[Liblas-commits] hg-main-tree: clean up temp files
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Jul 27 15:58:52 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/bd76cb7782e6
changeset: 957:bd76cb7782e6
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Wed Jul 27 12:58:49 2011 -0700
description:
clean up temp files
diffstat:
 test/unit/PipelineManagerTest.cpp |  51 ++++++++++++++++++++++++--------------
 test/unit/StageFactoryTest.cpp    |   4 +++
 2 files changed, 36 insertions(+), 19 deletions(-)
diffs (111 lines):
diff -r fd0fe36cbfa7 -r bd76cb7782e6 test/unit/PipelineManagerTest.cpp
--- a/test/unit/PipelineManagerTest.cpp	Wed Jul 27 12:48:39 2011 -0700
+++ b/test/unit/PipelineManagerTest.cpp	Wed Jul 27 12:58:49 2011 -0700
@@ -45,6 +45,7 @@
 #include <pdal/Options.hpp>
 #include <pdal/PointBuffer.hpp>
 #include <pdal/StageIterator.hpp>
+#include <pdal/Utils.hpp>
 using namespace pdal;
@@ -52,22 +53,26 @@
 BOOST_AUTO_TEST_CASE(PipelineManagerTest_test1)
-    PipelineManager mgr;
+        PipelineManager mgr;
-    Options optsR;
-    optsR.add("filename", Support::datapath("1.2-with-color.las"));
-    Reader* reader = mgr.addReader("drivers.las.reader", optsR);
+        Options optsR;
+        optsR.add("filename", Support::datapath("1.2-with-color.las"));
+        Reader* reader = mgr.addReader("drivers.las.reader", optsR);
-    Options optsF;
-    optsF.add("bounds", Bounds<double>(0,0,0,1000000,1000000,1000000));
-    Filter* filter = mgr.addFilter("filters.crop", *reader, optsF);
+        Options optsF;
+        optsF.add("bounds", Bounds<double>(0,0,0,1000000,1000000,1000000));
+        Filter* filter = mgr.addFilter("filters.crop", *reader, optsF);
-    Options optsW;
-    optsW.add("filename", "temp.las", "file to write to");
-    Writer* writer = mgr.addWriter("drivers.las.writer", *filter, optsW);
+        Options optsW;
+        optsW.add("filename", "temp.las", "file to write to");
+        Writer* writer = mgr.addWriter("drivers.las.writer", *filter, optsW);
-    const boost::uint64_t np = writer->write( reader->getNumPoints() );
-    BOOST_CHECK(np == 1065);
+        const boost::uint64_t np = writer->write( reader->getNumPoints() );
+        BOOST_CHECK(np == 1065);
+    Utils::deleteFile("temp.las");
     return;
@@ -96,12 +101,16 @@
 BOOST_AUTO_TEST_CASE(PipelineManagerTest_test3)
-    Writer& writer = mgr.readWriterPipeline(Support::datapath("pipeline_write.xml"));
+        Writer& writer = mgr.readWriterPipeline(Support::datapath("pipeline_write.xml"));
-    const boost::uint64_t np = writer.write();
+        const boost::uint64_t np = writer.write();
+    Utils::deleteFile("out.las");
     return;
@@ -109,11 +118,15 @@
 BOOST_AUTO_TEST_CASE(PipelineManagerTest_test4)
-    mgr.readWriterPipeline(Support::datapath("pipeline_write.xml"));
+        mgr.readWriterPipeline(Support::datapath("pipeline_write.xml"));
-    mgr.writeWriterPipeline("test.xml");
+        mgr.writeWriterPipeline("test.xml");
     bool filesSame = Support::compare_text_files("test.xml", Support::datapath("pipeline_write.xml"));
     BOOST_CHECK(filesSame);
diff -r fd0fe36cbfa7 -r bd76cb7782e6 test/unit/StageFactoryTest.cpp
--- a/test/unit/StageFactoryTest.cpp	Wed Jul 27 12:48:39 2011 -0700
+++ b/test/unit/StageFactoryTest.cpp	Wed Jul 27 12:58:49 2011 -0700
@@ -84,6 +84,8 @@
     delete filter;
     delete reader;
     return;
@@ -179,6 +181,8 @@
     delete filter;
     delete reader;
     return;
More information about the Liblas-commits mailing list
