[Liblas-commits] hg-main-tree: improved Options API,
	added support for debug/vebo...
    liblas-commits at liblas.org
    Fri Jul 29 12:50:59 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/a7b9128d7b29
changeset: 962:a7b9128d7b29
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Fri Jul 29 09:50:54 2011 -0700
description:
improved Options API, added support for debug/vebose opts
diffstat:
 include/pdal/Options.hpp    |  25 ++++++++++++++++++++++++
 src/StageBase.cpp           |   4 +-
 src/drivers/las/Reader.cpp  |   4 +--
 src/filters/CropFilter.cpp  |   2 +-
 test/unit/LasReaderTest.cpp |  46 +++++++++++++++++++++++++++++++++++++++++++++
 5 files changed, 75 insertions(+), 6 deletions(-)
diffs (132 lines):
diff -r 36fc7fac39f9 -r a7b9128d7b29 include/pdal/Options.hpp
--- a/include/pdal/Options.hpp	Thu Jul 28 21:03:54 2011 -0700
+++ b/include/pdal/Options.hpp	Fri Jul 29 09:50:54 2011 -0700
@@ -204,6 +204,31 @@
         throw option_not_found(name);
+    // get value of an option, or throw option_not_found if option not present
+    template<typename T> T getValueOrThrow(std::string const& name) const
+        Option<T> opt = getOption<T>(name);  // might throw
+        return opt.getValue();
+    // get value of an option, or use given default if option not present
+    template<typename T> T getValueOrDefault(std::string const& name, T defaultValue) const
+        T result;
+        try
+            result = opt.getValue();
+        catch (option_not_found)
+           result = defaultValue;
+        return result;
     // returns true iff the option name is valid
     template<typename T> bool hasOption(std::string const& name) const
diff -r 36fc7fac39f9 -r a7b9128d7b29 src/StageBase.cpp
--- a/src/StageBase.cpp	Thu Jul 28 21:03:54 2011 -0700
+++ b/src/StageBase.cpp	Fri Jul 29 09:50:54 2011 -0700
@@ -45,8 +45,8 @@
 StageBase::StageBase(const Options& options)
     : m_options(options)
-    , m_debug(false)
-    , m_verbose(0)
+    , m_debug(options.getValueOrDefault<bool>("debug", false))
+    , m_verbose(options.getValueOrDefault<boost::uint8_t>("verbose", 0))
     return;
diff -r 36fc7fac39f9 -r a7b9128d7b29 src/drivers/las/Reader.cpp
--- a/src/drivers/las/Reader.cpp	Thu Jul 28 21:03:54 2011 -0700
+++ b/src/drivers/las/Reader.cpp	Fri Jul 29 09:50:54 2011 -0700
@@ -52,10 +52,8 @@
 LasReader::LasReader(const Options& options)
     : LasReaderBase(options)
-    , m_filename("")
+    , m_filename(options.getValueOrThrow<std::string>("filename"))
-    m_filename = options.getOption<std::string>("filename").getValue();
     initialize();
     return;
diff -r 36fc7fac39f9 -r a7b9128d7b29 src/filters/CropFilter.cpp
--- a/src/filters/CropFilter.cpp	Thu Jul 28 21:03:54 2011 -0700
+++ b/src/filters/CropFilter.cpp	Fri Jul 29 09:50:54 2011 -0700
@@ -47,7 +47,7 @@
 CropFilter::CropFilter(const Stage& prevStage, const Options& options)
     : pdal::Filter(prevStage, options)
-    , m_bounds(options.getOption<Bounds<double> >("bounds").getValue())
+    , m_bounds(options.getValueOrThrow<Bounds<double> >("bounds"))
     initialize();
diff -r 36fc7fac39f9 -r a7b9128d7b29 test/unit/LasReaderTest.cpp
--- a/test/unit/LasReaderTest.cpp	Thu Jul 28 21:03:54 2011 -0700
+++ b/test/unit/LasReaderTest.cpp	Fri Jul 29 09:50:54 2011 -0700
@@ -47,6 +47,52 @@
 BOOST_AUTO_TEST_SUITE(LasReaderTest)
+BOOST_AUTO_TEST_CASE(test_base_options)
+    const std::string file(Support::datapath("1.2-with-color.las"));
+    const pdal::Option<std::string> opt_filename("filename", file);
+    const pdal::Option<std::string> opt_verbose_string("verbose", "99");
+    const pdal::Option<boost::uint8_t> opt_verbose_uint8("verbose", 99);
+    const pdal::Option<std::string> opt_debug_string("debug", "true");
+    const pdal::Option<bool> opt_debug_bool("debug", true);
+        pdal::Options opts;
+        opts.add(opt_filename);
+        pdal::drivers::las::LasReader reader(opts);
+        BOOST_CHECK(reader.getFileName() == file);
+        BOOST_CHECK(reader.getVerboseLevel() == 0);
+        BOOST_CHECK(reader.isDebug() == false);
+        opts.add(opt_verbose_string);
+        opts.add(opt_debug_string);
+        BOOST_CHECK(reader.getVerboseLevel() == 99);
+        BOOST_CHECK(reader.isDebug() == true);
+        opts.add(opt_verbose_uint8);
+        opts.add(opt_debug_bool);
+    return;
 BOOST_AUTO_TEST_CASE(test_sequential)
     pdal::drivers::las::LasReader reader(Support::datapath("1.2-with-color.las"));
More information about the Liblas-commits
