[Liblas-commits] laszip: consistent (and nicer) looking licensing
headers
liblas-commits at liblas.org
Fri Jan 28 09:53:41 EST 2011
details: http://hg.liblas.orglaszip/rev/b48854422090
changeset: 159:b48854422090
user: isenburg
date: Fri Jan 28 06:52:29 2011 -0800
description:
consistent (and nicer) looking licensing headers
Subject: laszip: consistent (and nicer) looking licensing headers
details: http://hg.liblas.orglaszip/rev/66f59b110640
changeset: 160:66f59b110640
user: isenburg
date: Fri Jan 28 06:53:17 2011 -0800
description:
diffstat:
include/laszip/lasunzipper.hpp | 36 ++++----------
include/laszip/laszip.hpp | 70 ++++++++++++------------------
include/laszip/laszipper.hpp | 36 ++++----------
src/arithmeticdecoder.cpp | 84 +++++++++++++++++++++++------------
src/arithmeticdecoder.hpp | 49 ++++++++------------
src/arithmeticencoder.cpp | 84 +++++++++++++++++++++++------------
src/arithmeticencoder.hpp | 57 +++++++++--------------
src/arithmeticmodel.cpp | 84 +++++++++++++++++++++++------------
src/arithmeticmodel.hpp | 56 +++++++++--------------
src/bytestreamin.hpp | 50 +++++++-------------
src/bytestreamin_file.hpp | 54 ++++++++--------------
src/bytestreamin_istream.hpp | 50 +++++++-------------
src/bytestreamout.hpp | 52 ++++++++--------------
src/bytestreamout_file.hpp | 52 ++++++++--------------
src/bytestreamout_ostream.hpp | 52 ++++++++--------------
src/entropydecoder.hpp | 50 +++++++-------------
src/entropyencoder.hpp | 50 +++++++-------------
src/integercompressor.cpp | 43 ++++++------------
src/integercompressor.hpp | 50 +++++++-------------
src/lasreaditem.hpp | 50 +++++++-------------
src/lasreaditemcompressed_v1.cpp | 44 ++++++------------
src/lasreaditemcompressed_v1.hpp | 50 +++++++-------------
src/lasreaditemraw.hpp | 50 +++++++-------------
src/lasreadpoint.cpp | 57 ++++++-----------------
src/lasreadpoint.hpp | 50 +++++++-------------
src/lasunzipper.cpp | 43 ++++++------------
src/laswriteitem.hpp | 50 +++++++-------------
src/laswriteitemcompressed_v1.cpp | 81 ++++++++++++++--------------------
src/laswriteitemcompressed_v1.hpp | 50 +++++++-------------
src/laswriteitemraw.hpp | 50 +++++++-------------
src/laswritepoint.cpp | 91 ++++++++++++++------------------------
src/laswritepoint.hpp | 52 ++++++++--------------
src/laszip.cpp | 43 ++++++------------
src/laszipper.cpp | 43 ++++++------------
src/mydefs.hpp | 85 +++++++++++++++++++++++-------------
35 files changed, 796 insertions(+), 1152 deletions(-)
diffs (truncated from 2604 to 300 lines):
diff -r 24f8c5388535 -r 66f59b110640 include/laszip/lasunzipper.hpp
--- a/include/laszip/lasunzipper.hpp Fri Jan 21 13:29:25 2011 -0600
+++ b/include/laszip/lasunzipper.hpp Fri Jan 28 06:53:17 2011 -0800
@@ -1,21 +1,3 @@
- * Project: integrating laszip into liblas - http://liblas.org -
- * Purpose:
- * Author: Martin Isenburg
- * isenburg at cs.unc.edu
- * Copyright (c) 2010, Martin Isenburg
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
@@ -27,18 +9,22 @@
PROGRAMMERS:
- martin isenburg at cs.unc.edu
+ martin.isenburg at gmail.com
COPYRIGHT:
- copyright (C) 2010 martin isenburg at cs.unc.edu
- This software is distributed in the hope that it will be useful,
- but WITHOUT ANY WARRANTY; without even the implied warranty of
- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
+ (c) 2010-2011, Martin Isenburg, LASSO - tools to catch reality
+ This is free software; you can redistribute and/or modify it under the
+ terms of the GNU Lesser General Licence as published by the Free Software
+ Foundation. See the COPYING file for more information.
