[Liblas-commits] hg: whitespace normalization
liblas-commits at liblas.org
Wed Jan 19 11:14:45 EST 2011
details: http://hg.liblas.orghg/rev/7a6220f4ac83
changeset: 2787:7a6220f4ac83
user: Howard Butler <hobu.inc at gmail.com>
date: Wed Jan 19 10:14:38 2011 -0600
description:
diffstat:
apps/laskernel.cpp | 51 ++++++++++++++++++++++++++++++++-------------------
1 files changed, 32 insertions(+), 19 deletions(-)
diffs (98 lines):
diff -r c5c07e9d970d -r 7a6220f4ac83 apps/laskernel.cpp
--- a/apps/laskernel.cpp Wed Jan 19 08:48:39 2011 -0600
+++ b/apps/laskernel.cpp Wed Jan 19 10:14:38 2011 -0600
@@ -222,7 +222,8 @@
} catch (liblas::property_tree::ptree_bad_path const& )
- std::cerr << "Unable to write header point return count info. Does the outputted file have any points?";
+ std::cerr << "Unable to write header point return count info. "
+ "Does the outputted file have any points?";
return;
@@ -239,54 +240,66 @@
return false;
-liblas::FilterPtr MakeReturnFilter(std::vector<boost::uint16_t> const& returns, liblas::FilterI::FilterType ftype)
+liblas::FilterPtr MakeReturnFilter( std::vector<boost::uint16_t> const& returns,
+ liblas::FilterI::FilterType ftype)
- liblas::ReturnFilter* return_filter = new liblas::ReturnFilter(returns, false);
+ typedef liblas::ReturnFilter filter;
+ filter* return_filter = new filter(returns, false);
return_filter->SetType(ftype);
return liblas::FilterPtr(return_filter);
-liblas::FilterPtr MakeClassFilter(std::vector<liblas::Classification> const& classes, liblas::FilterI::FilterType ftype)
+liblas::FilterPtr MakeClassFilter(std::vector<liblas::Classification> const& classes,
- liblas::ClassificationFilter* class_filter = new liblas::ClassificationFilter(classes);
+ typedef liblas::ClassificationFilter filter;
+ filter* class_filter = new filter(classes);
class_filter->SetType(ftype);
return liblas::FilterPtr(class_filter);
-liblas::FilterPtr MakeBoundsFilter(liblas::Bounds<double> const& bounds, liblas::FilterI::FilterType ftype)
+liblas::FilterPtr MakeBoundsFilter(liblas::Bounds<double> const& bounds,
- liblas::BoundsFilter* bounds_filter = new liblas::BoundsFilter(bounds);
+ typedef liblas::BoundsFilter filter;
+ filter* bounds_filter = new filter(bounds);
bounds_filter->SetType(ftype);
return liblas::FilterPtr(bounds_filter);
-liblas::FilterPtr MakeIntensityFilter(std::string intensities, liblas::FilterI::FilterType ftype)
+liblas::FilterPtr MakeIntensityFilter(std::string intensities,
- liblas::ContinuousValueFilter<boost::uint16_t>::filter_func f = &liblas::Point::GetIntensity;
- liblas::ContinuousValueFilter<boost::uint16_t>* intensity_filter = new liblas::ContinuousValueFilter<boost::uint16_t>(f, intensities);
+ typedef liblas::ContinuousValueFilter<boost::uint16_t> filter;
+ filter::filter_func f = &liblas::Point::GetIntensity;
+ filter* intensity_filter = new filter(f, intensities);
intensity_filter->SetType(ftype);
return liblas::FilterPtr(intensity_filter);
-liblas::FilterPtr MakeTimeFilter(std::string times, liblas::FilterI::FilterType ftype)
+liblas::FilterPtr MakeTimeFilter(std::string times,
- liblas::ContinuousValueFilter<double>::filter_func f = &liblas::Point::GetTime;
- liblas::ContinuousValueFilter<double>* time_filter = new liblas::ContinuousValueFilter<double>(f, times);
+ typedef liblas::ContinuousValueFilter<double> filter;
+ filter::filter_func f = &liblas::Point::GetTime;
+ filter* time_filter = new filter(f, times);
time_filter->SetType(ftype);
return liblas::FilterPtr(time_filter);
-liblas::FilterPtr MakeScanAngleFilter(std::string intensities, liblas::FilterI::FilterType ftype)
+liblas::FilterPtr MakeScanAngleFilter(std::string intensities,
- liblas::ContinuousValueFilter<boost::int8_t>::filter_func f = &liblas::Point::GetScanAngleRank;
- liblas::ContinuousValueFilter<boost::int8_t>* intensity_filter = new liblas::ContinuousValueFilter<boost::int8_t>(f, intensities);
+ typedef liblas::ContinuousValueFilter<boost::int8_t> filter;
+ filter::filter_func f = &liblas::Point::GetScanAngleRank;
-liblas::FilterPtr MakeColorFilter(liblas::Color const& low, liblas::Color const& high, liblas::FilterI::FilterType ftype)
+liblas::FilterPtr MakeColorFilter(liblas::Color const& low,
+ liblas::Color const& high,
liblas::ColorFilter* filter = new liblas::ColorFilter(low, high);
More information about the Liblas-commits
