[Liblas-commits] laszip: fixed for windows
liblas-commits at liblas.org liblas-commits at liblas.org
Sun Jan 30 08:15:07 EST 2011
details:   http://hg.liblas.orglaszip/rev/322077dc0b65
changeset: 163:322077dc0b65
user:      isenburg
date:      Sun Jan 30 05:14:53 2011 -0800
description:
fixed for windows
diffstat:
 tools/laszippertest.cpp |  697 ++++++++++++++++++++++-------------------------
 1 files changed, 329 insertions(+), 368 deletions(-)
diffs (truncated from 867 to 300 lines):
diff -r 2b5efddcdb54 -r 322077dc0b65 tools/laszippertest.cpp
--- a/tools/laszippertest.cpp	Sat Jan 29 20:18:26 2011 -0600
+++ b/tools/laszippertest.cpp	Sun Jan 30 05:14:53 2011 -0800
@@ -1,46 +1,28 @@
- * Project:  integrating laszip into liblas - http://liblas.org -
- * Purpose:
- * Author:   Martin Isenburg
- *           isenburg at cs.unc.edu
- * Copyright (c) 2010, Martin Isenburg
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
-  FILE:  laszippertest.cpp
+  FILE    laszippertest.cpp
-  CONTENTS:
+  CONTENTS
-    This tool reads and writes point data in the LAS 1.X format compressed
-    or uncompressed to test the laszipper and lasunzipper interfaces.
+  This tool reads and writes point data in the LAS 1.X format compressed
+  or uncompressed to test the laszipper and lasunzipper interfaces.
-  PROGRAMMERS:
+  PROGRAMMERS
-    martin isenburg at cs.unc.edu
+  martin isenburg at cs.unc.edu
-  COPYRIGHT:
+  COPYRIGHT
-    copyright (C) 2010 martin isenburg at cs.unc.edu
-    This software is distributed in the hope that it will be useful,
-    but WITHOUT ANY WARRANTY; without even the implied warranty of
-    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
+  copyright (C) 2010 martin isenburg at cs.unc.edu
-  CHANGE HISTORY:
+  This software is distributed in the hope that it will be useful,
+  but WITHOUT ANY WARRANTY; without even the implied warranty of
+  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
-    13 December 2010 -- created to test the remodularized laszip compressor
+  CHANGE HISTORY
+  13 December 2010 -- created to test the remodularized laszip compressor
@@ -58,11 +40,10 @@
 #include <time.h>
 #include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
 #include <stdarg.h>
-//#define LASZIP_HAVE_RANGECODER
 static double taketime()
@@ -70,182 +51,180 @@
   return (double)(clock())/CLOCKS_PER_SEC;
 // abstractions for doing I/O, which support VC6 streams, modern streams, and FILE*
-struct OStream
+class OStream
 public:
-    OStream(bool use_iostream, const char* filename) :
-      m_use_iostream(use_iostream),
-      m_filename(filename),
-      ofile(NULL),
-      ostream(NULL)
+  OStream(bool use_iostream, const char* filename) :
+    m_use_iostream(use_iostream),
+    m_filename(filename),
+    ofile(NULL),
+    streamo(NULL)
+    if (m_use_iostream)
-        if (m_use_iostream)
 #ifdef LZ_WIN32_VC6
-            ofb.open(filename, ios::out);
-            ofb.setmode(filebuf::binary);
-            ostream = new ostream(&ofb);
+      ofb.open(filename, ios::out);
+      ofb.setmode(filebuf::binary);
+      streamo = new ostream(&ofb);
 #else
-            ostream = new ofstream();
-            ostream->open(filename, std::ios::out | std::ios::binary );
+      streamo = new ofstream();
+      streamo->open(filename, std::ios::out | std::ios::binary );
 #endif
-        else
-            ofile = fopen(filename, "wb");
+    else
+      ofile = fopen(filename, "wb");
-        return;
+  ~OStream()
+      delete streamo;
+#ifdef LZ_WIN32_VC6
+      ofb.close();
+#endif
+    else
+      if (ofile)
+        fclose(ofile);
-      ~OStream()
-              delete ostream;
+  bool m_use_iostream;
+  const char* m_filename;
+  FILE* ofile;
+  filebuf ofb;
 #ifdef LZ_WIN32_VC6
-              ofb.close();
-#endif
-          else
-              if (ofile)
-                  fclose(ofile);
-public:
-    bool m_use_iostream;
-    const char* m_filename;
-    FILE* ofile;
-    filebuf ofb;
-#ifdef LZ_WIN32_VC6
-    ostream* ostream;
+  ostream* streamo;
 #else
-    ofstream* ostream;
+  ofstream* streamo;
 #endif
 struct IStream
 public:
-    IStream(bool use_iostream, const char* filename) :
-      ifile(NULL),
-      istream(NULL)
+  IStream(bool use_iostream, const char* filename) :
+    ifile(NULL),
+    streami(NULL)
 #ifdef LZ_WIN32_VC6
-            ifb.open(filename, ios::in);
-            ifb.setmode(filebuf::binary);
-            istream = new istream(&ifb);
+      ifb.open(filename, ios::in);
+      ifb.setmode(filebuf::binary);
+      streami = new istream(&ifb);
 #else
-            istream = new ifstream();
-            istream->open(filename, std::ios::in | std::ios::binary );
+      streami = new ifstream();
+      streami->open(filename, std::ios::in | std::ios::binary);
 #endif
-        else
-            ifile = fopen(filename, "rb");
+    else
+      ifile = fopen(filename, "rb");
-      ~IStream()
-              delete istream;
+  ~IStream()
+      delete streami;
 #ifdef LZ_WIN32_VC6
-              ifb.close();
+      ifb.close();
 #endif
-          else
-              if (ifile)
-                  fclose(ifile);
+    else
+      if (ifile)
+        fclose(ifile);
-public:
-    FILE* ifile;
-    filebuf ifb;
+  FILE* ifile;
+  filebuf ifb;
 #ifdef LZ_WIN32_VC6
-    istream* istream;
+  istream* streami;
 #else
-    ifstream* istream;
+  ifstream* streami;
 #endif
+#define NUM_ITEMS 5
 class PointData
 public:
-    PointData()
+  PointData()
+    num_items = NUM_ITEMS;
+    items[0].type = LASitem::POINT10;
+    items[0].size = 20;
+    items[0].version = 0;
+    items[1].type = LASitem::GPSTIME11;
+    items[1].size = 8;
+    items[1].version = 0;
+    items[2].type = LASitem::RGB12;
+    items[2].size = 6;
+    items[2].version = 0;
More information about the Liblas-commits mailing list
