[Liblas-commits] hg-main-tree: stub in an Options-based ctor for
every stage
liblas-commits at liblas.org
Fri Jul 22 18:09:42 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/a3cb4cf5201a
changeset: 917:a3cb4cf5201a
user: Michael P. Gerlek <mpg at flaxen.com>
date: Fri Jul 22 15:09:33 2011 -0700
description:
stub in an Options-based ctor for every stage
diffstat:
include/pdal/MultiFilter.hpp | 2 +-
include/pdal/Writer.hpp | 6 +++---
include/pdal/drivers/faux/Reader.hpp | 1 +
include/pdal/drivers/faux/Writer.hpp | 2 +-
include/pdal/drivers/las/Reader.hpp | 1 +
include/pdal/drivers/las/Writer.hpp | 1 +
include/pdal/drivers/liblas/Reader.hpp | 1 +
include/pdal/drivers/liblas/Writer.hpp | 1 +
include/pdal/drivers/oci/Reader.hpp | 5 +++--
include/pdal/drivers/oci/Writer.hpp | 1 +
include/pdal/drivers/qfit/Reader.hpp | 2 +-
include/pdal/drivers/terrasolid/Reader.hpp | 1 +
include/pdal/filters/ByteSwapFilter.hpp | 1 +
include/pdal/filters/CacheFilter.hpp | 1 +
include/pdal/filters/Chipper.hpp | 1 +
include/pdal/filters/ColorFilter.hpp | 1 +
include/pdal/filters/CropFilter.hpp | 1 +
include/pdal/filters/DecimationFilter.hpp | 1 +
include/pdal/filters/MosaicFilter.hpp | 2 +-
include/pdal/filters/ReprojectionFilter.hpp | 1 +
include/pdal/filters/ScalingFilter.hpp | 1 +
src/MultiFilter.cpp | 2 +-
src/Writer.cpp | 4 ++--
src/drivers/faux/Reader.cpp | 7 +++++++
src/drivers/faux/Writer.cpp | 4 ++--
src/drivers/las/Reader.cpp | 7 +++++++
src/drivers/las/Writer.cpp | 8 ++++++++
src/drivers/liblas/Reader.cpp | 7 +++++++
src/drivers/liblas/Writer.cpp | 8 ++++++++
src/drivers/oci/Reader.cpp | 10 +++++++++-
src/drivers/oci/Writer.cpp | 9 +++++++++
src/drivers/qfit/Reader.cpp | 2 +-
src/drivers/terrasolid/Reader.cpp | 8 ++++++++
src/filters/ByteSwapFilter.cpp | 7 +++++++
src/filters/CacheFilter.cpp | 7 +++++++
src/filters/Chipper.cpp | 7 +++++++
src/filters/ColorFilter.cpp | 7 +++++++
src/filters/CropFilter.cpp | 7 +++++++
src/filters/DecimationFilter.cpp | 7 +++++++
src/filters/MosaicFilter.cpp | 4 ++--
src/filters/ReprojectionFilter.cpp | 7 +++++++
src/filters/ScalingFilter.cpp | 7 +++++++
test/unit/CropFilterTest.cpp | 2 +-
test/unit/FauxWriterTest.cpp | 4 ++--
test/unit/MosaicFilterTest.cpp | 2 +-
45 files changed, 156 insertions(+), 22 deletions(-)
diffs (truncated from 668 to 300 lines):
diff -r f2ff84a215f9 -r a3cb4cf5201a include/pdal/MultiFilter.hpp
--- a/include/pdal/MultiFilter.hpp Fri Jul 22 13:41:19 2011 -0700
+++ b/include/pdal/MultiFilter.hpp Fri Jul 22 15:09:33 2011 -0700
@@ -47,7 +47,7 @@
public:
// entries may not be null
// vector.size() must be > 0
- MultiFilter(std::vector<const Stage*> prevStages, const Options& options);
+ MultiFilter(const std::vector<const Stage*>& prevStages, const Options& options);
const std::vector<const Stage*>& getPrevStages() const;
diff -r f2ff84a215f9 -r a3cb4cf5201a include/pdal/Writer.hpp
--- a/include/pdal/Writer.hpp Fri Jul 22 13:41:19 2011 -0700
+++ b/include/pdal/Writer.hpp Fri Jul 22 15:09:33 2011 -0700
@@ -50,7 +50,7 @@
class PDAL_DLL Writer : public StageBase
public:
- Writer(Stage& prevStage, const Options& options);
