[Liblas-commits] hg: get liblas::{Writer|Reader}::{Get|Set}Header
squared away an...
liblas-commits at liblas.org
Thu Jan 20 12:15:22 EST 2011
details: http://hg.liblas.orghg/rev/2b07a62223ea
changeset: 2795:2b07a62223ea
user: Howard Butler <hobu.inc at gmail.com>
date: Thu Jan 20 11:14:59 2011 -0600
description:
get liblas::{Writer|Reader}::{Get|Set}Header squared away and consistent in both the C++ and C APIs
diffstat:
include/liblas/capi/liblas.h | 15 ++++++++++++++-
include/liblas/writer.hpp | 5 ++++-
src/c_api.cpp | 41 ++++++++++++++++++++++++++++++++++++++++-
src/writer.cpp | 8 ++++++--
test/unit/writer_test.cpp | 3 ++-
5 files changed, 66 insertions(+), 6 deletions(-)
diffs (172 lines):
diff -r 24b479586b7d -r 2b07a62223ea include/liblas/capi/liblas.h
--- a/include/liblas/capi/liblas.h Wed Jan 19 16:23:02 2011 -0600
+++ b/include/liblas/capi/liblas.h Thu Jan 20 11:14:59 2011 -0600
@@ -194,6 +194,7 @@
LAS_DLL LASHeaderH LASReader_GetHeader(const LASReaderH hReader);
+LAS_DLL void LASReader_SetHeader( LASReaderH hReader, const LASHeaderH hHeader);
LAS_DLL LASError LASReader_SetSRS(LASReaderH hReader, const LASSRSH hSRS);
LAS_DLL LASError LASReader_SetInputSRS(LASReaderH hReader, const LASSRSH hSRS);
@@ -906,7 +907,9 @@
LAS_DLL LASError LASWriter_WritePoint(const LASWriterH hWriter, const LASPointH hPoint);
/** Overwrites the header for the file represented by the LASWriterH. It does
- * not matter if the file is opened for append or for write.
+ * not matter if the file is opened for append or for write. This function is
+ * equivalent to calling LASWriter_SetHeader and LASWriter_WriteOwnedHeader
+ * simultaneously.
* @param hWriter opaque pointer to the LASWriterH instance
* @param hHeader LASHeaderH instance to write into the file
* @return LE_None if no error occurred during the operation.
@@ -914,6 +917,15 @@
LAS_DLL LASError LASWriter_WriteHeader(const LASWriterH hWriter, const LASHeaderH hHeader);
+/** Overwrites the header for the file represented by the LASWriterH that was
+ * set using LASWriter_SetHeader or flushes the existing header that is on the
+ * the writer to the file and resets the file for writing.
+ * @param hWriter opaque pointer to the LASWriterH instance
+ * @return LE_None if no error occurred during the operation.
+LAS_DLL LASError LASWriter_WriteOwnedHeader(const LASWriterH hWriter);
/** Destroys the LASWriterH instance, effectively closing the file and performing
* housekeeping operations.
* @param hWriter LASWriterH instance to close
@@ -927,6 +939,7 @@
* in the event of a NULL return.
LAS_DLL LASHeaderH LASWriter_GetHeader(const LASWriterH hWriter);
+LAS_DLL void LASWriter_SetHeader( LASWriterH hWriter, const LASHeaderH hHeader) ;
LAS_DLL LASError LASWriter_SetSRS(LASWriterH hWriter, const LASSRSH hSRS);
LAS_DLL LASError LASWriter_SetInputSRS(LASWriterH hWriter, const LASSRSH hSRS);
diff -r 24b479586b7d -r 2b07a62223ea include/liblas/writer.hpp
--- a/include/liblas/writer.hpp Wed Jan 19 16:23:02 2011 -0600
+++ b/include/liblas/writer.hpp Thu Jan 20 11:14:59 2011 -0600
@@ -82,13 +82,16 @@
/// Provides access to header structure.
Header const& GetHeader() const;
+ void SetHeader(Header const& header);
/// \todo TODO: Move point record composition deep into writer implementation.
