[Liblas-commits] laszip: made Settings be a singleton,
added proper logging
liblas-commits at liblas.org
Sun Jan 16 19:38:32 EST 2011
details: http://hg.liblas.orglaszip/rev/e9b23bb9df21
changeset: 148:e9b23bb9df21
user: Michael P. Gerlek <mpg at flaxen.com>
date: Sun Jan 16 16:38:27 2011 -0800
description:
made Settings be a singleton, added proper logging
diffstat:
tools/laszippertest.cpp | 90 +++++++++++++++++++++++++++++++-----------------
1 files changed, 58 insertions(+), 32 deletions(-)
diffs (245 lines):
diff -r 37920442ee72 -r e9b23bb9df21 tools/laszippertest.cpp
--- a/tools/laszippertest.cpp Fri Jan 14 15:06:41 2011 -0800
+++ b/tools/laszippertest.cpp Sun Jan 16 16:38:27 2011 -0800
@@ -58,6 +58,7 @@
#include <time.h>
#include <stdio.h>
+#include <stdarg.h>
//#define LASZIP_HAVE_RANGECODER
@@ -258,13 +259,13 @@
use_random(random),
use_iostream(use_stream)
- // use a seed based on the current time
- seed = (unsigned int)time(NULL);
+ logfile = fopen("zippertest.log","w");
return;
~Settings()
+ fclose(logfile);
return;
@@ -272,8 +273,26 @@
bool use_random;
unsigned int seed;
bool use_iostream;
+ FILE* logfile;
+static Settings* settings = NULL; // singleton
+static void log(const char* format, ...)
+ va_list args;
+ va_start(args, format);
+ vfprintf(stderr, format, args);
+ vfprintf(settings->logfile, format, args);
+ va_end(args);
+ fflush(settings->logfile);
+ return;
@@ -282,7 +301,7 @@
#ifndef LASZIP_HAVE_RANGECODER
if (alg == LASzip::POINT_BY_POINT_RANGE)
- fprintf(stderr, "(skipping range encoder test)\n");
+ log("(skipping range encoder test)\n");
return NULL;
#endif
@@ -297,7 +316,7 @@
if (stat != 0)
- fprintf(stderr, "ERROR: could not open laszipper with %s\n", ost->m_filename);
+ log("ERROR: could not open laszipper with %s\n", ost->m_filename);
exit(1);
@@ -326,7 +345,7 @@
if (stat != 0)
- fprintf(stderr, "ERROR: could not open lasunzipper with %s\n", ist->m_filename);
+ log("ERROR: could not open lasunzipper with %s\n", ist->m_filename);
exit(1);
@@ -336,7 +355,7 @@
-static void write_points(LASzipper* zipper, Settings& settings, PointData& data)
+static void write_points(LASzipper* zipper, PointData& data)
if (zipper==NULL) // range coder test
return;
@@ -348,12 +367,12 @@
// the two branches of this IF are the same, except for the use of a random number;
// we keep the random case separate, so that we can get fastest timing tests w/o random data
- if (settings.use_random)
+ if (settings->use_random)
- srand(settings.seed);
+ srand(settings->seed);
start_time = taketime();
c = rand() % 256;
- for (i = 0; i < settings.num_points; i++)
+ for (i = 0; i < settings->num_points; i++)
for (j = 0; j < data.point_size; j++)
@@ -369,7 +388,7 @@
c = 0;
@@ -382,7 +401,7 @@
end_time = taketime();
- fprintf(stderr, "laszipper wrote %d bytes in %g seconds\n", num_bytes, end_time-start_time);
+ log("laszipper wrote %d bytes in %g seconds\n", num_bytes, end_time-start_time);
return;
@@ -390,7 +409,7 @@
-static void read_points(LASunzipper* unzipper, Settings& settings, PointData& data)
+static void read_points(LASunzipper* unzipper, PointData& data)
if (unzipper==NULL) // range coder test
return;
@@ -403,18 +422,18 @@
num_errors = 0;
c = rand() % 256;
unzipper->read(data.point);
if (data.point_data[j] != c)
- fprintf(stderr, "%d %d %d != %d\n", i, j, data.point_data[j], c);
+ log("%d %d %d != %d\n", i, j, data.point_data[j], c);
num_errors++;
if (num_errors > 20) break;
@@ -428,14 +447,14 @@
else
c = 0;
num_errors++;
@@ -449,11 +468,11 @@
if (num_errors)
- fprintf(stderr, "ERROR: with lasunzipper %d\n", num_errors);
+ log("ERROR: with lasunzipper %d\n", num_errors);
else
- fprintf(stderr, "SUCCESS: lasunzipper read %d bytes in %g seconds\n", num_bytes, end_time-start_time);
+ log("SUCCESS: lasunzipper read %d bytes in %g seconds\n", num_bytes, end_time-start_time);
return;
@@ -462,17 +481,17 @@
-static void run_test(const char* filename, Settings& settings, PointData& data, LASzip::Algorithm alg)
+static void run_test(const char* filename, PointData& data, LASzip::Algorithm alg)
- OStream* ost = new OStream(settings.use_iostream, filename);
+ OStream* ost = new OStream(settings->use_iostream, filename);
LASzipper* laszipper = make_zipper(ost, data, alg);
- write_points(laszipper, settings, data);
+ write_points(laszipper, data);
delete laszipper;
delete ost;
- IStream* ist = new IStream(settings.use_iostream, filename);
+ IStream* ist = new IStream(settings->use_iostream, filename);
LASunzipper* lasunzipper = make_unzipper(ist, data, alg);
- read_points(lasunzipper, settings, data);
+ read_points(lasunzipper, data);
delete lasunzipper;
delete ist;
@@ -520,20 +539,27 @@
- printf("Settings:\n");
- printf(" num_points=%d, use_iostream=%s, run_forever=%s, use_random=%s\n",
+ settings = new Settings(num_points, use_random, use_iostream);
+ log("Settings:\n");
+ log(" num_points=%d, use_iostream=%s, run_forever=%s, use_random=%s\n",
num_points, use_iostream?"true":"false", run_forever?"true":"false", use_random?"true":"false");
- Settings settings(num_points, use_random, use_iostream);
+ unsigned int run = 1;
do
PointData data;
- run_test("test1.lax", settings, data, LASzip::POINT_BY_POINT_RAW);
- run_test("test2.lax", settings, data, LASzip::POINT_BY_POINT_ARITHMETIC);
- run_test("test3.lax", settings, data, LASzip::POINT_BY_POINT_RANGE);
+ // use a seed based on the current time
+ settings->seed = (unsigned int)time(NULL);
+ log("Seed: %u\n", settings->seed);
+ run_test("test1.lax", data, LASzip::POINT_BY_POINT_RAW);
+ run_test("test2.lax", data, LASzip::POINT_BY_POINT_ARITHMETIC);
+ run_test("test3.lax", data, LASzip::POINT_BY_POINT_RANGE);
+ log("Finished %u runs\n\n", run);
+ ++run;
} while (run_forever);
return 0;
More information about the Liblas-commits
