[Liblas-commits] laszip: added Settings object to hold cmd line
params; added cmd...
liblas-commits at liblas.org
Fri Jan 14 18:03:35 EST 2011
details: http://hg.liblas.orglaszip/rev/207244c39d69
changeset: 146:207244c39d69
user: Michael P. Gerlek <mpg at flaxen.com>
date: Fri Jan 14 15:03:29 2011 -0800
description:
added Settings object to hold cmd line params; added cmd line interface; added randomness
diffstat:
tools/laszippertest.cpp | 194 +++++++++++++++++++++++++++++++++++++----------
1 files changed, 150 insertions(+), 44 deletions(-)
diffs (296 lines):
diff -r e3ff0a074d82 -r 207244c39d69 tools/laszippertest.cpp
--- a/tools/laszippertest.cpp Thu Jan 13 11:20:44 2011 -0800
+++ b/tools/laszippertest.cpp Fri Jan 14 15:03:29 2011 -0800
@@ -189,12 +189,10 @@
-class Data
+class PointData
public:
- Data(unsigned int num_pts, bool random) :
- num_points(num_pts),
- use_random(random)
+ PointData()
items[0].type = LASitem::POINT10;
items[0].size = 20;
@@ -235,7 +233,7 @@
return;
- ~Data()
+ ~PointData()
delete[] point;
delete[] point_data;
@@ -247,14 +245,39 @@
unsigned int point_size;
unsigned char* point_data;
unsigned char** point;
- unsigned num_points;
- bool use_random;
-static LASzipper* make_zipper(OStream* ost, Data& data, LASzip::Algorithm alg)
+class Settings
+public:
+ Settings(unsigned int num_pts, bool random, bool use_stream) :
+ num_points(num_pts),
+ use_random(random),
+ use_iostream(use_stream)
+ // use a seed based on the current time
+ seed = (unsigned int)time(NULL);
+ return;
+ ~Settings()
+ return;
+ unsigned num_points;
+ bool use_random;
+ unsigned int seed;
+ bool use_iostream;
+static LASzipper* make_zipper(OStream* ost, PointData& data, LASzip::Algorithm alg)
#ifndef LASZIP_HAVE_RANGECODER
if (alg == LASzip::POINT_BY_POINT_RANGE)
@@ -284,7 +307,7 @@
-static LASunzipper* make_unzipper(IStream* ist, Data& data, LASzip::Algorithm alg)
+static LASunzipper* make_unzipper(IStream* ist, PointData& data, LASzip::Algorithm alg)
@@ -313,7 +336,7 @@
-static void write_points(LASzipper* zipper, Data& data)
+static void write_points(LASzipper* zipper, Settings& settings, PointData& data)
if (zipper==NULL) // range coder test
return;
@@ -321,21 +344,44 @@
double start_time, end_time;
unsigned char c;
unsigned int i,j;
+ unsigned int num_bytes;
- start_time = taketime();
- c = 0;
- for (i = 0; i < data.num_points; i++)
+ // the two branches of this IF are the same, except for the use of a random number;
+ // we keep the random case separate, so that we can get fastest timing tests w/o random data
+ if (settings.use_random)
- for (j = 0; j < data.point_size; j++)
+ srand(settings.seed);
+ start_time = taketime();
+ c = rand() % 256;
+ for (i = 0; i < settings.num_points; i++)
- data.point_data[j] = c;
- c++;
+ for (j = 0; j < data.point_size; j++)
+ data.point_data[j] = c;
+ c = rand() % 256;
+ zipper->write(data.point);
- zipper->write(data.point);
+ num_bytes = zipper->close();
+ end_time = taketime();
+ else
+ c = 0;
+ c++;
- unsigned int num_bytes = zipper->close();
- end_time = taketime();
fprintf(stderr, "laszipper wrote %d bytes in %g seconds\n", num_bytes, end_time-start_time);
return;
@@ -344,7 +390,7 @@
-static void read_points(LASunzipper* unzipper, Data& data)
+static void read_points(LASunzipper* unzipper, Settings& settings, PointData& data)
if (unzipper==NULL) // range coder test
return;
@@ -357,24 +403,50 @@
num_errors = 0;
- c = 0;
- unzipper->read(data.point);
+ c = rand() % 256;
- if (data.point_data[j] != c)
+ unzipper->read(data.point);
- fprintf(stderr, "%d %d %d != %d\n", i, j, data.point_data[j], c);
- num_errors++;
- if (num_errors > 20) break;
+ if (data.point_data[j] != c)
+ fprintf(stderr, "%d %d %d != %d\n", i, j, data.point_data[j], c);
+ num_errors++;
+ if (num_errors > 20) break;
+ c = rand() % 256;
- c++;
+ num_bytes = unzipper->close();
- num_bytes = unzipper->close();
+ else
+ c = 0;
+ num_errors++;
+ c++;
if (num_errors)
fprintf(stderr, "ERROR: with lasunzipper %d\n", num_errors);
@@ -390,17 +462,17 @@
-static void run_test(bool use_iostream, const char* filename, Data& data, LASzip::Algorithm alg)
+static void run_test(const char* filename, Settings& settings, PointData& data, LASzip::Algorithm alg)
- OStream* ost = new OStream(use_iostream, filename);
+ OStream* ost = new OStream(settings.use_iostream, filename);
LASzipper* laszipper = make_zipper(ost, data, alg);
- write_points(laszipper, data);
+ write_points(laszipper, settings, data);
delete laszipper;
delete ost;
- IStream* ist = new IStream(use_iostream, filename);
+ IStream* ist = new IStream(settings.use_iostream, filename);
LASunzipper* lasunzipper = make_unzipper(ist, data, alg);
- read_points(lasunzipper, data);
+ read_points(lasunzipper, settings, data);
delete lasunzipper;
delete ist;
@@ -414,17 +486,51 @@
unsigned int num_points = 100000;
bool use_iostream = false;
- bool forever = false;
- bool use_random = true;
+ bool run_forever = false;
+ bool use_random = false;
+ for (int i=1; i<argc; i++)
+ const char* p = argv[i];
+ if (strcmp(p,"-n")==0)
+ ++i;
+ num_points = atoi(argv[i]);
+ else if (strcmp(p,"-s")==0)
+ use_iostream = true;
+ else if (strcmp(p,"-f")==0)
+ run_forever = true;
+ else if (strcmp(p,"-r")==0)
+ use_random = true;
+ else
+ fprintf(stderr, "Usage: ziptest [-n NUMBER] [-s] [-f] [-r]\n");
+ exit(1);
+ printf("Settings:\n");
+ printf(" num_points=%d, use_iostream=%s, run_forever=%s, use_random=%s\n",
+ num_points, use_iostream?"true":"false", run_forever?"true":"false", use_random?"true":"false");
+ Settings settings(num_points, use_random, use_iostream);
do
- Data data(num_points, use_random);
+ PointData data;
- run_test(use_iostream, "test1.lax", data, LASzip::POINT_BY_POINT_RAW);
- run_test(use_iostream, "test2.lax", data, LASzip::POINT_BY_POINT_ARITHMETIC);
- run_test(use_iostream, "test3.lax", data, LASzip::POINT_BY_POINT_RANGE);
- } while (forever);
+ run_test("test1.lax", settings, data, LASzip::POINT_BY_POINT_RAW);
+ run_test("test2.lax", settings, data, LASzip::POINT_BY_POINT_ARITHMETIC);
+ run_test("test3.lax", settings, data, LASzip::POINT_BY_POINT_RANGE);
+ } while (run_forever);
return 0;
More information about the Liblas-commits
