[Liblas-commits] hg-main-tree: typo in include guard
liblas-commits at liblas.org
Thu Jul 21 10:31:20 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/bc9079e7322d
changeset: 895:bc9079e7322d
user: Michael P. Gerlek <mpg at flaxen.com>
date: Wed Jul 20 21:27:19 2011 -0700
description:
Subject: hg-main-tree: improved Options class (from big backed-out commit)
details: http://hg.libpc.orghg-main-tree/rev/ce971170c2c9
changeset: 896:ce971170c2c9
date: Wed Jul 20 21:41:16 2011 -0700
description:
Subject: hg-main-tree: restore (much of) StageFactory class (from big backed-out commit)
details: http://hg.libpc.orghg-main-tree/rev/bf222e7712a6
changeset: 897:bf222e7712a6
date: Wed Jul 20 22:18:54 2011 -0700
description:
Subject: hg-main-tree: restore (much of) PipelineManager class (from big backed-out commit)
details: http://hg.libpc.orghg-main-tree/rev/146bb39ba8a8
changeset: 898:146bb39ba8a8
date: Wed Jul 20 22:34:45 2011 -0700
description:
diffstat:
include/pdal/Options.hpp | 132 +++++++--
include/pdal/PipelineManager.hpp | 54 ++-
include/pdal/StageFactory.hpp | 16 +-
include/pdal/drivers/terrasolid/Iterator.hpp | 4 +-
include/pdal/exceptions.hpp | 10 +
src/Options.cpp | 52 ++-
src/PipelineManager.cpp | 337 +++++++++++++++++++++++++-
src/StageFactory.cpp | 60 ++--
src/drivers/qfit/Reader.cpp | 2 +-
test/unit/OptionsTest.cpp | 96 ++++++-
test/unit/PipelineManagerTest.cpp | 33 ++-
test/unit/StageFactoryTest.cpp | 38 +-
12 files changed, 651 insertions(+), 183 deletions(-)
diffs (truncated from 1279 to 300 lines):
diff -r bd90f06866ef -r 146bb39ba8a8 include/pdal/Options.hpp
--- a/include/pdal/Options.hpp Wed Jul 20 13:29:32 2011 -0700
+++ b/include/pdal/Options.hpp Wed Jul 20 22:34:45 2011 -0700
@@ -36,8 +36,10 @@
#define INCLUDED_OPTIONS_HPP
#include <pdal/pdal.hpp>
+#include <pdal/exceptions.hpp>
#include <pdal/Bounds.hpp>
#include <boost/property_tree/ptree.hpp>
+#include <boost/property_tree/xml_parser.hpp>
namespace pdal
@@ -46,17 +48,16 @@
class PDAL_DLL OptionsOld
private:
boost::property_tree::ptree m_tree;
public:
- OptionsOld();
+ OptionsOld()
+ m_tree.put("is3d", false);
OptionsOld(boost::property_tree::ptree const& tree) { m_tree = tree; }
- //template<class T> void add(Option<T> const& option) { m_tree.put_child(option.getTree()); }
- //template<class T> Option<T> const& get(std::string const& name) { return m_tree.get<T>(name); }
boost::property_tree::ptree& GetPTree() { return m_tree; }
boost::property_tree::ptree const& GetPTree() const { return m_tree; }
@@ -66,34 +67,63 @@
// Dumped as XML, it looks like this:
// <?xml...>
-// <name>my name</name>
-// <description>my descr</description>
-// <value>17</value>
+// <Name>myname</Name>
+// <Description>my descr</Description>
+// <Value>17</Value>
// although of course that's not valid XML, since it has no single root element.
template <typename T>
public:
- Option(std::string const& name, T value, std::string const& description)
+ // construct it manually
+ Option(std::string const& name, T value, std::string const& description="")
: m_name(name)
, m_description(description)
, m_value(value)
+ // construct it from an xml stream
+ Option(std::istream& istr)
+ boost::property_tree::ptree t;
+ boost::property_tree::xml_parser::read_xml(istr, t);
+ m_name = t.get<std::string>("Name");
+ m_value = t.get<T>("Value");
+ m_description = t.get<std::string>("Description", "");
+ // construct it from a ptree
+ Option(const boost::property_tree::ptree t)
+ // getters
std::string const& getName() const { return m_name; }
std::string const& getDescription() const { return m_description; }
T const& getValue() const { return m_value; }
- boost::property_tree::ptree getPTree() const
+ // return a ptree representation
+ boost::property_tree::ptree getPTree() const
- t.put("name", getName());
- t.put("description", getDescription());
- t.put("value", getValue());
+ t.put("Name", getName());
+ t.put("Description", getDescription());
+ t.put("Value", getValue());
return t;
+ // return an xml representation
+ void write_xml(std::ostream& ostr) const
+ const boost::property_tree::ptree tree = getPTree();
+ boost::property_tree::xml_parser::write_xml(ostr, tree);
+ return;
private:
std::string m_name;
std::string m_description;
@@ -108,12 +138,12 @@
// Dumped as XML, an Options object with two Option objects looks like this:
// <?xml...>
// <option>
+// <name>myname</name>
// </option>
// <option>
-// <name>my name2</name>
+// <name>myname2</name>
// <description>my descr2</description>
// <value>13</value>
// </option>
@@ -121,47 +151,79 @@
public:
- Options();
+ // defult ctor, empy options list
+ Options() {}
+ Options(boost::property_tree::ptree t);
+ // read options from an xml stream
+ Options(std::istream& istr);
// add an option
boost::property_tree::ptree fields = option.getPTree();
- m_tree.add_child("option", fields);
+ m_tree.add_child("Option", fields);
// add an option (shortcut version, bypass need for an Option object)
