[Liblas-commits] hg-main-tree: fix up ScalingFilter to copy non-XYZ
data, appears...
liblas-commits at liblas.org
Thu Jul 21 14:30:32 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/9df6751d8129
changeset: 905:9df6751d8129
user: Howard Butler <hobu.inc at gmail.com>
date: Thu Jul 21 13:25:24 2011 -0500
description:
fix up ScalingFilter to copy non-XYZ data, appears to work now
Subject: hg-main-tree: remove lint
details: http://hg.libpc.orghg-main-tree/rev/66539fbcbfab
changeset: 906:66539fbcbfab
date: Thu Jul 21 13:25:33 2011 -0500
description:
remove lint
details: http://hg.libpc.orghg-main-tree/rev/a7d8a462ad9b
changeset: 907:a7d8a462ad9b
date: Thu Jul 21 13:28:46 2011 -0500
description:
remove lint
Subject: hg-main-tree: merge
details: http://hg.libpc.orghg-main-tree/rev/fa41ca1b1b9c
changeset: 908:fa41ca1b1b9c
date: Thu Jul 21 13:30:25 2011 -0500
description:
merge
diffstat:
include/pdal/PointBuffer.hpp | 2 +-
src/filters/ScalingFilter.cpp | 44 ++++++++++++++++++++++++++--------------
test/unit/ScalingFilterTest.cpp | 14 ++++++------
3 files changed, 36 insertions(+), 24 deletions(-)
diffs (138 lines):
diff -r 9ad3e85bd7c1 -r fa41ca1b1b9c include/pdal/PointBuffer.hpp
--- a/include/pdal/PointBuffer.hpp Thu Jul 21 11:45:36 2011 -0500
+++ b/include/pdal/PointBuffer.hpp Thu Jul 21 13:30:25 2011 -0500
@@ -204,7 +204,7 @@
Dimension const& d = dl.getDimension();
std::size_t offset = (pointIndex * m_pointSize) + dl.getByteOffset();
std::size_t size = d.getDataTypeSize(d.getDataType());
- std::cout << "copying field " << fieldIndex << " of size " << size << " at offset " << offset << std::endl;
+ // std::cout << "copying field " << d.getFieldName() << " with index" << fieldIndex << " of size " << size << " at offset " << offset << std::endl;
// assert(offset + sizeof(T) <= m_pointSize * m_capacity);
boost::uint8_t* p = m_data.get() + offset;
diff -r 9ad3e85bd7c1 -r fa41ca1b1b9c src/filters/ScalingFilter.cpp
--- a/src/filters/ScalingFilter.cpp Thu Jul 21 11:45:36 2011 -0500
+++ b/src/filters/ScalingFilter.cpp Thu Jul 21 13:30:25 2011 -0500
@@ -229,10 +229,6 @@
// rather than think about "src/dst", we will think in terms of "doubles" and "ints"
const Schema& schemaD = (m_forward ? srcSchema : dstSchema);
const Schema& schemaI = (m_forward ? dstSchema : srcSchema);
- // std::cout << " Source Schema: " << std::endl << srcSchema << std::endl;
- // std::cout << " DST Schema: " << std::endl << dstSchema << std::endl;
assert(schemaD.hasDimension(Dimension::Field_X, Dimension::Double));
assert(schemaI.hasDimension(Dimension::Field_X, Dimension::Int32));
@@ -268,6 +264,28 @@
const boost::int32_t yi = dimYi.removeScaling<boost::int32_t>(yd);
const boost::int32_t zi = dimZi.removeScaling<boost::int32_t>(zd);
+ const boost::uint8_t* src_raw_data = srcData.getData(pointIndex);
+ boost::uint8_t* dst_raw_data = dstData.getData(pointIndex);
+ boost::uint32_t srcFieldIndex = 0;
+ boost::uint32_t dstFieldIndex = 0;
+ for (std::vector<DimensionLayout>::const_iterator i = src_layouts.begin(); i != src_layouts.end(); ++i)
+ Dimension const& d = i->getDimension();
+ std::size_t src_offset = i->getByteOffset();
+ if (d != dimXd && d != dimYd && d != dimZd)
+ dstFieldIndex = dstSchemaLayout.getSchema().getDimensionIndex(d);
+ srcFieldIndex = srcSchemaLayout.getSchema().getDimensionIndex(d);
