[Liblas-commits] hg-main-tree: point_schema_override doesn't mean anything now
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Jul 25 16:08:04 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/fabdd7bfc930
changeset: 928:fabdd7bfc930
user:      Howard Butler <hobu.inc at gmail.com>
date:      Mon Jul 25 15:08:00 2011 -0500
description:
diffstat:
 src/drivers/oci/Writer.cpp |  24 +++++-------------------
 1 files changed, 5 insertions(+), 19 deletions(-)
diffs (63 lines):
diff -r 0ae87c14148e -r fabdd7bfc930 src/drivers/oci/Writer.cpp
--- a/src/drivers/oci/Writer.cpp	Mon Jul 25 14:46:58 2011 -0500
+++ b/src/drivers/oci/Writer.cpp	Mon Jul 25 15:08:00 2011 -0500
@@ -697,7 +697,6 @@
     std::string header_blob_column_name = tree.get<std::string>("header_blob_column_name");
     std::string base_table_boundary_column = tree.get<std::string>("base_table_boundary_column");
     std::string base_table_boundary_wkt = tree.get<std::string>("base_table_boundary_wkt");
-    std::string point_schema_override = tree.get<std::string>("point_schema_override");
     boost::uint32_t srid = tree.get<boost::uint32_t>("srid");
     boost::uint32_t precision = tree.get<boost::uint32_t>("precision");
@@ -705,7 +704,6 @@
     boost::uint32_t dimensions = tree.get<boost::uint32_t>("dimensions");
     bool bUse3d = is3d();
-    bool bHaveSchemaOverride = (point_schema_override.size() > 0);
     std::ostringstream oss;
@@ -727,7 +725,6 @@
     int nPCPos = 1;
     int nSchemaPos = 1;
-    // if (bHaveSchemaOverride)
         nSchemaPos++;
     int nPos = nSchemaPos; // Bind column position
@@ -762,13 +759,7 @@
         s_srid << srid;
-        s_schema << "xmltype(:"<<nSchemaPos<<")";
-    // } else
-    //     s_schema << "NULL";
+    s_schema << "xmltype(:"<<nSchemaPos<<")";
     long gtype = GetGType();
@@ -838,16 +829,11 @@
     OCILobLocator* boundary_locator ;
     std::string schema_data;
-    if (bHaveSchemaOverride)
-        schema_data = ReadFile(point_schema_override);
-    } else {
         schema_data = pdal::Schema::to_xml(m_stage.getSchema());
-        std::cout << m_stage.getSchema() << std::endl;
-        std::ostream* output= Utils::createFile("oracle-write-schema.xml",true);
-        *output << schema_data <<std::endl;
-        Utils::closeFile(output);
+        // std::cout << m_stage.getSchema() << std::endl;
+        // std::ostream* output= Utils::createFile("oracle-write-schema.xml",true);
+        // *output << schema_data <<std::endl;
+        // Utils::closeFile(output);
     char* schema = (char*) malloc(schema_data.size() * sizeof(char) + 1);
     strncpy(schema, schema_data.c_str(), schema_data.size());
More information about the Liblas-commits mailing list