/// \todo TODO: How to handle point_source_id in portable way, for LAS 1.0 and 1.1
bool WritePoint(Point const& point);
/// Allow in-place writing of header
- void WriteHeader(Header& header);
+ void WriteHeader();
/// Sets filters that are used to determine wither or not to
/// keep a point that before we write it
diff -r 24b479586b7d -r 2b07a62223ea src/c_api.cpp
--- a/src/c_api.cpp Wed Jan 19 16:23:02 2011 -0600
+++ b/src/c_api.cpp Thu Jan 20 11:14:59 2011 -0600
@@ -269,6 +269,17 @@
+ VALIDATE_LAS_POINTER0(hReader, "LASReader_SetHeader");
+ VALIDATE_LAS_POINTER0(hHeader, "LASReader_SetHeader");
+ liblas::Reader* reader = (liblas::Reader*)hReader;
+ liblas::Header* header = (liblas::Header*)hHeader;
+ reader->SetHeader(*header);
LAS_DLL void LASReader_Destroy(LASReaderH hReader)
VALIDATE_LAS_POINTER0(hReader, "LASReader_Destroy");
@@ -1518,7 +1529,8 @@
VALIDATE_LAS_POINTER1(hWriter, "LASWriter_WriteHeader", LE_Failure);
try {
- ((liblas::Writer*) hWriter)->WriteHeader(*((liblas::Header*) hHeader));
+ ((liblas::Writer*) hWriter)->SetHeader(*((liblas::Header*) hHeader));
+ ((liblas::Writer*) hWriter)->WriteHeader();
} catch (std::exception const& e)
LASError_PushError(LE_Failure, e.what(), "LASWriter_WriteHeader");
@@ -1528,6 +1540,33 @@
return LE_None;
+LAS_DLL LASErrorEnum LASWriter_WriteOwnedHeader(const LASWriterH hWriter)
+ VALIDATE_LAS_POINTER1(hWriter, "LASWriter_WriteOwnedHeader", LE_Failure);
+ try {
+ } catch (std::exception const& e)
+ LASError_PushError(LE_Failure, e.what(), "LASWriter_WriteOwnedHeader");
+ return LE_Failure;
+ return LE_None;
+ VALIDATE_LAS_POINTER0(hWriter, "LASWriter_SetHeader");
+ VALIDATE_LAS_POINTER0(hHeader, "LASWriter_SetHeader");
+ liblas::Writer* writer = (liblas::Writer*)hWriter;
+ writer->SetHeader(*header);
LAS_DLL void LASWriter_Destroy(LASWriterH hWriter)
VALIDATE_LAS_POINTER0(hWriter, "LASWriter_Destroy");
diff -r 24b479586b7d -r 2b07a62223ea src/writer.cpp
--- a/src/writer.cpp Wed Jan 19 16:23:02 2011 -0600
+++ b/src/writer.cpp Thu Jan 20 11:14:59 2011 -0600
@@ -98,17 +98,21 @@
return m_pimpl->GetHeader();
+void Writer::SetHeader(Header const& header)
+ return m_pimpl->SetHeader(header);
bool Writer::WritePoint(Point const& point)
m_pimpl->WritePoint(point);
return true;
-void Writer::WriteHeader(Header& header)
+void Writer::WriteHeader()
// The writer may update our header as part of its
// writing process (change VLRs for SRS's, for instance).
- m_pimpl->SetHeader(header);
m_pimpl->WriteHeader();
diff -r 24b479586b7d -r 2b07a62223ea test/unit/writer_test.cpp
--- a/test/unit/writer_test.cpp Wed Jan 19 16:23:02 2011 -0600
+++ b/test/unit/writer_test.cpp Thu Jan 20 11:14:59 2011 -0600
@@ -207,7 +207,8 @@
header.SetScale(1.123, 2.123, 3.123);
header.SetOffset(4.321, 5.321, 6.321);
- writer.WriteHeader(header);
+ writer.SetHeader(header);
+ writer.WriteHeader();
liblas::Header const& written_header = writer.GetHeader();
ensure_equals("written_header fileSource id", written_header.GetFileSourceId(), 65535);
ensure_equals("written_header SystemId", written_header.GetSystemId(), "Unit Test libLAS System");
More information about the Liblas-commits