+ std::size_t size = d.getDataTypeSize(d.getDataType());
+ dstData.setFieldData(pointIndex, dstFieldIndex, src_raw_data+src_offset);
dstData.setField<boost::int32_t>(pointIndex, indexXi, xi);
dstData.setField<boost::int32_t>(pointIndex, indexYi, yi);
dstData.setField<boost::int32_t>(pointIndex, indexZi, zi);
@@ -279,7 +297,8 @@
// ints --> doubles (applyScaling)
const boost::int32_t xi = srcData.getField<boost::int32_t>(pointIndex, indexXi);
const boost::int32_t yi = srcData.getField<boost::int32_t>(pointIndex, indexYi);
- const boost::int32_t zi = srcData.getField<boost::int32_t>(pointIndex, indexZi);
+ const boost::int32_t zi = srcData.getField<boost::int32_t>(pointIndex, indexZi);
const double xd = dimXd.applyScaling(xi);
const double yd = dimYd.applyScaling(yi);
@@ -288,8 +307,6 @@
- std::size_t src_position = 0;
- std::size_t dst_position = 0;
@@ -300,15 +317,10 @@
if (d != dimXi && d != dimYi && d != dimZi)
- dstFieldIndex = dstSchemaLayout.getSchema().getDimensionIndex(d);
- srcFieldIndex = srcSchemaLayout.getSchema().getDimensionIndex(d);
- std::size_t size = d.getDataTypeSize(d.getDataType());
- std::cout << " src osffset: " << src_offset
- << " srcFieldIndex: " << srcFieldIndex
- << " dstFieldIndex: " << dstFieldIndex
- << std::endl;
- dstData.setFieldData(pointIndex, dstFieldIndex, src_raw_data+src_offset);
diff -r 9ad3e85bd7c1 -r fa41ca1b1b9c test/unit/ScalingFilterTest.cpp
--- a/test/unit/ScalingFilterTest.cpp Thu Jul 21 11:45:36 2011 -0500
+++ b/test/unit/ScalingFilterTest.cpp Thu Jul 21 13:30:25 2011 -0500
@@ -52,7 +52,7 @@
static void getDoublePoint(const pdal::PointBuffer& data, double& x, double& y, double& z,
- boost::uint16_t& intensity, boost::int16_t scan_angle, boost::uint16_t green)
+ boost::uint16_t& intensity, boost::int8_t& scan_angle, boost::uint16_t& green)
using namespace pdal;
@@ -61,15 +61,15 @@
const int indexX = schema.getDimensionIndex(Dimension::Field_X, Dimension::Double);
const int indexY = schema.getDimensionIndex(Dimension::Field_Y, Dimension::Double);
const int indexZ = schema.getDimensionIndex(Dimension::Field_Z, Dimension::Double);
- const int indexIntensity = schema.getDimensionIndex(Dimension::Field_Intensity, Dimension::Uint16);
- const int indexScanAngle = schema.getDimensionIndex(Dimension::Field_ScanAngleRank, Dimension::Int16);
+ const int indexIntensity = schema.getDimensionIndex(Dimension::Field_Intensity, Dimension::Uint8);
+ const int indexScanAngle = schema.getDimensionIndex(Dimension::Field_ScanAngleRank, Dimension::Int8);
const int indexGreen = schema.getDimensionIndex(Dimension::Field_Green, Dimension::Uint16);
x = data.getField<double>(0, indexX);
y = data.getField<double>(0, indexY);
z = data.getField<double>(0, indexZ);
- scan_angle = data.getField<boost::int16_t>(0, indexScanAngle);
+ scan_angle = data.getField<boost::int8_t>(0, indexScanAngle);
intensity = data.getField<boost::uint16_t>(0, indexIntensity);
green = data.getField<boost::uint16_t>(0, indexGreen);
@@ -100,9 +100,9 @@
delete iter;
double x=0, y=0, z=0;
- boost::uint16_t intensity;
- boost::int16_t scan_angle;
- boost::uint16_t green;
+ boost::uint16_t intensity(0);
+ boost::int8_t scan_angle(06);
+ boost::uint16_t green(0);
getDoublePoint(data2, x, y, z, intensity, scan_angle, green);
BOOST_CHECK_CLOSE(x, 470692.44, 1);
More information about the Liblas-commits
