[Liblas-commits] hg: make Cleanup methods save to call multiple
times
liblas-commits at liblas.org
Tue Jan 18 11:58:54 EST 2011
details: http://hg.liblas.orghg/rev/82b078bee898
changeset: 2775:82b078bee898
user: Howard Butler <hobu.inc at gmail.com>
date: Tue Jan 18 10:58:35 2011 -0600
description:
make Cleanup methods save to call multiple times
Subject: hg: use size_type for iteration, not size_t
details: http://hg.liblas.orghg/rev/77d092db4f1a
changeset: 2776:77d092db4f1a
date: Tue Jan 18 10:58:47 2011 -0600
description:
diffstat:
include/liblas/liblas.hpp | 2 ++
src/c_api.cpp | 2 +-
2 files changed, 3 insertions(+), 1 deletions(-)
diffs (31 lines):
diff -r db7de8b00d68 -r 77d092db4f1a include/liblas/liblas.hpp
--- a/include/liblas/liblas.hpp Tue Jan 18 10:52:44 2011 -0600
+++ b/include/liblas/liblas.hpp Tue Jan 18 10:58:47 2011 -0600
@@ -165,6 +165,7 @@
// An ofstream is closeable and deletable, but
// an ostream like &std::cout isn't.
+ if (!ofs) return;
if (static_cast<std::ofstream&>(*ofs))
static_cast<std::ofstream&>(*ofs).close();
@@ -176,6 +177,7 @@
// An ifstream is closeable and deletable, but
// an istream like &std::cin isn't.
+ if (!ifs) return;
if (static_cast<std::ifstream&>(*ifs))
static_cast<std::ifstream&>(*ifs).close();
diff -r db7de8b00d68 -r 77d092db4f1a src/c_api.cpp
--- a/src/c_api.cpp Tue Jan 18 10:52:44 2011 -0600
+++ b/src/c_api.cpp Tue Jan 18 10:58:47 2011 -0600
@@ -169,7 +169,7 @@
LAS_DLL void LASError_Reset(void) {
if (errors.empty()) return;
- for (std::size_t i=0;i<errors.size();i++) errors.pop();
+ for (std::stack<liblas::Error >::size_type i=0;i<errors.size();i++) errors.pop();
LAS_DLL void LASError_Pop(void) {
More information about the Liblas-commits
