[Liblas-commits] hg: add locale support to las2txt
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Jan 20 23:35:03 EST 2011
details:   http://hg.liblas.orghg/rev/163628f814ba
changeset: 2802:163628f814ba
user:      Howard Butler <hobu.inc at gmail.com>
date:      Thu Jan 20 22:34:32 2011 -0600
description:
Subject: hg: use appropriate numeric types for number output
details:   http://hg.liblas.orghg/rev/3d25d8f60b35
changeset: 2803:3d25d8f60b35
date:      Thu Jan 20 22:34:52 2011 -0600
description:
diffstat:
 apps/lasinfo.cpp |  16 +++++++++++++++-
 src/header.cpp   |   4 ++--
 src/utility.cpp  |   4 ++--
 3 files changed, 19 insertions(+), 5 deletions(-)
diffs (89 lines):
diff -r 614df6944ee9 -r 3d25d8f60b35 apps/lasinfo.cpp
--- a/apps/lasinfo.cpp	Thu Jan 20 14:20:58 2011 -0600
+++ b/apps/lasinfo.cpp	Thu Jan 20 22:34:52 2011 -0600
@@ -15,6 +15,8 @@
 #include <boost/cstdint.hpp>
 #include <boost/foreach.hpp>
+#include <locale>
 using namespace liblas;
 using namespace std;
@@ -106,6 +108,7 @@
     bool output_xml = false;
     bool output_json = false;
     bool show_point = false;
+    bool use_locale = false;
     boost::uint32_t point = 0;
     std::vector<liblas::FilterPtr> filters;
@@ -134,7 +137,7 @@
             ("xml", po::value<bool>(&output_xml)->zero_tokens()->implicit_value(true), "Output as XML")
             ("point,p", po::value<boost::uint32_t>(&point), "Display a point with a given id.  --point 44")
-            // ("json", po::value<bool>(&output_json)->zero_tokens()->implicit_value(true), "Output summary as JSON")
+            ("locale", po::value<bool>(&use_locale)->zero_tokens()->implicit_value(true), "Use the environment's locale for output")
 // --xml
 // --json
@@ -207,6 +210,11 @@
                 else
+                    if (use_locale)
+                        std::locale l("");
+                        std::cout.imbue(l);
                     std::cout <<  p << std::endl;
                     exit(0);
@@ -251,6 +259,12 @@
             return 0;
+        if (use_locale)
         std::cout << header << std::endl;
         if (show_vlrs)
             PrintVLRs(std::cout, header);
diff -r 614df6944ee9 -r 3d25d8f60b35 src/header.cpp
--- a/src/header.cpp	Thu Jan 20 14:20:58 2011 -0600
+++ b/src/header.cpp	Thu Jan 20 22:34:52 2011 -0600
@@ -793,7 +793,7 @@
     os << "  Generating Software:         '" << tree.get<std::string>("softwareid") << "'" << std::endl;
     os << "  File Creation Day/Year:      " << tree.get<std::string>("date") << std::endl;
     os << "  Header Byte Size             " << tree.get<boost::uint32_t>("size") << std::endl;
-    os << "  Data Offset:                 " << tree.get<std::string>("dataoffset") << std::endl;
+    os << "  Data Offset:                 " << tree.get<boost::uint32_t>("dataoffset") << std::endl;
     os << "  Number Var. Length Records:  ";
     try {
@@ -812,7 +812,7 @@
     BOOST_FOREACH(ptree::value_type &v,
           tree.get_child("returns"))
-          returns_oss << v.second.get<std::string>("count")<< " ";
+          returns_oss << v.second.get<boost::uint32_t>("count")<< " ";
diff -r 614df6944ee9 -r 3d25d8f60b35 src/utility.cpp
--- a/src/utility.cpp	Thu Jan 20 14:20:58 2011 -0600
+++ b/src/utility.cpp	Thu Jan 20 22:34:52 2011 -0600
@@ -391,8 +391,8 @@
         os << "  File has no points ...";
         return os;
-    os << "  Header Point Count: " << tree.get<std::string>("summary.header.count") << std::endl;
-    os << "  Actual Point Count: " << tree.get<std::string>("summary.points.count") << std::endl;
+    os << "  Header Point Count: " << tree.get<boost::uint32_t>("summary.header.count") << std::endl;
+    os << "  Actual Point Count: " << tree.get<boost::uint32_t>("summary.points.count") << std::endl;
     os << std::endl;
     os << "  Minimum and Maximum Attributes (min,max)" << std::endl;
More information about the Liblas-commits mailing list
