[Liblas-commits] hg-main-tree: turn on pipeline writer testing
liblas-commits at liblas.org
Wed Jul 27 05:45:52 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/0dab4c7fe9f6
changeset: 951:0dab4c7fe9f6
user: Michael P. Gerlek <mpg at flaxen.com>
date: Wed Jul 27 02:45:47 2011 -0700
description:
diffstat:
test/data/pipeline_write_out.xml | 2 --
test/unit/PipelineManagerTest.cpp | 6 +++---
test/unit/Support.cpp | 34 ++++++++++++++++++++++++++++++++++
test/unit/Support.hpp | 1 +
4 files changed, 38 insertions(+), 5 deletions(-)
diffs (86 lines):
diff -r f7e648dae130 -r 0dab4c7fe9f6 test/data/pipeline_write_out.xml
--- a/test/data/pipeline_write_out.xml Tue Jul 26 20:00:27 2011 -0700
+++ /dev/null Thu Jan 01 00:00:00 1970 +0000
@@ -1,2 +0,0 @@
-<?xml version="1.0" encoding="utf-8"?>
-<Pipeline><Writer><Type>drivers.las.writer</Type><Option><Name>filename</Name><Value>out.las</Value><Description>junk junk junk</Description></Option><Filter><Type>filters.crop</Type><Option><Name>bounds</Name><Value>([0,1000000],[0,1000000],[0,1000000])</Value></Option><Reader><Type>drivers.las.reader</Type><Option><Name>filename</Name><Value>../../test/data/1.2-with-color.las</Value></Option></Reader></Filter></Writer></Pipeline>
\ No newline at end of file
diff -r f7e648dae130 -r 0dab4c7fe9f6 test/unit/PipelineManagerTest.cpp
--- a/test/unit/PipelineManagerTest.cpp Tue Jul 26 20:00:27 2011 -0700
+++ b/test/unit/PipelineManagerTest.cpp Wed Jul 27 02:45:47 2011 -0700
@@ -115,10 +115,10 @@
mgr.writeWriterPipeline("test.xml");
- bool filesSame = Support::compare_files("test.xml", Support::datapath("pipeline_write_out.xml"));
- //BOOST_CHECK(filesSame);
+ bool filesSame = Support::compare_text_files("test.xml", Support::datapath("pipeline_write.xml"));
+ BOOST_CHECK(filesSame);
- //if (filesSame)
+ if (filesSame)
Utils::deleteFile("test.xml");
diff -r f7e648dae130 -r 0dab4c7fe9f6 test/unit/Support.cpp
--- a/test/unit/Support.cpp Tue Jul 26 20:00:27 2011 -0700
+++ b/test/unit/Support.cpp Wed Jul 27 02:45:47 2011 -0700
@@ -35,6 +35,7 @@
#include "Support.hpp"
#include <iostream>
+#include <string>
#include <boost/test/unit_test.hpp>
@@ -53,6 +54,39 @@
+// same as compare_files, but for text files: ignores CRLF differences
+bool Support::compare_text_files(const std::string& file1, const std::string& file2)
+ if (!pdal::Utils::fileExists(file1) ||
+ !pdal::Utils::fileExists(file2))
+ return false;
+ std::istream* str1 = pdal::Utils::openFile(file1, false);
+ std::istream* str2 = pdal::Utils::openFile(file2, false);
+ BOOST_CHECK(str1);
+ BOOST_CHECK(str2);
+ bool same = true;
+ while (!str1->eof())
+ std::string buf1;
+ std::string buf2;
+ std::getline(*str1, buf1);
+ std::getline(*str2, buf2);
+ same = (str1->eof() == str2->eof());
+ if (!same) break;
+ same = (buf1 == buf2);
+ if (!same) break;
+ pdal::Utils::closeFile(str1);
+ pdal::Utils::closeFile(str2);
+ return same;
bool Support::compare_files(const std::string& file1, const std::string& file2)
diff -r f7e648dae130 -r 0dab4c7fe9f6 test/unit/Support.hpp
--- a/test/unit/Support.hpp Tue Jul 26 20:00:27 2011 -0700
+++ b/test/unit/Support.hpp Wed Jul 27 02:45:47 2011 -0700
@@ -55,6 +55,7 @@
// verify if two files are the same
static bool compare_files(const std::string& file1, const std::string& file2);
+ static bool compare_text_files(const std::string& file1, const std::string& file2);
// validate a point's XYZ values
static void check_pN(const pdal::PointBuffer& data, const pdal::Schema& schema,
More information about the Liblas-commits
