[Liblas-commits] hg: refactor liblas::detail::reader::Header inconsistent names, ...
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Jan 25 15:04:25 EST 2011
details:   http://hg.liblas.orghg/rev/aa4c6fb279a1
changeset: 2818:aa4c6fb279a1
user:      Howard Butler <hobu.inc at gmail.com>
date:      Tue Jan 25 14:04:20 2011 -0600
description:
refactor liblas::detail::reader::Header inconsistent names, move point count validation into its own method
diffstat:
 include/liblas/detail/reader/header.hpp |    6 +-
 src/detail/reader/header.cpp            |  128 +++++++++++++++----------------
 src/detail/reader/reader.cpp            |    2 +-
 src/detail/reader/zipreader.cpp         |    2 +-
 src/factory.cpp                         |    4 +-
 5 files changed, 69 insertions(+), 73 deletions(-)
diffs (225 lines):
diff -r a9e44a39eb45 -r aa4c6fb279a1 include/liblas/detail/reader/header.hpp
--- a/include/liblas/detail/reader/header.hpp	Tue Jan 25 13:43:46 2011 -0600
+++ b/include/liblas/detail/reader/header.hpp	Tue Jan 25 14:04:20 2011 -0600
@@ -59,10 +59,12 @@
     virtual ~Header();
     HeaderPtr GetHeader() const { return m_header; }
-    void read();
-    void readvlrs();
+    void ReadHeader();
+    void ReadVLRs();
 protected:
+    void Validate();
     std::istream& m_ifs;
     HeaderPtr m_header;
diff -r a9e44a39eb45 -r aa4c6fb279a1 src/detail/reader/header.cpp
--- a/src/detail/reader/header.cpp	Tue Jan 25 13:43:46 2011 -0600
+++ b/src/detail/reader/header.cpp	Tue Jan 25 14:04:20 2011 -0600
@@ -63,7 +63,7 @@
-void Header::read()
+void Header::ReadHeader()
     using detail::read_n;
@@ -284,76 +284,13 @@
     // only go read VLRs if we have them.
     if (m_header->GetRecordsCount() > 0)
-        readvlrs();
+        ReadVLRs();
-    // Check that the point count actually describes the number of points
-    // in the file.  If it doesn't, we're going to throw an error telling
-    // the user why.  It may also be a problem that the dataoffset is
-    // really what is wrong, but there's no real way to know that unless
-    // you go start mucking around in the bytes with hexdump or od
     // If we're eof, we need to reset the state
     if (m_ifs.eof())
         m_ifs.clear();
-    // LAS 1.3 specification no longer mandates that the end of the file is the
-    // end of the points. See http://trac.liblas.org/ticket/147 for more details
-    // on this issue and why the seek can be trouble in the windows case.
-    // If you are having trouble properly seeking to the end of the stream on
-    // windows, use boost's iostreams or similar, which do not have an overflow
-    // problem.
-    if (m_header->GetVersionMinor() < 3)
-        // Seek to the beginning
-        m_ifs.seekg(0, std::ios::beg);
-        std::ios::pos_type beginning = m_ifs.tellg();
-        // Seek to the end
-        m_ifs.seekg(0, std::ios::end);
-        std::ios::pos_type end = m_ifs.tellg();
-        std::ios::off_type size = end - beginning;
-        std::ios::off_type offset = static_cast<std::ios::off_type>(m_header->GetDataOffset());
-        std::ios::off_type length = static_cast<std::ios::off_type>(m_header->GetDataRecordLength());
-        std::ios::off_type point_bytes = end - offset;
-        // Figure out how many points we have and whether or not we have
-        // extra slop in there.
-        std::ios::off_type count = point_bytes / length;
-        std::ios::off_type remainder = point_bytes % length;
-        if ( !m_header->Compressed() && m_header->GetPointRecordsCount() != static_cast<uint32_t>(count)) {
-            if (remainder == 0)
-                // The point bytes are exactly long enough, let's use it
-                // Set the count to what we calculated
-                m_header->SetPointRecordsCount(static_cast<boost::uint32_t>(count));
-            else
-                std::ostringstream msg;
-                msg <<  "The number of points in the header that was set "
-                        "by the software '" << m_header->GetSoftwareId() <<
-                        "' does not match the actual number of points in the file "
-                        "as determined by subtracting the data offset ("
-                        <<m_header->GetDataOffset() << ") from the file length ("
-                        << size <<  ") and dividing by the point record length ("
-                        << m_header->GetDataRecordLength() << ")."
-                        " It also does not perfectly contain an exact number of"
-                        " point data and we cannot infer a point count."
