[Liblas-commits] hg-main-tree: enable Options-based ctors
liblas-commits at liblas.org
Fri Jul 29 15:20:40 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/b10964c028e3
changeset: 966:b10964c028e3
user: Michael P. Gerlek <mpg at flaxen.com>
date: Fri Jul 29 12:13:41 2011 -0700
description:
Subject: hg-main-tree: lint
details: http://hg.libpc.orghg-main-tree/rev/0f814f803ba2
changeset: 967:0f814f803ba2
date: Fri Jul 29 12:14:00 2011 -0700
description:
lint
Subject: hg-main-tree: enable Options-based ctors
details: http://hg.libpc.orghg-main-tree/rev/0f158c29d276
changeset: 968:0f158c29d276
date: Fri Jul 29 12:20:31 2011 -0700
description:
diffstat:
include/pdal/drivers/faux/Reader.hpp | 8 ++-
include/pdal/filters/ByteSwapFilter.hpp | 2 +-
include/pdal/filters/CacheFilter.hpp | 2 +
include/pdal/filters/DecimationFilter.hpp | 2 +
src/drivers/faux/Reader.cpp | 86 +++++++++++++++++++++---------
src/filters/ByteSwapFilter.cpp | 22 +++++--
src/filters/CacheFilter.cpp | 17 +++++-
src/filters/DecimationFilter.cpp | 15 ++++-
test/unit/CacheFilterTest.cpp | 54 +++++++++++++++++++
test/unit/DecimationFilterTest.cpp | 39 +++++++++++++-
test/unit/FauxReaderTest.cpp | 48 +++++++++++++++++
11 files changed, 255 insertions(+), 40 deletions(-)
diffs (truncated from 471 to 300 lines):
diff -r e013fe10c140 -r 0f158c29d276 include/pdal/drivers/faux/Reader.hpp
--- a/include/pdal/drivers/faux/Reader.hpp Fri Jul 29 11:44:22 2011 -0700
+++ b/include/pdal/drivers/faux/Reader.hpp Fri Jul 29 12:20:31 2011 -0700
@@ -77,8 +77,8 @@
public:
Reader(const Options& options);
- Reader(const Bounds<double>&, int numPoints, Mode mode);
- Reader(const Bounds<double>&, int numPoints, Mode mode, const std::vector<Dimension>& dimensions);
+ Reader(const Bounds<double>&, boost::uint64_t numPoints, Mode mode);
+ Reader(const Bounds<double>&, boost::uint64_t numPoints, Mode mode, const std::vector<Dimension>& dimensions);
Mode getMode() const;
@@ -97,7 +97,11 @@
boost::uint32_t processBuffer(PointBuffer& data, boost::uint64_t index) const;
private:
+ void initialize();
+ void initialize(const std::vector<Dimension>& dimensions);
+ Bounds<double> m_bounds;
+ boost::uint64_t m_numPoints;
Mode m_mode;
Reader& operator=(const Reader&); // not implemented
diff -r e013fe10c140 -r 0f158c29d276 include/pdal/filters/ByteSwapFilter.hpp
--- a/include/pdal/filters/ByteSwapFilter.hpp Fri Jul 29 11:44:22 2011 -0700
+++ b/include/pdal/filters/ByteSwapFilter.hpp Fri Jul 29 12:20:31 2011 -0700
@@ -76,7 +76,7 @@
private:
ByteSwapFilter& operator=(const ByteSwapFilter&); // not implemented
ByteSwapFilter(const ByteSwapFilter&); // not implemented
diff -r e013fe10c140 -r 0f158c29d276 include/pdal/filters/CacheFilter.hpp
--- a/include/pdal/filters/CacheFilter.hpp Fri Jul 29 11:44:22 2011 -0700
+++ b/include/pdal/filters/CacheFilter.hpp Fri Jul 29 12:20:31 2011 -0700
@@ -102,6 +102,8 @@
pdal::StageRandomIterator* createRandomIterator() const;
private:
// these are mutable to allow const-ness for updating stats
