
- boost::uint16_t GetIntensity() const;
+ void SetCoordinates(double const& x, double const& y, double const& z);
+ void SetX(double const& value);
+ void SetY(double const& value);
+ void SetZ(double const& value);
+ boost::uint16_t GetIntensity() const;
+ void SetIntensity(boost::uint16_t const& intensity);
+ boost::uint8_t GetScanFlags() const;
+ void SetScanFlags(boost::uint8_t const& flags);
boost::uint16_t GetReturnNumber() const;
+ void SetReturnNumber(boost::uint16_t const& num);
boost::uint16_t GetNumberOfReturns() const;
+ void SetNumberOfReturns(boost::uint16_t const& num);
+ boost::uint16_t GetScanDirection() const;
+ void SetScanDirection(boost::uint16_t const& dir);
+ boost::uint16_t GetFlightLineEdge() const;
+ void SetFlightLineEdge(boost::uint16_t const& edge);
Classification GetClassification() const;
+ void SetClassification(Classification const& cls);
Color GetColor() const;
+ void SetColor(Color const& value);
double GetTime() const;
+ void SetTime(double const& time);
@@ -176,7 +220,11 @@
class VariableRecord
public:
- std::string GetUserId(bool pad) const;
+ VariableRecord();
+ VariableRecord(VariableRecord const& other);
+ ~VariableRecord();
+ std::string GetUserId(bool pad) const;
boost::uint16_t GetRecordId() const;
boost::uint16_t GetRecordLength() const;
std::string GetDescription(bool pad) const;
@@ -201,6 +249,11 @@
eOGRWKT = 2
+ SpatialReference();
+ ~SpatialReference();
+ SpatialReference(std::vector<VariableRecord> const& vlrs);
+ SpatialReference(SpatialReference const& other);
std::string GetWKT(WKTModeFlag mode_flag, bool pretty) const;
std::string GetProj4() const;
std::vector<VariableRecord> GetVLRs() const;
@@ -212,6 +265,7 @@
class Header
public:
+ Header();
Header(Header const& other);
std::string GetFileSignature() const;
@@ -269,11 +323,18 @@
class Reader
public:
- Reader(std::istream& ifs);
- ~Reader();
+ Reader(std::istream& ifs);
+ Reader(Reader const& other);
+ ~Reader();
+ // BUG: GetHeader and GetPoint make new proxy objects at every call.
+ // For perf reasons, it'd be nice to avoid that.
+ // BUG: GetHeader and GetPoint will cause GC issues if the Reader goes
+ // away while you're still using the Point or Header (see 18.6.1 of the
+ // swig manual)
Header const& GetHeader() const;
Point const& GetPoint() const;
bool ReadNextPoint();
bool ReadPointAt(std::size_t n);
void Reset();
@@ -287,28 +348,41 @@
public:
Writer(std::ostream& ofs, Header const& header);
+ Writer(Writer const& other);
+ ~Writer();
+ // BUG: see Reader::GetHeader() above
bool WritePoint(Point const& point);
//void WriteHeader(Header& header);
//void SetFilters(std::vector<liblas::FilterPtr> const& filters);
//void SetTransforms(std::vector<liblas::TransformPtr> const& transforms);
class ReaderFactory
public:
+ ReaderFactory();
+ ~ReaderFactory();
Reader CreateCached(std::istream& stream, boost::uint32_t cache_size);
Reader CreateWithStream(std::istream& stream);
static std::istream* FileOpen(std::string const& filename);
static void FileClose(std::istream*);
class WriterFactory
public:
+ WriterFactory();
+ ~WriterFactory();
static std::ostream* FileCreate(std::string const& filename);
static void FileClose(std::ostream*);
diff -r f21cf1799b09 -r 700fd86f446a csharp-new/liblas_swig_cpp/liblas_swig_cpp.vcxproj
--- a/csharp-new/liblas_swig_cpp/liblas_swig_cpp.vcxproj Thu Jan 13 10:20:53 2011 -0600