+ Writer(const Stage& prevStage, const Options& options);
virtual ~Writer() {}
// size of the PointBuffer buffer to use
@@ -72,14 +72,14 @@
// called once, after the writeBuffer calls
virtual void writeEnd() = 0;
- Stage& getPrevStage();
+ const Stage& getPrevStage();
// these two are valid for use after writeBegin has been called
boost::uint64_t m_actualNumPointsWritten;
boost::uint64_t m_targetNumPointsToWrite;
private:
- Stage& m_prevStage;
+ const Stage& m_prevStage;
boost::uint32_t m_chunkSize;
static const boost::uint32_t s_defaultChunkSize;
diff -r f2ff84a215f9 -r a3cb4cf5201a include/pdal/drivers/faux/Reader.hpp
--- a/include/pdal/drivers/faux/Reader.hpp Fri Jul 22 13:41:19 2011 -0700
+++ b/include/pdal/drivers/faux/Reader.hpp Fri Jul 22 15:09:33 2011 -0700
@@ -76,6 +76,7 @@
public:
+ Reader(const Options& options);
Reader(const Bounds<double>&, int numPoints, Mode mode);
Reader(const Bounds<double>&, int numPoints, Mode mode, const std::vector<Dimension>& dimensions);
diff -r f2ff84a215f9 -r a3cb4cf5201a include/pdal/drivers/faux/Writer.hpp
--- a/include/pdal/drivers/faux/Writer.hpp Fri Jul 22 13:41:19 2011 -0700
+++ b/include/pdal/drivers/faux/Writer.hpp Fri Jul 22 15:09:33 2011 -0700
@@ -54,7 +54,7 @@
DECLARE_STATICS
public:
- Writer(Stage& prevStage);
+ Writer(const Stage& prevStage, const Options&);
// retrieve the summary info
double getMinX() const { return m_minimumX; }
diff -r f2ff84a215f9 -r a3cb4cf5201a include/pdal/drivers/las/Reader.hpp
--- a/include/pdal/drivers/las/Reader.hpp Fri Jul 22 13:41:19 2011 -0700
+++ b/include/pdal/drivers/las/Reader.hpp Fri Jul 22 15:09:33 2011 -0700
@@ -58,6 +58,7 @@
DECLARE_STATICS
public:
+ LasReader(const Options&);
LasReader(const std::string& filename);
const std::string& getFileName() const;
diff -r f2ff84a215f9 -r a3cb4cf5201a include/pdal/drivers/las/Writer.hpp
--- a/include/pdal/drivers/las/Writer.hpp Fri Jul 22 13:41:19 2011 -0700
+++ b/include/pdal/drivers/las/Writer.hpp Fri Jul 22 15:09:33 2011 -0700
@@ -55,6 +55,7 @@
DECLARE_STATICS
public:
+ LasWriter(const Stage& prevStage, const Options&);
LasWriter(Stage& prevStage, std::ostream&);
~LasWriter();
diff -r f2ff84a215f9 -r a3cb4cf5201a include/pdal/drivers/liblas/Reader.hpp
--- a/include/pdal/drivers/liblas/Reader.hpp Fri Jul 22 13:41:19 2011 -0700
+++ b/include/pdal/drivers/liblas/Reader.hpp Fri Jul 22 15:09:33 2011 -0700
@@ -58,6 +58,7 @@
DECLARE_STATICS
public:
+ LiblasReader(const Options&);
LiblasReader(const std::string& filename);
~LiblasReader();
diff -r f2ff84a215f9 -r a3cb4cf5201a include/pdal/drivers/liblas/Writer.hpp
--- a/include/pdal/drivers/liblas/Writer.hpp Fri Jul 22 13:41:19 2011 -0700
+++ b/include/pdal/drivers/liblas/Writer.hpp Fri Jul 22 15:09:33 2011 -0700
@@ -55,6 +55,7 @@
DECLARE_STATICS
public:
+ LiblasWriter(const Stage& prevStage, const Options&);
LiblasWriter(Stage& prevStage, std::ostream&);
~LiblasWriter();
diff -r f2ff84a215f9 -r a3cb4cf5201a include/pdal/drivers/oci/Reader.hpp
--- a/include/pdal/drivers/oci/Reader.hpp Fri Jul 22 13:41:19 2011 -0700
+++ b/include/pdal/drivers/oci/Reader.hpp Fri Jul 22 15:09:33 2011 -0700
@@ -37,7 +37,7 @@
#include <pdal/pdal.hpp>
