[Liblas-commits] hg: LASzip should be optional, not required
liblas-commits at liblas.org
Fri Jul 1 13:28:36 EDT 2011
details: http://hg.liblas.orghg/rev/a1a0a7014028
changeset: 3062:a1a0a7014028
user: Howard Butler <hobu.inc at gmail.com>
date: Fri Jul 01 12:28:28 2011 -0500
description:
diffstat:
CMakeLists.txt | 21 +++++++++++----------
1 files changed, 11 insertions(+), 10 deletions(-)
diffs (33 lines):
diff -r 08f64fd1e2a1 -r a1a0a7014028 CMakeLists.txt
--- a/CMakeLists.txt Fri Jul 01 10:11:48 2011 -0500
+++ b/CMakeLists.txt Fri Jul 01 12:28:28 2011 -0500
@@ -197,18 +197,19 @@
set(WITH_STATIC_LASZIP FALSE CACHE BOOL "Choose of LASzip should be statically linked")
mark_as_advanced(WITH_STATIC_LASZIP)
-find_package(LASzip 2.0.0)
-if(LASZIP_FOUND)
- set(CMAKE_REQUIRED_LIBRARIES ${LASZIP_LIBRARY})
- include_directories(${LASZIP_INCLUDE_DIR})
- add_definitions(-DHAVE_LASZIP=1)
- mark_as_advanced(CLEAR LASZIP_INCLUDE_DIR)
- mark_as_advanced(CLEAR LASZIP_LIBRARY)
- mark_as_advanced(CLEAR LASZIP_VERSION)
- set(WITH_LASZIP TRUE CACHE BOOL "Choose if LASzip support should be built" FORCE)
+if (WITH_LASZIP)
+ find_package(LASzip 2.0.1)
+ if(LASZIP_FOUND)
+ set(CMAKE_REQUIRED_LIBRARIES ${LASZIP_LIBRARY})
+ include_directories(${LASZIP_INCLUDE_DIR})
+ add_definitions(-DHAVE_LASZIP=1)
+ mark_as_advanced(CLEAR LASZIP_INCLUDE_DIR)
+ mark_as_advanced(CLEAR LASZIP_LIBRARY)
+ mark_as_advanced(CLEAR LASZIP_VERSION)
+ endif()
endif()
# GDAL/OGR support - optional, default=OFF
set(WITH_GDAL FALSE CACHE BOOL "Choose if GDAL support should be built")
More information about the Liblas-commits