- template<class T> void add(const std::string& name, T value, const std::string& description)
+ template<class T> void add(const std::string& name, T value, const std::string& description="")
Option<T> opt(name, value, description);
add(opt);
- // get value of an option
- template<class T> T getValue(std::string const& name) const
+ // get an option, by name
+ // throws pdal::option_not_found if the option name is not valid
+ template<typename T> Option<T> getOption(std::string const& name) const
- try
+ boost::property_tree::ptree::const_iterator iter = m_tree.begin();
+ while (iter != m_tree.end())
- boost::property_tree::ptree optionTree = getOptionPTree(name);
- return optionTree.get_child("value").get_value<T>();
- } catch (boost::property_tree::ptree_bad_path const&)
- return T();
+ if (iter->first != "Option")
+ throw pdal_error("malformed Options ptree");
+ const boost::property_tree::ptree& optionTree = iter->second;
+ if (optionTree.get_child("Name").get_value<std::string>() == name)
+ Option<T> option(optionTree);
+ return option;
+ ++iter;
+ throw option_not_found(name);
- // get description of an option
- std::string getDescription(std::string const& name) const;
- boost::property_tree::ptree const& getPTree() const;
+ // returns true iff the option name is valid
+ template<typename T> bool hasOption(std::string const& name) const
+ bool ok = false;
+ try
+ Option<T> option = getOption<T>(name);
+ ok = true;
+ catch (option_not_found&)
+ ok = false;
+ // any other exception will bubble up
+ return ok;
+ // get the ptree for the whole option block
+ const boost::property_tree::ptree& getPTree() const;
- // return the empty options list
+ // the empty options list
+ // BUG: this should be a member variable, not a function, but doing so causes vs2010 to fail to link
static const Options& none();
private:
- boost::property_tree::ptree getOptionPTree(std::string const& name) const;
+ // get the ptree for an option
+ const boost::property_tree::ptree getOptionPTree(const std::string& name) const;
diff -r bd90f06866ef -r 146bb39ba8a8 include/pdal/PipelineManager.hpp
--- a/include/pdal/PipelineManager.hpp Wed Jul 20 13:29:32 2011 -0700
+++ b/include/pdal/PipelineManager.hpp Wed Jul 20 22:34:45 2011 -0700
@@ -35,50 +35,56 @@
#ifndef INCLUDED_PIPELINEMANAGER_HPP
#define INCLUDED_PIPELINEMANAGER_HPP
+#include <pdal/pdal.hpp>
+#include <pdal/StageFactory.hpp>
+#include <boost/shared_ptr.hpp>
#include <vector>
-#include <pdal/Stage.hpp>
-#include <pdal/Filter.hpp>
-#include <pdal/Writer.hpp>
+#include <map>
+#include <string>
namespace pdal
-class OptionsNew;
+class Options;
class PDAL_DLL PipelineManager
public:
PipelineManager();
+ ~PipelineManager();
- boost::uint32_t addReader(const std::string& type, const OptionsNew&);
- boost::uint32_t addFilter(const std::string& type, boost::uint32_t prevStage, const OptionsNew&);
- boost::uint32_t addFilter(const std::string& type, const std::vector<boost::uint32_t>& prevStages, const OptionsNew&);
- boost::uint32_t addWriter(const std::string& type, boost::uint32_t prevStage, const OptionsNew&);
+ Reader* addReader(const std::string& type, const Options&);
+ Filter* addFilter(const std::string& type, const Stage& prevStage, const Options&);
+ MultiFilter* addMultiFilter(const std::string& type, const std::vector<const Stage*>& prevStages, const Options&);
+ Writer* addWriter(const std::string& type, const Stage& prevStage, const Options&);
- Stage* getStage(boost::uint32_t);
- Filter* getFilter(boost::uint32_t);
- Writer* getWriter(boost::uint32_t);
- typedef Stage* readerCreatorFunction(const OptionsNew&);
- typedef Filter* filter1CreatorFunction(boost::uint32_t prevStage, const OptionsNew&);
- typedef Filter* filterNCreatorFunction(const std::vector<boost::uint32_t>& prevStage, const OptionsNew&);
- typedef Writer* writerCreatorFunction(boost::uint32_t prevStage, const OptionsNew&);
- void registerReader(const std::string& type, readerCreatorFunction);
- void registerFilter(const std::string& type, filter1CreatorFunction);
- void registerFilter(const std::string& type, filterNCreatorFunction);
- void registerWriter(const std::string& type, writerCreatorFunction);
+ void readXml(const std::string&);
private:
- void registerKnownReaders();
- void registerKnownFilters();
- void registerKnownWriters();
+ void parsePipeline(const boost::property_tree::ptree&, Writer*& writer, Stage*& stage);
+ Reader* parseReader(const boost::property_tree::ptree& tree);
+ Filter* parseFilter(const boost::property_tree::ptree& tree);
+ MultiFilter* parseMultiFilter(const boost::property_tree::ptree& tree);
+ Writer* parseWriter(const boost::property_tree::ptree& tree);
+ Option<std::string> parseOption(const boost::property_tree::ptree& tree);
+ std::string parseType(const boost::property_tree::ptree& tree);
+ StageFactory m_factory;
+ //typedef std::vector<StagePtr> StagePtrList;
+ //StagePtrList m_stages;
PipelineManager& operator=(const PipelineManager&); // not implemented
More information about the Liblas-commits