-#include <pdal/Stage.hpp>
+#include <pdal/Reader.hpp>
#include <pdal/drivers/oci/common.hpp>
#include <boost/scoped_ptr.hpp>
@@ -49,11 +49,12 @@
-class PDAL_DLL Reader : public pdal::Stage
+class PDAL_DLL Reader : public pdal::Reader
DECLARE_STATICS
public:
+ Reader(const Options&);
Reader(OptionsOld& options);
~Reader();
diff -r f2ff84a215f9 -r a3cb4cf5201a include/pdal/drivers/oci/Writer.hpp
--- a/include/pdal/drivers/oci/Writer.hpp Fri Jul 22 13:41:19 2011 -0700
+++ b/include/pdal/drivers/oci/Writer.hpp Fri Jul 22 15:09:33 2011 -0700
@@ -52,6 +52,7 @@
DECLARE_STATICS
public:
Writer(Stage& prevStage, OptionsOld& options);
~Writer();
diff -r f2ff84a215f9 -r a3cb4cf5201a include/pdal/drivers/qfit/Reader.hpp
--- a/include/pdal/drivers/qfit/Reader.hpp Fri Jul 22 13:41:19 2011 -0700
+++ b/include/pdal/drivers/qfit/Reader.hpp Fri Jul 22 15:09:33 2011 -0700
@@ -122,7 +122,7 @@
DECLARE_STATICS
public:
- Reader(Options& options);
~Reader();
std::string getFileName() const;
diff -r f2ff84a215f9 -r a3cb4cf5201a include/pdal/drivers/terrasolid/Reader.hpp
--- a/include/pdal/drivers/terrasolid/Reader.hpp Fri Jul 22 13:41:19 2011 -0700
+++ b/include/pdal/drivers/terrasolid/Reader.hpp Fri Jul 22 15:09:33 2011 -0700
@@ -130,6 +130,7 @@
DECLARE_STATICS
public:
~Reader();
diff -r f2ff84a215f9 -r a3cb4cf5201a include/pdal/filters/ByteSwapFilter.hpp
--- a/include/pdal/filters/ByteSwapFilter.hpp Fri Jul 22 13:41:19 2011 -0700
+++ b/include/pdal/filters/ByteSwapFilter.hpp Fri Jul 22 15:09:33 2011 -0700
@@ -57,6 +57,7 @@
DECLARE_STATICS
public:
+ ByteSwapFilter(const Stage& prevStage, const Options&);
ByteSwapFilter(const Stage& prevStage);
bool supportsIterator (StageIteratorType t) const
diff -r f2ff84a215f9 -r a3cb4cf5201a include/pdal/filters/CacheFilter.hpp
--- a/include/pdal/filters/CacheFilter.hpp Fri Jul 22 13:41:19 2011 -0700
+++ b/include/pdal/filters/CacheFilter.hpp Fri Jul 22 15:09:33 2011 -0700
@@ -60,6 +60,7 @@
DECLARE_STATICS
public:
+ CacheFilter(const Stage& prevStage, const Options&);
CacheFilter(const Stage& prevStage, boost::uint32_t numBlocks, boost::uint32_t blockSize);
~CacheFilter();
diff -r f2ff84a215f9 -r a3cb4cf5201a include/pdal/filters/Chipper.hpp
--- a/include/pdal/filters/Chipper.hpp Fri Jul 22 13:41:19 2011 -0700
+++ b/include/pdal/filters/Chipper.hpp Fri Jul 22 15:09:33 2011 -0700
@@ -154,6 +154,7 @@
DECLARE_STATICS
public:
+ Chipper(const Stage& prevStage, const Options&);
Chipper(Stage& prevStage, boost::uint32_t max_partition_size)
: pdal::Filter(prevStage, Options::none())
, m_threshold(max_partition_size)
diff -r f2ff84a215f9 -r a3cb4cf5201a include/pdal/filters/ColorFilter.hpp
--- a/include/pdal/filters/ColorFilter.hpp Fri Jul 22 13:41:19 2011 -0700
+++ b/include/pdal/filters/ColorFilter.hpp Fri Jul 22 15:09:33 2011 -0700
@@ -58,6 +58,7 @@
DECLARE_STATICS
public:
+ ColorFilter(const Stage& prevStage, const Options&);
ColorFilter(const Stage& prevStage);
void getColor_F32_U8(float value, boost::uint8_t& red, boost::uint8_t& green, boost::uint8_t& blue) const;
diff -r f2ff84a215f9 -r a3cb4cf5201a include/pdal/filters/CropFilter.hpp