-                        " Calculated number of points: " << count <<
-                        " Header-specified number of points: "
-                        << m_header->GetPointRecordsCount() <<
-                        " Point data remainder: " << remainder;
-                throw std::runtime_error(msg.str());
     // Seek to the data offset so we can start reading points
     m_ifs.seekg(m_header->GetDataOffset());
@@ -405,7 +342,7 @@
     return found;
-void Header::readvlrs()
+void Header::ReadVLRs()
     VLRHeader vlrh = { 0 };
@@ -480,4 +417,61 @@
 #endif
+void Header::Validate()
+    // Check that the point count actually describes the number of points
+    // in the file.  If it doesn't, we're going to throw an error telling
+    // the user why.  It may also be a problem that the dataoffset is
+    // really what is wrong, but there's no real way to know that unless
+    // you go start mucking around in the bytes with hexdump or od
+    // LAS 1.3 specification no longer mandates that the end of the file is the
+    // end of the points. See http://trac.liblas.org/ticket/147 for more details
+    // on this issue and why the seek can be trouble in the windows case.
+    // If you are having trouble properly seeking to the end of the stream on
+    // windows, use boost's iostreams or similar, which do not have an overflow
+    // problem.
+    if (m_header->GetVersionMinor() < 3 && !m_header->Compressed() )
+        // Seek to the beginning
+        m_ifs.seekg(0, std::ios::beg);
+        std::ios::pos_type beginning = m_ifs.tellg();
+        // Seek to the end
+        m_ifs.seekg(0, std::ios::end);
+        std::ios::pos_type end = m_ifs.tellg();
+        std::ios::off_type size = end - beginning;
+        std::ios::off_type offset = static_cast<std::ios::off_type>(m_header->GetDataOffset());
+        std::ios::off_type length = static_cast<std::ios::off_type>(m_header->GetDataRecordLength());
+        std::ios::off_type point_bytes = end - offset;
+        // Figure out how many points we have and whether or not we have
+        // extra slop in there.
+        std::ios::off_type count = point_bytes / length;
+        std::ios::off_type remainder = point_bytes % length;
+        if ( m_header->GetPointRecordsCount() != static_cast<uint32_t>(count)) {
+                std::ostringstream msg;
+                msg <<  "The number of points in the header that was set "
+                        "by the software '" << m_header->GetSoftwareId() <<
+                        "' does not match the actual number of points in the file "
+                        "as determined by subtracting the data offset ("
+                        <<m_header->GetDataOffset() << ") from the file length ("
+                        << size <<  ") and dividing by the point record length ("
+                        << m_header->GetDataRecordLength() << ")."
+                        " It also does not perfectly contain an exact number of"
+                        " point data and we cannot infer a point count."
+                        " Calculated number of points: " << count <<
+                        " Header-specified number of points: "
+                        << m_header->GetPointRecordsCount() <<
+                        " Point data remainder: " << remainder;
+                throw std::runtime_error(msg.str());
 }}} // namespace liblas::detail::reader
diff -r a9e44a39eb45 -r aa4c6fb279a1 src/detail/reader/reader.cpp
--- a/src/detail/reader/reader.cpp	Tue Jan 25 13:43:46 2011 -0600
+++ b/src/detail/reader/reader.cpp	Tue Jan 25 14:04:20 2011 -0600
@@ -130,7 +130,7 @@
     if (m_ifs.eof())
         m_ifs.clear();
-    m_header_reader->read();
+    m_header_reader->ReadHeader();
     m_header = m_header_reader->GetHeader();
     if (m_header->Compressed())
diff -r a9e44a39eb45 -r aa4c6fb279a1 src/detail/reader/zipreader.cpp
--- a/src/detail/reader/zipreader.cpp	Tue Jan 25 13:43:46 2011 -0600
+++ b/src/detail/reader/zipreader.cpp	Tue Jan 25 14:04:20 2011 -0600
@@ -180,7 +180,7 @@
     if (m_ifs.eof())
         m_ifs.clear();
     if (!m_header->Compressed())
diff -r a9e44a39eb45 -r aa4c6fb279a1 src/factory.cpp
--- a/src/factory.cpp	Tue Jan 25 13:43:46 2011 -0600
+++ b/src/factory.cpp	Tue Jan 25 14:04:20 2011 -0600
@@ -74,7 +74,7 @@
 Reader ReaderFactory::CreateCached(std::istream& stream, boost::uint32_t cache_size)
     detail::HeaderReaderPtr h(new detail::reader::Header(stream));
-    h->read();
+    h->ReadHeader();
     HeaderPtr header = h->GetHeader();
     if (header->Compressed())
@@ -89,7 +89,7 @@
 Reader ReaderFactory::CreateWithStream(std::istream& stream)
-    h->read();
+    h->ReadHeader();
More information about the Liblas-commits mailing list
