[Liblas-commits] hg-main-tree: memoize fetching the indexID and
blockID for the b...
liblas-commits at liblas.org
Wed Jul 27 10:06:44 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/d364ec8b549c
changeset: 953:d364ec8b549c
user: Howard Butler <hobu.inc at gmail.com>
date: Wed Jul 27 09:06:40 2011 -0500
description:
memoize fetching the indexID and blockID for the block so we don't have to do this for every point for a good speed win
diffstat:
include/pdal/filters/Chipper.hpp | 2 +-
src/filters/Chipper.cpp | 6 +++---
src/filters/ChipperIterator.cpp | 6 +++++-
test/unit/ChipperTest.cpp | 4 +++-
4 files changed, 12 insertions(+), 6 deletions(-)
diffs (65 lines):
diff -r ae34a3faf6e7 -r d364ec8b549c include/pdal/filters/Chipper.hpp
--- a/include/pdal/filters/Chipper.hpp Wed Jul 27 08:36:22 2011 -0500
+++ b/include/pdal/filters/Chipper.hpp Wed Jul 27 09:06:40 2011 -0500
@@ -136,7 +136,7 @@
std::vector<boost::uint32_t> GetIDs() const;
pdal::Bounds<double> const& GetBounds() const {return m_bounds;}
void SetBounds(pdal::Bounds<double> const& bounds) {m_bounds = bounds;}
- void GetBuffer( Stage const& stage, PointBuffer& buffer, boost::uint32_t block_id) const;
+ void GetBuffer( Stage const& stage, PointBuffer& buffer, boost::uint32_t block_id, boost::int32_t indexId, boost::int32_t indexBlockId) const;
// double GetXmin() const
// { return m_xmin; }
// double GetYmin() const
diff -r ae34a3faf6e7 -r d364ec8b549c src/filters/Chipper.cpp
--- a/src/filters/Chipper.cpp Wed Jul 27 08:36:22 2011 -0500
+++ b/src/filters/Chipper.cpp Wed Jul 27 09:06:40 2011 -0500
@@ -92,7 +92,7 @@
return ids;
-void Block::GetBuffer( Stage const& stage, PointBuffer& buffer, boost::uint32_t block_id) const
+void Block::GetBuffer( Stage const& stage, PointBuffer& buffer, boost::uint32_t block_id, boost::int32_t indexId, boost::int32_t indexBlockId) const
pdal::Schema const& schema = buffer.getSchema();
@@ -113,8 +113,8 @@
std::vector<boost::uint32_t>::const_iterator it;
boost::uint32_t count = 0;
- const int indexId = schema.getDimensionIndex(Dimension::Field_User1, Dimension::Int32);
- const int indexBlockId = schema.getDimensionIndex(Dimension::Field_User2, Dimension::Int32);
+ // const int indexId = schema.getDimensionIndex(Dimension::Field_User1, Dimension::Int32);
+ // const int indexBlockId = schema.getDimensionIndex(Dimension::Field_User2, Dimension::Int32);
for (it = ids.begin(); it != ids.end(); it++)
diff -r ae34a3faf6e7 -r d364ec8b549c src/filters/ChipperIterator.cpp
--- a/src/filters/ChipperIterator.cpp Wed Jul 27 08:36:22 2011 -0500
+++ b/src/filters/ChipperIterator.cpp Wed Jul 27 09:06:40 2011 -0500
@@ -72,7 +72,11 @@
// FIXME: Expand the buffer?
throw pdal_error("Buffer not large enough to hold block!");
- block.GetBuffer(m_chipper.getPrevStage(), buffer, m_currentBlockId);
+ Schema const& schema = buffer.getSchemaLayout().getSchema();
+ const int indexId = schema.getDimensionIndex(Dimension::Field_User1, Dimension::Int32);
+ const int indexBlockId = schema.getDimensionIndex(Dimension::Field_User2, Dimension::Int32);
+ block.GetBuffer(m_chipper.getPrevStage(), buffer, m_currentBlockId, indexId, indexBlockId);
buffer.setSpatialBounds(block.GetBounds());
m_currentBlockId++;
diff -r ae34a3faf6e7 -r d364ec8b549c test/unit/ChipperTest.cpp
--- a/test/unit/ChipperTest.cpp Wed Jul 27 08:36:22 2011 -0500
+++ b/test/unit/ChipperTest.cpp Wed Jul 27 09:06:40 2011 -0500
@@ -83,7 +83,9 @@
pdal::Schema const& schema = reader.getSchema();
PointBuffer buffer(schema, 15);
- chipper.GetBlock(20).GetBuffer(reader, buffer, 70);
+ chipper.GetBlock(20).GetBuffer(reader, buffer, 70, indexId, indexBlockId);
// std::cout << buffer.getField<boost::int32_t>(0, 0) << std::endl;
More information about the Liblas-commits
