[Liblas-commits] hg: update doc
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Jan 26 14:03:35 EST 2011
details:   http://hg.liblas.orghg/rev/941c259f8c63
changeset: 2826:941c259f8c63
user:      Howard Butler <hobu.inc at gmail.com>
date:      Wed Jan 26 13:03:31 2011 -0600
description:
update doc
diffstat:
 apps/laskernel.cpp |  2 +-
 1 files changed, 1 insertions(+), 1 deletions(-)
diffs (12 lines):
diff -r 9ad42bb0f010 -r 941c259f8c63 apps/laskernel.cpp
--- a/apps/laskernel.cpp	Wed Jan 26 11:51:07 2011 -0600
+++ b/apps/laskernel.cpp	Wed Jan 26 13:03:31 2011 -0600
@@ -356,7 +356,7 @@
     ("drop-returns", po::value< std::vector<boost::uint16_t> >()->multitoken(), "Return numbers to drop.\nFor example, --drop-returns 2 3 4 5")
     ("valid_only", po::value<bool>()->zero_tokens(), "Keep only valid points")
     ("keep-classes", po::value< std::vector<boost::uint32_t > >()->multitoken(), "A list of classifications to keep:\n--keep-classes 2 4 12\n--keep-classes 2")
-    ("drop-classes", po::value< std::vector<boost::uint32_t > >()->multitoken(), "A comma-separated list of classifications to drop:\n--drop-classes 1,7,8\n--drop-classes 2")
+    ("drop-classes", po::value< std::vector<boost::uint32_t > >()->multitoken(), "A list of classifications to drop:\n--drop-classes 1 7 8\n--drop-classes 2")
     ("keep-intensity", po::value< string >(), "Range in which to keep intensity.\nThe following expression types are supported:  \n--keep-intensity 0-100 \n--keep-intensity <200 \n--keep-intensity >400 \n--keep-intensity >=200")
     ("drop-intensity", po::value< string >(), "Range in which to drop intensity.\nThe following expression types are supported:  \n--drop-intensity <200 \n--drop-intensity >400 \n--drop-intensity >=200")
     ("keep-time", po::value< string >(), "Range in which to keep time.\nThe following expression types are supported:  \n--keep-time 413665.2336-414092.8462 \n--keep-time <414094.8462 \n--keep-time >413665.2336 \n--keep-time >=413665.2336")
More information about the Liblas-commits mailing list
