[Liblas-commits] hg-main-tree: replace INIT_OPTIONS with something
more verbose, ...
liblas-commits at liblas.org
Mon Jul 25 20:31:03 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/3b44435ac590
changeset: 930:3b44435ac590
user: Michael P. Gerlek <mpg at flaxen.com>
date: Mon Jul 25 17:30:59 2011 -0700
description:
replace INIT_OPTIONS with something more verbose, but more explicit and simpler
diffstat:
include/pdal/Options.hpp | 21 +++++++--------------
include/pdal/StageBase.hpp | 1 -
src/Options.cpp | 33 ++++++++++++++++++++++++++++-----
src/drivers/faux/Reader.cpp | 8 +++++++-
src/drivers/faux/Writer.cpp | 9 ++++++++-
src/drivers/las/Reader.cpp | 8 +++++++-
src/drivers/las/Writer.cpp | 8 +++++++-
src/drivers/liblas/Reader.cpp | 8 +++++++-
src/drivers/liblas/Writer.cpp | 8 +++++++-
src/drivers/oci/Reader.cpp | 9 ++++++++-
src/drivers/oci/Writer.cpp | 8 +++++++-
src/drivers/qfit/Reader.cpp | 8 +++++++-
src/drivers/terrasolid/Reader.cpp | 8 +++++++-
src/filters/ByteSwapFilter.cpp | 8 +++++++-
src/filters/CacheFilter.cpp | 8 +++++++-
src/filters/Chipper.cpp | 8 +++++++-
src/filters/ColorFilter.cpp | 8 +++++++-
src/filters/CropFilter.cpp | 9 ++++++++-
src/filters/DecimationFilter.cpp | 8 +++++++-
src/filters/MosaicFilter.cpp | 8 +++++++-
src/filters/ReprojectionFilter.cpp | 9 ++++++++-
src/filters/ScalingFilter.cpp | 8 +++++++-
test/unit/OptionsTest.cpp | 32 +++++++++++++-------------------
23 files changed, 185 insertions(+), 58 deletions(-)
diffs (truncated from 635 to 300 lines):
diff -r 5933f9408d44 -r 3b44435ac590 include/pdal/Options.hpp
--- a/include/pdal/Options.hpp Mon Jul 25 15:29:48 2011 -0500
+++ b/include/pdal/Options.hpp Mon Jul 25 17:30:59 2011 -0700
@@ -82,7 +82,7 @@
, m_description(description)
, m_value(value)
// construct it from an xml stream
Option(std::istream& istr)
@@ -154,10 +154,13 @@
// defult ctor, empy options list
Options() {}
- // construct from an array of Option items
- // (useful for initialization of a static Options object)
- Options(std::vector<pdal::Option<std::string> > options);
+ // what's a better way to do this?
+ Options(const Option<std::string>&);
+ Options(const Option<std::string>&, const Option<std::string>&);
+ Options(const Option<std::string>&, const Option<std::string>&, const Option<std::string>&);
+ Options(const Option<std::string>&, const Option<std::string>&, const Option<std::string>&, const Option<std::string>&);
+ // initialize from a property tree
Options(boost::property_tree::ptree t);
// read options from an xml stream
@@ -236,16 +239,6 @@
PDAL_DLL std::ostream& operator<<(std::ostream& ostr, const OptionsOld&);
-// Use this to create a static variable initialized to the given Option items.
-// Note that option_items must use boost::assign syntax, e.g.
-// INIT_OPTIONS(s_defaultOptions, (pdal::Option<std::string>("r","s","t")) (pdal::Option<std::string>("u","v","w")) )
-// The reason for this mess is that we want to initialize static Options objects, and there's no clean way to do that.
-#define INIT_OPTIONS(var, option_items) \
- static const std::vector<pdal::Option<std::string> > var##_vector(boost::assign::list_of option_items); \
- static const pdal::Options var(var##_vector);
} // namespace pdal
#endif
diff -r 5933f9408d44 -r 3b44435ac590 include/pdal/StageBase.hpp
--- a/include/pdal/StageBase.hpp Mon Jul 25 15:29:48 2011 -0500
+++ b/include/pdal/StageBase.hpp Mon Jul 25 17:30:59 2011 -0700
@@ -81,7 +81,6 @@
private:
#define IMPLEMENT_STATICS(T, name, description) \
- const Options& T::s_getDefaultOptions() { return s_defaultOptions; } \
const Options& T::getDefaultOptions() const { return s_getDefaultOptions(); } \
const std::string& T::s_getName() { static std::string s(name); return s; } \
const std::string& T::getName() const { return s_getName(); } \
diff -r 5933f9408d44 -r 3b44435ac590 src/Options.cpp
--- a/src/Options.cpp Mon Jul 25 15:29:48 2011 -0500
+++ b/src/Options.cpp Mon Jul 25 17:30:59 2011 -0700
@@ -55,13 +55,36 @@
-Options::Options(std::vector<Option<std::string> > options)
+Options::Options(const Option<std::string>& opt1)
- BOOST_FOREACH(const Option<std::string>& option, options)
- add(option);
+ add(opt1);
+ return;