// BUG: need to make thread-safe
mutable boost::uint64_t m_numPointsRequested;
diff -r e013fe10c140 -r 0f158c29d276 include/pdal/filters/DecimationFilter.hpp
--- a/include/pdal/filters/DecimationFilter.hpp Fri Jul 29 11:44:22 2011 -0700
+++ b/include/pdal/filters/DecimationFilter.hpp Fri Jul 29 12:20:31 2011 -0700
@@ -75,6 +75,8 @@
private:
boost::uint32_t m_step;
DecimationFilter& operator=(const DecimationFilter&); // not implemented
DecimationFilter(const DecimationFilter&); // not implemented
diff -r e013fe10c140 -r 0f158c29d276 src/drivers/faux/Reader.cpp
--- a/src/drivers/faux/Reader.cpp Fri Jul 29 11:44:22 2011 -0700
+++ b/src/drivers/faux/Reader.cpp Fri Jul 29 12:20:31 2011 -0700
@@ -45,48 +45,84 @@
IMPLEMENT_STATICS(Reader, "drivers.faux.reader", "Faux Reader")
+static Reader::Mode string2mode(const std::string& str)
+ if (compare_no_case(str.c_str(), "constant")==0) return Reader::Constant;
+ if (compare_no_case(str.c_str(), "random")==0) return Reader::Random;
+ if (compare_no_case(str.c_str(), "ramp")==0) return Reader::Ramp;
+ throw pdal_error("invalid Mode option: " + str);
Reader::Reader(const Options& options)
: pdal::Reader(options)
+ , m_bounds(options.getValueOrThrow<Bounds<double> >("bounds"))
+ , m_numPoints(options.getValueOrThrow<boost::uint64_t>("num_points"))
+ , m_mode(string2mode(options.getValueOrThrow<std::string>("mode")))
- throw not_yet_implemented("options ctor");
-Reader::Reader(const Bounds<double>& bounds, int numPoints, Mode mode)
- : pdal::Reader(Options::none())
- , m_mode(mode)
- Schema& schema = getSchemaRef();
- schema.addDimension(Dimension(Dimension::Field_X, Dimension::Double));
- schema.addDimension(Dimension(Dimension::Field_Y, Dimension::Double));
- schema.addDimension(Dimension(Dimension::Field_Z, Dimension::Double));
- schema.addDimension(Dimension(Dimension::Field_Time, Dimension::Uint64));
- setNumPoints(numPoints);
- setPointCountType(PointCount_Fixed);
- setBounds(bounds);
+ initialize();
return;
-Reader::Reader(const Bounds<double>& bounds, int numPoints, Mode mode, const std::vector<Dimension>& dimensions)
- : pdal::Reader( Options::none())
+Reader::Reader(const Bounds<double>& bounds, boost::uint64_t numPoints, Mode mode)
+ : pdal::Reader(Options::none())
+ , m_bounds(bounds)
+ , m_numPoints(numPoints)
, m_mode(mode)
+ initialize();
+ return;
+Reader::Reader(const Bounds<double>& bounds, boost::uint64_t numPoints, Mode mode, const std::vector<Dimension>& dimensions)
+ : pdal::Reader( Options::none())
+ , m_mode(mode)
if (dimensions.size() == 0)
throw; // BUG
+ initialize(dimensions);
+ return;
+void Reader::initialize()
+ std::vector<Dimension> dimensions;
+ Dimension dimx(Dimension::Field_X, Dimension::Double);
+ Dimension dimy(Dimension::Field_Y, Dimension::Double);
+ Dimension dimz(Dimension::Field_Z, Dimension::Double);
+ Dimension dimt(Dimension::Field_Time, Dimension::Uint64);
+ dimensions.push_back(dimx);
+ dimensions.push_back(dimy);
+ dimensions.push_back(dimz);
+ dimensions.push_back(dimt);
