[Liblas-commits] hg: fix up
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Jan 14 10:43:44 EST 2011
details:   http://hg.liblas.orghg/rev/15e8dfd2e14b
changeset: 2765:15e8dfd2e14b
user:      Howard Butler <hobu.inc at gmail.com>
date:      Fri Jan 14 09:42:49 2011 -0600
description:
fix up
Subject: hg: add test of writing/reading compressed file
details:   http://hg.liblas.orghg/rev/93c76cdd1a71
changeset: 2766:93c76cdd1a71
date:      Fri Jan 14 09:43:03 2011 -0600
description:
Subject: hg: m_record is now gone -- no longer used
details:   http://hg.liblas.orghg/rev/381ffdfa435a
changeset: 2767:381ffdfa435a
date:      Fri Jan 14 09:43:25 2011 -0600
description:
diffstat:
 include/liblas/detail/writer/point.hpp |   2 -
 python/tests/File.txt                  |  36 +++++++++++++++++++++++++++++++++-
 python/tests/Header.txt                |   2 +-
 3 files changed, 36 insertions(+), 4 deletions(-)
diffs (83 lines):
diff -r 5bdc71863dd0 -r 381ffdfa435a include/liblas/detail/writer/point.hpp
--- a/include/liblas/detail/writer/point.hpp	Fri Jan 14 08:25:57 2011 -0600
+++ b/include/liblas/detail/writer/point.hpp	Fri Jan 14 09:43:25 2011 -0600
@@ -82,8 +82,6 @@
     std::ostream& m_ofs;
     HeaderPtr m_header;
-    PointRecord m_record;
     Schema m_format;
diff -r 5bdc71863dd0 -r 381ffdfa435a python/tests/File.txt
--- a/python/tests/File.txt	Fri Jan 14 08:25:57 2011 -0600
+++ b/python/tests/File.txt	Fri Jan 14 09:43:25 2011 -0600
@@ -304,6 +304,39 @@
   630320.96
   630280.89
+  >>> comp_header = header.Header()
+  >>> comp_header.minor_version = 2
+  >>> comp_header.compressed = True
+  >>> compressed = file.File('output.laz', mode='w', header=comp_header)
+  True
+  >>> for i in points:
+  ...    compressed.write(i)
+  >>> compressed.close()
+  >>> del compressed
+  >>> read_compressed = file.File('output.laz', mode='r')
+  >>> read_compressed.header.compressed
+  True
+  >>> for i in read_compressed:
+  ...   print round(i.x, 6)
+  630262.3
+  630282.45
+  630300.08
+  630346.83
+  630327.59
+  630323.57
+  630320.96
+  630280.89
+  >>> read_compressed.close()
+  >>> del read_compressed
 # The following tests writing out point data that are larger in size than
 # the base point format, allowing you to store extra data.
@@ -368,7 +401,7 @@
   >>> os.remove('junk3.las')
   >>> os.remove('junk4.las')
-# >>> os.remove('junk5.las')
+#  >>> os.remove('junk5.las')
   >>> f = file.File('junk.las', mode="w", header=h)
   >>> import liblas.core
@@ -384,5 +417,6 @@
   >>> import os
   >>> os.remove('junk.las')
diff -r 5bdc71863dd0 -r 381ffdfa435a python/tests/Header.txt
--- a/python/tests/Header.txt	Fri Jan 14 08:25:57 2011 -0600
+++ b/python/tests/Header.txt	Fri Jan 14 09:43:25 2011 -0600
@@ -48,7 +48,7 @@
   datetime.datetime(2008, 3, 19, 0, 0)
   >>> h.software_id
-  'libLAS 1.6.0b2'
+  'libLAS 1.6.0b4'
   >>> h.software_id = 'hobu'
   >>> h.software_id
   'hobu'
More information about the Liblas-commits mailing list