+Options::Options(const Option<std::string>& opt1, const Option<std::string>& opt2)
+ add(opt1);
+ add(opt2);
+ return;
+Options::Options(const Option<std::string>& opt1, const Option<std::string>& opt2, const Option<std::string>& opt3)
+ add(opt1);
+ add(opt2);
+ add(opt3);
+ return;
+Options::Options(const Option<std::string>& opt1, const Option<std::string>& opt2, const Option<std::string>& opt3, const Option<std::string>& opt4)
+ add(opt1);
+ add(opt2);
+ add(opt3);
+ add(opt4);
return;
diff -r 5933f9408d44 -r 3b44435ac590 src/drivers/faux/Reader.cpp
--- a/src/drivers/faux/Reader.cpp Mon Jul 25 15:29:48 2011 -0500
+++ b/src/drivers/faux/Reader.cpp Mon Jul 25 17:30:59 2011 -0700
@@ -43,7 +43,6 @@
namespace pdal { namespace drivers { namespace faux {
-static Options s_defaultOptions;
IMPLEMENT_STATICS(Reader, "drivers.faux.reader", "Faux Reader")
@@ -91,6 +90,13 @@
+const Options& Reader::s_getDefaultOptions()
+ static Options options;
+ return options;
Reader::Mode Reader::getMode() const
return m_mode;
diff -r 5933f9408d44 -r 3b44435ac590 src/drivers/faux/Writer.cpp
--- a/src/drivers/faux/Writer.cpp Mon Jul 25 15:29:48 2011 -0500
+++ b/src/drivers/faux/Writer.cpp Mon Jul 25 17:30:59 2011 -0700
@@ -40,7 +40,6 @@
IMPLEMENT_STATICS(Writer, "drivers.faux.writer", "Faux Writer")
@@ -51,6 +50,14 @@
+const Options& Writer::s_getDefaultOptions()
+ return options;
void Writer::writeBegin()
m_minimumX = m_minimumY = m_minimumZ = std::numeric_limits<double>::max();
diff -r 5933f9408d44 -r 3b44435ac590 src/drivers/las/Reader.cpp
--- a/src/drivers/las/Reader.cpp Mon Jul 25 15:29:48 2011 -0500
+++ b/src/drivers/las/Reader.cpp Mon Jul 25 17:30:59 2011 -0700
@@ -47,7 +47,6 @@
namespace pdal { namespace drivers { namespace las {
IMPLEMENT_STATICS(LasReader, "drivers.las.reader", "Las Reader")
@@ -82,6 +81,13 @@
+const Options& LasReader::s_getDefaultOptions()
+ return options;
const std::string& LasReader::getFileName() const
return m_filename;
diff -r 5933f9408d44 -r 3b44435ac590 src/drivers/las/Writer.cpp
--- a/src/drivers/las/Writer.cpp Mon Jul 25 15:29:48 2011 -0500
+++ b/src/drivers/las/Writer.cpp Mon Jul 25 17:30:59 2011 -0700
@@ -54,7 +54,6 @@
IMPLEMENT_STATICS(LasWriter, "drivers.las.writer", "Las Writer")
@@ -84,6 +83,13 @@
+const Options& LasWriter::s_getDefaultOptions()
+ return options;
void LasWriter::setCompressed(bool v)
m_lasHeader.SetCompressed(v);
diff -r 5933f9408d44 -r 3b44435ac590 src/drivers/liblas/Reader.cpp
--- a/src/drivers/liblas/Reader.cpp Mon Jul 25 15:29:48 2011 -0500
+++ b/src/drivers/liblas/Reader.cpp Mon Jul 25 17:30:59 2011 -0700
@@ -45,7 +45,6 @@
namespace pdal { namespace drivers { namespace liblas {
IMPLEMENT_STATICS(LiblasReader, "drivers.liblas.reader", "Liblas Reader")
@@ -93,6 +92,13 @@
+const Options& LiblasReader::s_getDefaultOptions()
+ return options;
const std::string& LiblasReader::getFileName() const
return m_filename;
diff -r 5933f9408d44 -r 3b44435ac590 src/drivers/liblas/Writer.cpp
--- a/src/drivers/liblas/Writer.cpp Mon Jul 25 15:29:48 2011 -0500
+++ b/src/drivers/liblas/Writer.cpp Mon Jul 25 17:30:59 2011 -0700
@@ -51,7 +51,6 @@
IMPLEMENT_STATICS(LiblasWriter, "drivers.liblas.writer", "Liblas Writer")
@@ -83,6 +82,13 @@
+const Options& LiblasWriter::s_getDefaultOptions()
+ return options;
void LiblasWriter::setupExternalHeader()
setFormatVersion(1,2);
diff -r 5933f9408d44 -r 3b44435ac590 src/drivers/oci/Reader.cpp
--- a/src/drivers/oci/Reader.cpp Mon Jul 25 15:29:48 2011 -0500
+++ b/src/drivers/oci/Reader.cpp Mon Jul 25 17:30:59 2011 -0700
@@ -45,7 +45,6 @@
namespace pdal { namespace drivers { namespace oci {
IMPLEMENT_STATICS(Reader, "drivers.oci.reader", "OCI Reader")
static OptionsOld dummy;
@@ -116,6 +115,14 @@
// setNumPoints(1000);
+ return options;
bool Reader::isVerbose() const
return m_optionsOld.GetPTree().get<bool>("verbose");
diff -r 5933f9408d44 -r 3b44435ac590 src/drivers/oci/Writer.cpp
--- a/src/drivers/oci/Writer.cpp Mon Jul 25 15:29:48 2011 -0500
+++ b/src/drivers/oci/Writer.cpp Mon Jul 25 17:30:59 2011 -0700
@@ -269,7 +269,6 @@
IMPLEMENT_STATICS(Writer, "drivers.oci.writer", "OCI Writer")
@@ -309,6 +308,13 @@
+ return options;
More information about the Liblas-commits