+ return;
+void Reader::initialize(const std::vector<Dimension>& dimensions)
+ Schema& schema = getSchemaRef();
schema.addDimensions(dimensions);
+ setNumPoints(m_numPoints);
+ setPointCountType(PointCount_Fixed);
- return;
+ setBounds(m_bounds);
diff -r e013fe10c140 -r 0f158c29d276 src/filters/ByteSwapFilter.cpp
--- a/src/filters/ByteSwapFilter.cpp Fri Jul 29 11:44:22 2011 -0700
+++ b/src/filters/ByteSwapFilter.cpp Fri Jul 29 12:20:31 2011 -0700
@@ -53,18 +53,26 @@
ByteSwapFilter::ByteSwapFilter(const Stage& prevStage, const Options& options)
: pdal::Filter(prevStage, options)
+ initialize();
+ return;
ByteSwapFilter::ByteSwapFilter(const Stage& prevStage)
: Filter(prevStage, Options::none())
+ initialize();
+ return;
- this->setNumPoints(prevStage.getNumPoints());
- this->setPointCountType(prevStage.getPointCountType());
- Schema& schema = this->getSchemaRef();
+void ByteSwapFilter::initialize()
+ const Stage& stage = getPrevStage();
+ this->setNumPoints(stage.getNumPoints());
+ this->setPointCountType(stage.getPointCountType());
+ //Schema& schema = this->getSchemaRef();
// FIXME: this doesn't work anymore
// std::vector<Dimension>& dimensions = schema.getDimensions();
@@ -80,9 +88,9 @@
// } else {
// throw pdal_error("ByteSwapFilter can only swap big/little endian dimensions");
- return;
+ return;
diff -r e013fe10c140 -r 0f158c29d276 src/filters/CacheFilter.cpp
--- a/src/filters/CacheFilter.cpp Fri Jul 29 11:44:22 2011 -0700
+++ b/src/filters/CacheFilter.cpp Fri Jul 29 12:20:31 2011 -0700
@@ -45,8 +45,14 @@
CacheFilter::CacheFilter(const Stage& prevStage, const Options& options)
+ , m_numPointsRequested(0)
+ , m_numPointsRead(0)
+ , m_cache(NULL)
+ , m_maxCacheBlocks(options.getValueOrThrow<boost::uint32_t>("max_cache_blocks"))
+ , m_cacheBlockSize(options.getValueOrThrow<boost::uint32_t>("cache_block_size"))
+ initialize();
+ return;
@@ -59,7 +65,7 @@
, m_maxCacheBlocks(maxCacheBlocks)
, m_cacheBlockSize(cacheBlockSize)
- resetCache();
+ initialize();
return;
@@ -70,6 +76,13 @@
+void CacheFilter::initialize()
+ resetCache();
+ return;
const Options& CacheFilter::s_getDefaultOptions()
static Options options;
diff -r e013fe10c140 -r 0f158c29d276 src/filters/DecimationFilter.cpp
--- a/src/filters/DecimationFilter.cpp Fri Jul 29 11:44:22 2011 -0700
+++ b/src/filters/DecimationFilter.cpp Fri Jul 29 12:20:31 2011 -0700
@@ -45,8 +45,11 @@
DecimationFilter::DecimationFilter(const Stage& prevStage, const Options& options)
+ , m_step(options.getValueOrThrow<boost::uint32_t>("step"))
+ initialize();
+ return;
@@ -54,7 +57,15 @@
, m_step(step)
- this->setNumPoints( this->getNumPoints() / step );
+ initialize();
+ return;
+void DecimationFilter::initialize()
+ this->setNumPoints( this->getNumPoints() / m_step );
return;
diff -r e013fe10c140 -r 0f158c29d276 test/unit/CacheFilterTest.cpp
--- a/test/unit/CacheFilterTest.cpp Fri Jul 29 11:44:22 2011 -0700
+++ b/test/unit/CacheFilterTest.cpp Fri Jul 29 12:20:31 2011 -0700
More information about the Liblas-commits
