[Liblas-commits] hg-main-tree: cleanups
liblas-commits at liblas.org
Thu Jul 14 16:11:45 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/cc83cbdc225c
changeset: 862:cc83cbdc225c
user: Michael P. Gerlek <mpg at flaxen.com>
date: Thu Jul 14 13:11:40 2011 -0700
description:
cleanups
diffstat:
include/pdal/StageFactory.hpp | 51 ++++++++++++++++++++++++++++-------------
src/StageFactory.cpp | 52 +++++++++++++++++++-----------------------
2 files changed, 59 insertions(+), 44 deletions(-)
diffs (212 lines):
diff -r 2194feefd1a9 -r cc83cbdc225c include/pdal/StageFactory.hpp
--- a/include/pdal/StageFactory.hpp Thu Jul 14 12:24:37 2011 -0700
+++ b/include/pdal/StageFactory.hpp Thu Jul 14 13:11:40 2011 -0700
@@ -55,13 +55,31 @@
class Options;
+// This class provides a mechanism for creating Stage objects using only a
+// string (the stage type name) and an Options block.
+// We keep a list of (stage type name, creation function) pairs, which
+// acts as a registry of creator functions. The list is initialized with
+// the core stages we know about (I wish C++ had anonymous functions.).
+// We allow the user to add his own "external" drivers to the registry list
+// as well.
+// We use 4 different functions for each kind of operation, since we have
+// 4 types of derived classes from Stage and they all have slightly different
+// parameters. That makes it kinda messy.
class PDAL_DLL StageFactory
public:
- typedef Reader* readerCreatorFunction(const Options&);
- typedef Filter* filterCreatorFunction(const Stage& prevStage, const Options&);
- typedef MultiFilter* multifilterCreatorFunction(const std::vector<const Stage*>& prevStage, const Options&);
- typedef Writer* writerCreatorFunction(const Stage& prevStage, const Options&);
+ typedef Reader* ReaderCreator(const Options&);
+ typedef Filter* FilterCreator(const Stage& prevStage, const Options&);
+ typedef MultiFilter* MultiFilterCreator(const std::vector<const Stage*>& prevStage, const Options&);
+ typedef Writer* WriterCreator(const Stage& prevStage, const Options&);
+ typedef std::map<std::string, ReaderCreator*> ReaderCreatorList;
+ typedef std::map<std::string, FilterCreator*> FilterCreatorList;
+ typedef std::map<std::string, MultiFilterCreator*> MultiFilterCreatorList;
+ typedef std::map<std::string, WriterCreator*> WriterCreatorList;
public:
StageFactory();
@@ -71,23 +89,24 @@
boost::shared_ptr<MultiFilter> createMultiFilter(const std::string& type, const std::vector<const Stage*>& prevStage, const Options& options);
boost::shared_ptr<Writer> createWriter(const std::string& type, const Stage& prevStage, const Options& options);
- void registerReader(const std::string& type, readerCreatorFunction* f);
- void registerFilter(const std::string& type, filterCreatorFunction* f);
- void registerMultiFilter(const std::string& type, multifilterCreatorFunction* f);
- void registerWriter(const std::string& type, writerCreatorFunction* f);
+ void registerReader(const std::string& type, ReaderCreator* f);
+ void registerFilter(const std::string& type, FilterCreator* f);
+ void registerMultiFilter(const std::string& type, MultiFilterCreator* f);
+ void registerWriter(const std::string& type, WriterCreator* f);
private:
- readerCreatorFunction* getReaderCreator(const std::string& type);
- filterCreatorFunction* getFilterCreator(const std::string& type);
- multifilterCreatorFunction* getMultiFilterCreator(const std::string& type);
- writerCreatorFunction* getWriterCreator(const std::string& type);
+ ReaderCreator* getReaderCreator(const std::string& type);
+ FilterCreator* getFilterCreator(const std::string& type);
+ MultiFilterCreator* getMultiFilterCreator(const std::string& type);
+ WriterCreator* getWriterCreator(const std::string& type);
void registerKnownStages();
- std::map<std::string, readerCreatorFunction*> m_readerCreators;
- std::map<std::string, filterCreatorFunction*> m_filterCreators;
- std::map<std::string, multifilterCreatorFunction*> m_multifilterCreators;
- std::map<std::string, writerCreatorFunction*> m_writerCreators;
+ // these are the "registries" of the factory creator functions
+ ReaderCreatorList m_readerCreators;
+ FilterCreatorList m_filterCreators;
+ MultiFilterCreatorList m_multifilterCreators;
+ WriterCreatorList m_writerCreators;
StageFactory& operator=(const StageFactory&); // not implemented
StageFactory(const StageFactory&); // not implemented
diff -r 2194feefd1a9 -r cc83cbdc225c src/StageFactory.cpp
--- a/src/StageFactory.cpp Thu Jul 14 12:24:37 2011 -0700
+++ b/src/StageFactory.cpp Thu Jul 14 13:11:40 2011 -0700
@@ -68,10 +68,6 @@
namespace pdal
-// We keep a list of (driver name, creation function) pairs. The list is
-// initialized with the core stages we know about, and we allow the user
-// to add more to it. (I wish C++ had anonymous functions.)