+++ b/csharp-new/liblas_swig_cpp/liblas_swig_cpp.vcxproj Thu Jan 13 15:07:46 2011 -0500
@@ -117,14 +117,14 @@
<ClCompile>
<WarningLevel>Level3</WarningLevel>
<Optimization>Disabled</Optimization>
- <AdditionalIncludeDirectories>C:\dev\liblas\include;C:\Program Files %28x86%29\boost\boost_1_44;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
+ <AdditionalIncludeDirectories>..\..\include;C:\Program Files %28x86%29\boost\boost_1_44;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
<DebugInformationFormat>ProgramDatabase</DebugInformationFormat>
<RuntimeTypeInfo>true</RuntimeTypeInfo>
<PreprocessorDefinitions>WIN32;_WINDOWS;_DEBUG;_CRT_SECURE_NO_DEPRECATE;_CRT_SECURE_NO_WARNINGS;_CRT_NONSTDC_NO_WARNING;_SCL_SECURE_NO_WARNINGS;%(PreprocessorDefinitions)</PreprocessorDefinitions>
</ClCompile>
<Link>
<GenerateDebugInformation>true</GenerateDebugInformation>
- <AdditionalDependencies>%(AdditionalDependencies);c:\dev\liblas\bin\Debug\Debug\liblas.lib</AdditionalDependencies>
+ <AdditionalDependencies>%(AdditionalDependencies);..\..\bin\Debug\Debug\liblas.lib</AdditionalDependencies>
<OutputFile>$(OutDir)$(TargetName)$(TargetExt)</OutputFile>
<AdditionalLibraryDirectories>%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
</Link>
@@ -133,14 +133,14 @@
<ClCompile>
</ClCompile>
<Link>
<AdditionalLibraryDirectories>C:\Program Files (x86)\boost\boost_1_44\lib;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
</Link>
@@ -151,12 +151,13 @@
<Optimization>MaxSpeed</Optimization>
<FunctionLevelLinking>true</FunctionLevelLinking>
<IntrinsicFunctions>true</IntrinsicFunctions>
</ClCompile>
<Link>
<EnableCOMDATFolding>true</EnableCOMDATFolding>
<OptimizeReferences>true</OptimizeReferences>
- <AdditionalDependencies>%(AdditionalDependencies);c:\dev\liblas\bin\Release\Release\liblas.lib</AdditionalDependencies>
+ <AdditionalDependencies>%(AdditionalDependencies);..\..\liblas\bin\Release\Release\liblas.lib</AdditionalDependencies>
</Link>
</ItemDefinitionGroup>
<ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|x64'">
@@ -165,12 +166,13 @@
</ClCompile>
<Link>
</Link>
<Import Project="$(VCTargetsPath)\Microsoft.Cpp.targets" />
diff -r f21cf1799b09 -r 700fd86f446a csharp-new/liblas_swig_test/Program.cs
--- a/csharp-new/liblas_swig_test/Program.cs Thu Jan 13 10:20:53 2011 -0600
+++ b/csharp-new/liblas_swig_test/Program.cs Thu Jan 13 15:07:46 2011 -0500
@@ -45,6 +45,7 @@
using Liblas;
using System.Diagnostics;
+using System.IO;
namespace swig_test
@@ -78,6 +79,8 @@
// reader tests for the generated B
Test_ReadT();
+ File.Delete(fileT);
return 0;
@@ -87,24 +90,28 @@
SWIGTYPE_p_std__istream ifs = Liblas.ReaderFactory.FileOpen(fileA);
- Reader reader = factory.CreateWithStream(ifs);
- TestReader.Test_A(reader);
+ // the "using" here is required, because it forces the Reader
+ // to be disposed before the stream explicitly goes away
+ using (Reader reader = factory.CreateWithStream(ifs))
+ TestReader.Test_A(reader);
- Header header = reader.GetHeader();
- TestHeader.Test_A(header);
+ Header header = reader.GetHeader();
+ TestHeader.Test_A(header);
- TestGuid.Test_A(header.GetProjectId());
+ TestGuid.Test_A(header.GetProjectId());
- VectorVariableRecord vlrs = header.GetVLRs();
- TestVariableRecord.Test_A(vlrs);
+ VectorVariableRecord vlrs = header.GetVLRs();
+ TestVariableRecord.Test_A(vlrs);
- SpatialReference srs = header.GetSRS();
More information about the Liblas-commits