+ This software is distributed WITHOUT ANY WARRANTY and without even the
+ implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
CHANGE HISTORY:
+ 10 January 2011 -- licensing change for LGPL release and liblas integration
12 December 2010 -- created from LASwriter/LASreader after Howard got pushy (-;
diff -r 24f8c5388535 -r 66f59b110640 include/laszip/laszip.hpp
--- a/include/laszip/laszip.hpp Fri Jan 21 13:29:25 2011 -0600
+++ b/include/laszip/laszip.hpp Fri Jan 28 06:53:17 2011 -0800
@@ -1,51 +1,37 @@
- * Purpose:
- FILE: laszip.hpp
- CONTENTS:
+ FILE: laszip.hpp
+ CONTENTS:
Contains LASitem and LASchunk structs as well as the IDs of the currently
- supported entropy coding scheme
+ supported entropy coding scheme
PROGRAMMERS:
COPYRIGHT:
- copyright (C) 2007 martin isenburg at cs.unc.edu
CHANGE HISTORY:
12 December 2010 -- refactored from lasdefinitions after movies with silke
-#ifndef LASZIP_H
-#define LASZIP_H
+#ifndef LASZIP_HPP
+#define LASZIP_HPP
#if defined(_MSC_VER) && (_MSC_VER < 1300)
#define LZ_WIN32_VC6
@@ -54,11 +40,12 @@
typedef long long SIGNED_INT64;
#endif
#define LASZIP_VERSION_MAJOR 1
#define LASZIP_VERSION_MINOR 0
#define LASZIP_VERSION_REVISION 0
-#include "laszipexport.hpp"
+#include "laszipexport.hpp"
class LASZIP_DLL LASitem
@@ -87,7 +74,6 @@
POINT_BY_POINT_RAW = 0,
POINT_BY_POINT_ARITHMETIC = 1,
- POINT_BY_POINT_RANGE = 2,
DEFAULT_COMPRESSION = POINT_BY_POINT_ARITHMETIC,
DEFAULT_RAW = POINT_BY_POINT_RAW
@@ -115,4 +101,4 @@
-#endif
+#endif
diff -r 24f8c5388535 -r 66f59b110640 include/laszip/laszipper.hpp
--- a/include/laszip/laszipper.hpp Fri Jan 21 13:29:25 2011 -0600
+++ b/include/laszip/laszipper.hpp Fri Jan 28 06:53:17 2011 -0800
@@ -1,21 +1,3 @@
- * Purpose:
@@ -27,18 +9,22 @@
PROGRAMMERS:
COPYRIGHT:
CHANGE HISTORY:
diff -r 24f8c5388535 -r 66f59b110640 src/arithmeticdecoder.cpp
--- a/src/arithmeticdecoder.cpp Fri Jan 21 13:29:25 2011 -0600
+++ b/src/arithmeticdecoder.cpp Fri Jan 28 06:53:17 2011 -0800
@@ -1,21 +1,3 @@
- * Purpose:
@@ -23,19 +5,23 @@
CONTENTS:
- see header file
+ A modular C++ wrapper for an adapted version of Amir Said's FastAC Code.
+ see: http://www.cipr.rpi.edu/~said/FastAC.html
- PROGRAMMERS:
- COPYRIGHT:
- copyright (C) 2009 martin isenburg (isenburg at cs.unc.edu)
+ PROGRAMMERS:
+ COPYRIGHT:
+ (c) 2011, Martin Isenburg, LASSO - tools to catch reality
CHANGE HISTORY:
@@ -43,6 +29,44 @@
+// Fast arithmetic coding implementation -
+// -> 32-bit variables, 32-bit product, periodic updates, table decoding -
+// Version 1.00 - April 25, 2004 -
+// WARNING -
+// The only purpose of this program is to demonstrate the basic principles -
+// of arithmetic coding. It is provided as is, without any express or -
More information about the Liblas-commits
