[Liblas-commits] laszip: added -x, to set random seed (and fix crlf)
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Jan 31 12:49:03 EST 2011
details:   http://hg.liblas.orglaszip/rev/1d04d8dfe854
changeset: 166:1d04d8dfe854
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Mon Jan 31 09:42:25 2011 -0800
description:
Subject: laszip: fix vs2010 warnings; fix crlfs
details:   http://hg.liblas.orglaszip/rev/66f2247d3ab0
changeset: 167:66f2247d3ab0
date:      Mon Jan 31 09:46:22 2011 -0800
description:
Subject: laszip: VS2010 lint
details:   http://hg.liblas.orglaszip/rev/bba0e8b23ab9
changeset: 168:bba0e8b23ab9
date:      Mon Jan 31 09:47:13 2011 -0800
description:
VS2010 lint
diffstat:
 src/bytestreamin_istream.hpp  |   510 +++++++++---------
 src/bytestreamout_ostream.hpp |   506 +++++++++---------
 src/laszip.cpp                |   382 +++++++-------
 tools/laszippertest.cpp       |  1089 ++++++++++++++++++++--------------------
 4 files changed, 1248 insertions(+), 1239 deletions(-)
diffs (truncated from 2543 to 300 lines):
diff -r bdef75161817 -r bba0e8b23ab9 src/bytestreamin_istream.hpp
--- a/src/bytestreamin_istream.hpp	Mon Jan 31 08:50:56 2011 -0800
+++ b/src/bytestreamin_istream.hpp	Mon Jan 31 09:47:13 2011 -0800
@@ -5,269 +5,271 @@
   CONTENTS:
-  PROGRAMMERS:
-    martin.isenburg at gmail.com
-  COPYRIGHT:
-    (c) 2010-2011, Martin Isenburg, LASSO - tools to catch reality
-    This is free software; you can redistribute and/or modify it under the
-    terms of the GNU Lesser General Licence as published by the Free Software
-    Foundation. See the COPYING file for more information.
-    This software is distributed WITHOUT ANY WARRANTY and without even the
-    implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
-  CHANGE HISTORY:
-    10 January 2011 -- licensing change for LGPL release and liblas integration
-    12 December 2010 -- created from ByteStreamOutFile after Howard got pushy (-;
+  PROGRAMMERS:
+    martin.isenburg at gmail.com
+  COPYRIGHT:
+    (c) 2010-2011, Martin Isenburg, LASSO - tools to catch reality
+    This is free software; you can redistribute and/or modify it under the
+    terms of the GNU Lesser General Licence as published by the Free Software
+    Foundation. See the COPYING file for more information.
+    This software is distributed WITHOUT ANY WARRANTY and without even the
+    implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
+  CHANGE HISTORY:
+    10 January 2011 -- licensing change for LGPL release and liblas integration
+    12 December 2010 -- created from ByteStreamOutFile after Howard got pushy (-;
 #ifndef BYTE_STREAM_IN_ISTREAM_H
 #define BYTE_STREAM_IN_ISTREAM_H
-#include "bytestreamin.hpp"
-#ifdef LZ_WIN32_VC6
-#include <fstream.h>
-#else
-#include <istream>
-#include <fstream>
-using namespace std;
-#endif
+#include "bytestreamin.hpp"
+#ifdef LZ_WIN32_VC6
+#include <fstream.h>
+#else
+#include <istream>
+#include <fstream>
+using namespace std;
+#endif
 class ByteStreamInIstream : public ByteStreamIn
-public:
-  ByteStreamInIstream(istream& stream);
-/* read a single byte                                        */
+public:
+  ByteStreamInIstream(istream& stream);
+/* read a single byte                                        */
   unsigned int getByte();
-/* read an array of bytes                                    */
-  bool getBytes(unsigned char* bytes, unsigned int num_bytes);
-/* is the stream seekable (e.g. standard in is not)          */
-  bool isSeekable() const;
-/* returns how many bytes were read since last reset         */
-  unsigned int byteCount() const;
-/* reset byte counter                                        */
-  void resetCount();
-/* destructor                                                */
-  ~ByteStreamInIstream(){};
-protected:
-  istream& stream;
-private:
-  long start;
-#else
-  ios::off_type start;
-#endif
+/* read an array of bytes                                    */
+  bool getBytes(unsigned char* bytes, unsigned int num_bytes);