static Reader* create_drivers_faux_reader(const Options& options) { return new pdal::drivers::faux::Reader(options); }
static Reader* create_drivers_las_reader(const Options& options) { return new pdal::drivers::las::LasReader(options); }
static Reader* create_drivers_liblas_reader(const Options& options) { return new pdal::drivers::liblas::LiblasReader(options); }
@@ -106,7 +102,7 @@
boost::shared_ptr<Reader> StageFactory::createReader(const std::string& type, const Options& options)
- readerCreatorFunction* f = getReaderCreator(type);
+ ReaderCreator* f = getReaderCreator(type);
Reader* stage = f(options);
boost::shared_ptr<Reader> ptr(stage);
return ptr;
@@ -115,7 +111,7 @@
boost::shared_ptr<Filter> StageFactory::createFilter(const std::string& type, const Stage& prevStage, const Options& options)
- filterCreatorFunction* f = getFilterCreator(type);
+ FilterCreator* f = getFilterCreator(type);
Filter* stage = f(prevStage, options);
boost::shared_ptr<Filter> ptr(stage);
return ptr;
@@ -124,7 +120,7 @@
boost::shared_ptr<MultiFilter> StageFactory::createMultiFilter(const std::string& type, const std::vector<const Stage*>& prevStages, const Options& options)
- multifilterCreatorFunction* f = getMultiFilterCreator(type);
+ MultiFilterCreator* f = getMultiFilterCreator(type);
MultiFilter* stage = f(prevStages, options);
boost::shared_ptr<MultiFilter> ptr(stage);
return ptr;
@@ -133,73 +129,73 @@
boost::shared_ptr<Writer> StageFactory::createWriter(const std::string& type, const Stage& prevStage, const Options& options)
- writerCreatorFunction* f = getWriterCreator(type);
+ WriterCreator* f = getWriterCreator(type);
Writer* stage = f(prevStage, options);
boost::shared_ptr<Writer> ptr(stage);
return ptr;
-StageFactory::readerCreatorFunction* StageFactory::getReaderCreator(const std::string& type)
+StageFactory::ReaderCreator* StageFactory::getReaderCreator(const std::string& type)
- std::map<std::string, readerCreatorFunction*>::const_iterator iter = m_readerCreators.find(type);
+ ReaderCreatorList::const_iterator iter = m_readerCreators.find(type);
if (iter == m_readerCreators.end()) throw pdal_error("unknown reader stage type");
- readerCreatorFunction* f = iter->second;
+ ReaderCreator* f = iter->second;
return f;
-StageFactory::filterCreatorFunction* StageFactory::getFilterCreator(const std::string& type)
+StageFactory::FilterCreator* StageFactory::getFilterCreator(const std::string& type)
- std::map<std::string, filterCreatorFunction*>::const_iterator iter = m_filterCreators.find(type);
+ FilterCreatorList::const_iterator iter = m_filterCreators.find(type);
if (iter == m_filterCreators.end()) throw pdal_error("unknown filter stage type");
- filterCreatorFunction* f = iter->second;
+ FilterCreator* f = iter->second;
return f;
-StageFactory::multifilterCreatorFunction* StageFactory::getMultiFilterCreator(const std::string& type)
+StageFactory::MultiFilterCreator* StageFactory::getMultiFilterCreator(const std::string& type)
- std::map<std::string, multifilterCreatorFunction*>::const_iterator iter = m_multifilterCreators.find(type);
+ MultiFilterCreatorList::const_iterator iter = m_multifilterCreators.find(type);
if (iter == m_multifilterCreators.end()) throw pdal_error("unknown multifilter stage type");
- multifilterCreatorFunction* f = iter->second;
+ MultiFilterCreator* f = iter->second;
return f;
-StageFactory::writerCreatorFunction* StageFactory::getWriterCreator(const std::string& type)
+StageFactory::WriterCreator* StageFactory::getWriterCreator(const std::string& type)
- std::map<std::string, writerCreatorFunction*>::const_iterator iter = m_writerCreators.find(type);
+ WriterCreatorList::const_iterator iter = m_writerCreators.find(type);
if (iter == m_writerCreators.end()) throw pdal_error("unknown writer stage type");
- writerCreatorFunction* f = iter->second;
+ WriterCreator* f = iter->second;
return f;
-void StageFactory::registerReader(const std::string& type, readerCreatorFunction* f)
+void StageFactory::registerReader(const std::string& type, ReaderCreator* f)
- std::pair<std::string, readerCreatorFunction*> p(type, f);
+ std::pair<std::string, ReaderCreator*> p(type, f);
m_readerCreators.insert(p);
-void StageFactory::registerFilter(const std::string& type, filterCreatorFunction* f)
+void StageFactory::registerFilter(const std::string& type, FilterCreator* f)
- std::pair<std::string, filterCreatorFunction*> p(type, f);
+ std::pair<std::string, FilterCreator*> p(type, f);
m_filterCreators.insert(p);
-void StageFactory::registerMultiFilter(const std::string& type, multifilterCreatorFunction* f)
+void StageFactory::registerMultiFilter(const std::string& type, MultiFilterCreator* f)
- std::pair<std::string, multifilterCreatorFunction*> p(type, f);
+ std::pair<std::string, MultiFilterCreator*> p(type, f);
m_multifilterCreators.insert(p);
-void StageFactory::registerWriter(const std::string& type, writerCreatorFunction* f)
+void StageFactory::registerWriter(const std::string& type, WriterCreator* f)
- std::pair<std::string, writerCreatorFunction*> p(type, f);
+ std::pair<std::string, WriterCreator*> p(type, f);
m_writerCreators.insert(p);
More information about the Liblas-commits
