[Liblas-commits] hg: use common stream creation facility
liblas-commits at liblas.org
Fri Jan 21 12:44:02 EST 2011
details: http://hg.liblas.orghg/rev/e4decee2196b
changeset: 2807:e4decee2196b
user: Howard Butler <hobu.inc at gmail.com>
date: Fri Jan 21 11:43:55 2011 -0600
description:
diffstat:
src/c_api.cpp | 25 +++----------------------
1 files changed, 3 insertions(+), 22 deletions(-)
diffs (42 lines):
diff -r b1dbaf051135 -r e4decee2196b src/c_api.cpp
--- a/src/c_api.cpp Fri Jan 21 09:53:35 2011 -0600
+++ b/src/c_api.cpp Fri Jan 21 11:43:55 2011 -0600
@@ -1550,23 +1550,8 @@
else {
m = std::ios::out | std::ios::binary | std::ios::ate;
- if (compare_no_case(filename,"STOUT",5) == 0)
- ostrm = &std::cout;
- else
- ostrm = new std::ofstream(filename, m);
- if (!ostrm->good())
- delete ostrm;
- throw std::runtime_error("Writing stream was not able to be created");
+ ostrm = liblas::Create(filename, m);
liblas::Header* header = ((liblas::Header*) hHeader);
liblas::Writer* writer = new liblas::Writer(*ostrm, *header);
@@ -1672,11 +1657,7 @@
return;
- if (static_cast<std::ofstream&>(*ostrm))
- static_cast<std::ofstream&>(*ostrm).close();
- if (ostrm != NULL)
- delete ostrm;
+ liblas::Cleanup(ostrm);
writers.erase(writer);
More information about the Liblas-commits