--- a/include/pdal/filters/CropFilter.hpp Fri Jul 22 13:41:19 2011 -0700
+++ b/include/pdal/filters/CropFilter.hpp Fri Jul 22 15:09:33 2011 -0700
@@ -57,6 +57,7 @@
DECLARE_STATICS
public:
+ CropFilter(const Stage& prevStage, const Options&);
CropFilter(const Stage& prevStage, Bounds<double> const& bounds);
diff -r f2ff84a215f9 -r a3cb4cf5201a include/pdal/filters/DecimationFilter.hpp
--- a/include/pdal/filters/DecimationFilter.hpp Fri Jul 22 13:41:19 2011 -0700
+++ b/include/pdal/filters/DecimationFilter.hpp Fri Jul 22 15:09:33 2011 -0700
@@ -55,6 +55,7 @@
DECLARE_STATICS
public:
+ DecimationFilter(const Stage& prevStage, const Options&);
DecimationFilter(const Stage& prevStage, boost::uint32_t step);
diff -r f2ff84a215f9 -r a3cb4cf5201a include/pdal/filters/MosaicFilter.hpp
--- a/include/pdal/filters/MosaicFilter.hpp Fri Jul 22 13:41:19 2011 -0700
+++ b/include/pdal/filters/MosaicFilter.hpp Fri Jul 22 15:09:33 2011 -0700
@@ -55,7 +55,7 @@
public:
- MosaicFilter(std::vector<const Stage*> prevStages);
+ MosaicFilter(const std::vector<const Stage*>& prevStages, const Options&);
diff -r f2ff84a215f9 -r a3cb4cf5201a include/pdal/filters/ReprojectionFilter.hpp
--- a/include/pdal/filters/ReprojectionFilter.hpp Fri Jul 22 13:41:19 2011 -0700
+++ b/include/pdal/filters/ReprojectionFilter.hpp Fri Jul 22 15:09:33 2011 -0700
@@ -55,6 +55,7 @@
DECLARE_STATICS
public:
+ ReprojectionFilter(const Stage& prevStage, const Options&);
const SpatialReference& inSRS,
const SpatialReference& outSRS);
diff -r f2ff84a215f9 -r a3cb4cf5201a include/pdal/filters/ScalingFilter.hpp
--- a/include/pdal/filters/ScalingFilter.hpp Fri Jul 22 13:41:19 2011 -0700
+++ b/include/pdal/filters/ScalingFilter.hpp Fri Jul 22 15:09:33 2011 -0700
@@ -62,6 +62,7 @@
// - "forward=true" means doubles --> ints
// - "forward=false" means ints --> doubles
// - 1st version uses the scale/offset values already present
+ ScalingFilter(const Stage& prevStage, const Options&);
ScalingFilter(const Stage& prevStage, bool forward);
ScalingFilter(const Stage& prevStage, double scaleX, double offsetX, double scaleY, double offsetY, double scaleZ, double offsetZ, bool forward);
diff -r f2ff84a215f9 -r a3cb4cf5201a src/MultiFilter.cpp
--- a/src/MultiFilter.cpp Fri Jul 22 13:41:19 2011 -0700
+++ b/src/MultiFilter.cpp Fri Jul 22 15:09:33 2011 -0700
@@ -39,7 +39,7 @@
-MultiFilter::MultiFilter(std::vector<const Stage*> prevStages, const Options& options)
+MultiFilter::MultiFilter(const std::vector<const Stage*>& prevStages, const Options& options)
: Stage(options)
if (prevStages.size() == 0)
diff -r f2ff84a215f9 -r a3cb4cf5201a src/Writer.cpp
--- a/src/Writer.cpp Fri Jul 22 13:41:19 2011 -0700
+++ b/src/Writer.cpp Fri Jul 22 15:09:33 2011 -0700
@@ -47,7 +47,7 @@
const boost::uint32_t Writer::s_defaultChunkSize = 1024 * 32;
-Writer::Writer(Stage& prevStage, const Options& options)
+Writer::Writer(const Stage& prevStage, const Options& options)
: StageBase(options)
, m_actualNumPointsWritten(0)
, m_targetNumPointsToWrite(0)
@@ -59,7 +59,7 @@
-Stage& Writer::getPrevStage()
+const Stage& Writer::getPrevStage()
return m_prevStage;
More information about the Liblas-commits
