[Liblas-commits] hg: add {Get|Set}Data methods for LASPointH for manipulating raw...
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Jan 20 13:55:48 EST 2011
details:   http://hg.liblas.orghg/rev/104d1f1c250e
changeset: 2797:104d1f1c250e
user:      Howard Butler <hobu.inc at gmail.com>
date:      Thu Jan 20 12:55:22 2011 -0600
description:
add {Get|Set}Data methods for LASPointH for manipulating raw point data
diffstat:
 include/liblas/capi/liblas.h |  18 +++++++++++
 src/c_api.cpp                |  72 +++++++++++++++++++++++++++++++++++++++++++-
 2 files changed, 89 insertions(+), 1 deletions(-)
diffs (117 lines):
diff -r 39fbbdf0882b -r 104d1f1c250e include/liblas/capi/liblas.h
--- a/include/liblas/capi/liblas.h	Thu Jan 20 12:15:41 2011 -0600
+++ b/include/liblas/capi/liblas.h	Thu Jan 20 12:55:22 2011 -0600
@@ -508,6 +508,24 @@
 LAS_DLL void LASPoint_SetHeader( LASPointH hPoint, const LASHeaderH hHeader);
+/** Gets the data stream for the VLR as an array of bytes.  The length of this
+ *  array should be the same as LASVLR_GetRecordLength.  You must allocate it on
+ *  the heap and you are responsible for its destruction.
+ *  @param hPoint the LASPointH instance
+ *  @param data a pointer to your array where you want the data copied
+ *  @return LASErrorEnum
+LAS_DLL LASError LASPoint_GetData(const LASPointH hPoint, unsigned char* data);
+/** Sets the data stream for the Point as an array of bytes.  The length of this
+ *  array should be the same as LASPoint_GetHeader(LASHeader_GetDataRecordLength()).  The data are copied into
+ *  the Point .
+ *  @param data a pointer to your array.  It must be LASPoint_GetHeader(LASHeader_GetDataRecordLength()) in size
+LAS_DLL LASError LASPoint_SetData(LASPointH hPoint, unsigned char* data);
 /* Header operations                                                        */
diff -r 39fbbdf0882b -r 104d1f1c250e src/c_api.cpp
--- a/src/c_api.cpp	Thu Jan 20 12:15:41 2011 -0600
+++ b/src/c_api.cpp	Thu Jan 20 12:55:22 2011 -0600
@@ -481,6 +481,76 @@
     point->SetHeaderPtr(h);
+LAS_DLL LASErrorEnum LASPoint_SetData(LASPointH hPoint, unsigned char* data) {
+    VALIDATE_LAS_POINTER1(hPoint, "LASPoint_SetData", LE_Failure);
+    VALIDATE_LAS_POINTER1(data, "LASPoint_SetData", LE_Failure);
+    try {
+        liblas::Point* p = ((liblas::Point*) hPoint);
+        boost::uint16_t size = 0;
+        liblas::HeaderPtr h = p->GetHeaderPtr();
+        if (h.get())
+            size = h->GetDataRecordLength();
+        } else
+            size = liblas::DefaultHeader::get().GetDataRecordLength();
+        std::vector<boost::uint8_t> & d = p->GetData();
+        if (d.size() != size)
+            d.resize(size);
+            d.assign(0, size);
+        for (boost::uint16_t i=0; i < size; i++) {
+            d[i] = data[i];
+    catch (std::exception const& e) {
+        LASError_PushError(LE_Failure, e.what(), "LASPoint_SetData");
+        return LE_Failure;
+    return LE_None;
+LAS_DLL LASErrorEnum LASPoint_GetData( const LASPointH hPoint, boost::uint8_t* data) {
+    VALIDATE_LAS_POINTER1(hPoint, "LASPoint_GetData", LE_Failure);
+    VALIDATE_LAS_POINTER1(data, "LASPoint_GetData", LE_Failure);
+    try {
+        std::vector<boost::uint8_t> const& d = p->GetData();
+        if (h.get())
+        } else
+            data[i] = d[i];
+        LASError_PushError(LE_Failure, e.what(), "LASPoint_GetData");
+    return LE_None;
 LAS_DLL void LASPoint_Destroy(LASPointH hPoint) {
     VALIDATE_LAS_POINTER0(hPoint, "LASPoint_Destroy");
     delete (liblas::Point*) hPoint;
@@ -1808,7 +1878,7 @@
     try {
         liblas::VariableRecord* vlr = ((liblas::VariableRecord*) hVLR);
-        std::vector<boost::uint8_t> d = vlr->GetData();
+        std::vector<boost::uint8_t> const& d = vlr->GetData();
         boost::uint16_t length = vlr->GetRecordLength();
         for (boost::uint16_t i=0; i < length; i++) {
             data[i] = d[i];
More information about the Liblas-commits mailing list