+/* is the stream seekable (e.g. standard in is not)          */
+  bool isSeekable() const;
+/* returns how many bytes were read since last reset         */
+  unsigned int byteCount() const;
+/* reset byte counter                                        */
+  void resetCount();
+/* destructor                                                */
+  ~ByteStreamInIstream(){};
+protected:
+  istream& stream;
+private:
+  long start;
+#else
+  ios::off_type start;
+#endif
+private:
+    ByteStreamInIstream& operator=(ByteStreamInIstream const& rhs); // not implemented
-class ByteStreamInIstreamLE : public ByteStreamInIstream
-public:
-  ByteStreamInIstreamLE(istream& stream);
-/* read 16 bit low-endian field                              */
-  bool get16bitsLE(unsigned char* bytes);
-/* read 32 bit low-endian field                              */
-  bool get32bitsLE(unsigned char* bytes);
-/* read 64 bit low-endian field                              */
-  bool get64bitsLE(unsigned char* bytes);
-/* read 16 bit big-endian field                              */
-  bool get16bitsBE(unsigned char* bytes);
-/* read 32 bit big-endian field                              */
-  bool get32bitsBE(unsigned char* bytes);
-/* read 64 bit big-endian field                              */
-  bool get64bitsBE(unsigned char* bytes);
-private:
-  unsigned char swapped[8];
-class ByteStreamInIstreamBE : public ByteStreamInIstream
-public:
-  ByteStreamInIstreamBE(istream& stream);
-private:
-inline ByteStreamInIstream::ByteStreamInIstream(istream& stream_param) :
-  stream(stream_param)
-  resetCount();
-inline unsigned int ByteStreamInIstream::getByte()
-  int byte = stream.get();
-  if (stream.eof())
-//    fprintf(stderr, "reading EOF\n");
-    byte = 0;
-  return (unsigned int)byte;
-inline bool ByteStreamInIstream::getBytes(unsigned char* bytes, unsigned int num_bytes)
-  stream.read((char*)bytes, num_bytes);
-  return !!(stream.good());
-inline bool ByteStreamInIstream::isSeekable() const
-  return (!!(static_cast<ifstream&>(stream)));
-inline unsigned int ByteStreamInIstream::byteCount() const
-  return (stream.tellg() - start);
-#else
-  ios::pos_type end = stream.tellg();
-  ios::off_type size = end - start;
-  return static_cast<unsigned int>(size);
-#endif
-inline void ByteStreamInIstream::resetCount()
-  start = stream.tellg();
-inline ByteStreamInIstreamLE::ByteStreamInIstreamLE(istream& stream) : ByteStreamInIstream(stream)
-inline bool ByteStreamInIstreamLE::get16bitsLE(unsigned char* bytes)
-  return getBytes(bytes, 2);
-inline bool ByteStreamInIstreamLE::get32bitsLE(unsigned char* bytes)
-  return getBytes(bytes, 4);
-inline bool ByteStreamInIstreamLE::get64bitsLE(unsigned char* bytes)
-  return getBytes(bytes, 8);
-inline bool ByteStreamInIstreamLE::get16bitsBE(unsigned char* bytes)
-  if (getBytes(swapped, 2))
-    bytes[0] = swapped[1];
-    bytes[1] = swapped[0];
-    return true;
-  return false;
-inline bool ByteStreamInIstreamLE::get32bitsBE(unsigned char* bytes)
-  if (getBytes(swapped, 4))
-    bytes[0] = swapped[3];
-    bytes[1] = swapped[2];
-    bytes[2] = swapped[1];
-    bytes[3] = swapped[0];
-    return true;
-  return false;
-inline bool ByteStreamInIstreamLE::get64bitsBE(unsigned char* bytes)
-  if (getBytes(swapped, 8))
-    bytes[0] = swapped[7];
-    bytes[1] = swapped[6];
-    bytes[2] = swapped[5];
-    bytes[3] = swapped[4];
-    bytes[4] = swapped[3];
-    bytes[5] = swapped[2];
-    bytes[6] = swapped[1];
-    bytes[7] = swapped[0];
-    return true;
-  return false;
-inline ByteStreamInIstreamBE::ByteStreamInIstreamBE(istream& stream) : ByteStreamInIstream(stream)
-inline bool ByteStreamInIstreamBE::get16bitsLE(unsigned char* bytes)
-    return true;
-  return false;
-inline bool ByteStreamInIstreamBE::get32bitsLE(unsigned char* bytes)
-    return true;
-  return false;
-inline bool ByteStreamInIstreamBE::get64bitsLE(unsigned char* bytes)
More information about the Liblas-commits mailing list
