[Liblas-commits] hg: add a comparison cast to silence warning
liblas-commits at liblas.org
Fri Jul 1 14:56:32 EDT 2011
details: http://hg.liblas.orghg/rev/358777fe89bf
changeset: 3065:358777fe89bf
user: Howard Butler <hobu.inc at gmail.com>
date: Fri Jul 01 13:56:28 2011 -0500
description:
diffstat:
src/detail/writer/header.cpp | 7 ++++---
1 files changed, 4 insertions(+), 3 deletions(-)
diffs (17 lines):
diff -r 2beedf2e9e48 -r 358777fe89bf src/detail/writer/header.cpp
--- a/src/detail/writer/header.cpp Fri Jul 01 13:39:11 2011 -0500
+++ b/src/detail/writer/header.cpp Fri Jul 01 13:56:28 2011 -0500
@@ -171,9 +171,10 @@
int32_t d = abs(existing_padding);
- // overflowed here
- boost::int32_t new_padding = d - m_header.GetVLRBlockSize();
- if (m_header.GetVLRBlockSize() > d)
+ // If our required VLR space is larger than we have
+ // room for, we have no padding. AddVLRs will take care
+ // of incrementing up the space it needs.
+ if (static_cast<boost::int32_t>(m_header.GetVLRBlockSize()) > d)
m_header.SetHeaderPadding(0);
} else {
More information about the Liblas-commits
