[Liblas-commits] hg-main-tree: don't be so aggressive in capitalizing everything
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Jul 22 11:24:16 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/cc1a954b7bac
changeset: 911:cc1a954b7bac
user:      Howard Butler <hobu.inc at gmail.com>
date:      Fri Jul 22 10:24:11 2011 -0500
description:
diffstat:
 src/drivers/oci/Writer.cpp |  8 ++++----
 1 files changed, 4 insertions(+), 4 deletions(-)
diffs (18 lines):
diff -r d5a54ea4019e -r cc1a954b7bac src/drivers/oci/Writer.cpp
--- a/src/drivers/oci/Writer.cpp	Thu Jul 21 15:56:07 2011 -0500
+++ b/src/drivers/oci/Writer.cpp	Fri Jul 22 10:24:11 2011 -0500
@@ -695,10 +695,10 @@
     std::string block_table_name = to_upper(tree.get<std::string>("block_table_name"));
     std::string base_table_name = to_upper(tree.get<std::string>("base_table_name"));
     std::string cloud_column_name = to_upper(tree.get<std::string>("cloud_column_name"));
-    std::string base_table_aux_columns = to_upper(tree.get<std::string>("base_table_aux_columns"));
-    std::string base_table_aux_values = to_upper(tree.get<std::string>("base_table_aux_values"));
-    std::string header_blob_column_name = to_upper(tree.get<std::string>("header_blob_column_name"));
-    std::string base_table_boundary_column = to_upper(tree.get<std::string>("base_table_boundary_column"));
+    std::string base_table_aux_columns = tree.get<std::string>("base_table_aux_columns");
+    std::string base_table_aux_values = tree.get<std::string>("base_table_aux_values");
+    std::string header_blob_column_name = tree.get<std::string>("header_blob_column_name");
+    std::string base_table_boundary_column = tree.get<std::string>("base_table_boundary_column");
     std::string base_table_boundary_wkt = tree.get<std::string>("base_table_boundary_wkt");
     std::string point_schema_override = tree.get<std::string>("point_schema_override");
More information about the Liblas-commits mailing list
