[Liblas-commits] hg-main-tree: force the deletion order of LASzip
objects before ...
liblas-commits at liblas.org
Thu Jun 9 12:54:42 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/898005ec4dd4
changeset: 776:898005ec4dd4
user: Howard Butler <hobu.inc at gmail.com>
date: Thu Jun 09 11:50:31 2011 -0500
description:
force the deletion order of LASzip objects before we close the stream
Subject: hg-main-tree: rename old libpc file. libPC is now dead. Long live PDAL
details: http://hg.libpc.orghg-main-tree/rev/ff4f5f0158f2
changeset: 777:ff4f5f0158f2
date: Thu Jun 09 11:54:34 2011 -0500
description:
diffstat:
include/pdal/drivers/las/Iterator.hpp | 2 +-
libpc_defines.h.in | 70 -----------------------------------
pdal_defines.h.in | 70 +++++++++++++++++++++++++++++++++++
src/drivers/las/Iterator.cpp | 3 +
4 files changed, 74 insertions(+), 71 deletions(-)
diffs (174 lines):
diff -r 5c533adc4b0c -r ff4f5f0158f2 include/pdal/drivers/las/Iterator.hpp
--- a/include/pdal/drivers/las/Iterator.hpp Thu Jun 09 11:21:09 2011 -0500
+++ b/include/pdal/drivers/las/Iterator.hpp Thu Jun 09 11:54:34 2011 -0500
@@ -66,8 +66,8 @@
public:
#ifdef PDAL_HAVE_LASZIP
boost::scoped_ptr<LASzip> m_zip;
+ boost::scoped_ptr<ZipPoint> m_zipPoint;
boost::scoped_ptr<LASunzipper> m_unzipper;
- boost::scoped_ptr<ZipPoint> m_zipPoint;
#endif
diff -r 5c533adc4b0c -r ff4f5f0158f2 libpc_defines.h.in
--- a/libpc_defines.h.in Thu Jun 09 11:21:09 2011 -0500
+++ /dev/null Thu Jan 01 00:00:00 1970 +0000
@@ -1,70 +0,0 @@
- * pdal_defines.h.in is used by cmake to generate pdal_defines.h
- * Do not edit pdal_defines.h!
- * Note this is a C-style header. Do not use C++ syntax.
-#ifndef LIBPC_DEFINES_H
-#define LIBPC_DEFINES_H
- * version settings
-#define LIBPC_VERSION_MAJOR @LIBPC_VERSION_MAJOR@
-#define LIBPC_VERSION_MINOR @LIBPC_VERSION_MINOR@
-#define LIBPC_VERSION_PATCH @LIBPC_VERSION_PATCH@
-#define LIBPC_VERSION_STRING "@LIBPC_VERSION_STRING@"
-/* (note this will look yucky until we get to major>=1) */
-#define LIBPC_VERSION_INTEGER ((LIBPC_VERSION_MAJOR*100*100)+(LIBPC_VERSION_MINOR*100)+LIBPC_VERSION_PATCH)
- * availability of 3rd-party libraries
-#cmakedefine LIBPC_HAVE_LIBLAS
-#cmakedefine LIBPC_HAVE_LASZIP
-#cmakedefine LIBPC_HAVE_ORACLE
-#cmakedefine LIBPC_HAVE_GDAL
-#cmakedefine LIBPC_HAVE_LIBXML2
-#cmakedefine LIBPC_HAVE_LIBGEOTIFF
-#cmakedefine LIBPC_HAVE_MRSID
- * platform endianness
-#cmakedefine LIBPC_ENDIAN_AWARE
- * Debug or Release build?
-#define LIBPC_BUILD_TYPE "@LIBPC_BUILD_TYPE@"
- * platform OS
-#cmakedefine LIBPC_PLATFORM_WIN32
- * platform compiler
-#cmakedefine LIBPC_COMPILER_MSVC
-#cmakedefine LIBPC_COMPILER_VC10
-#cmakedefine LIBPC_COMPILER_VC9
-#cmakedefine LIBPC_COMPILER_VC8
-#cmakedefine LIBPC_COMPILER_GCC
-#cmakedefine LIBPC_COMPILER_CLANG
- * We have two modes: with GDAL and geotiff, SRS is enabled -- otherwise, it's disabled
- * we use one macro to simplify the control
-#if defined(LIBPC_HAVE_GDAL) && defined(LIBPC_HAVE_LIBGEOTIFF)
-#define LIBPC_SRS_ENABLED
-#endif
-#endif
diff -r 5c533adc4b0c -r ff4f5f0158f2 pdal_defines.h.in
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/pdal_defines.h.in Thu Jun 09 11:54:34 2011 -0500
@@ -0,0 +1,70 @@
+ * pdal_defines.h.in is used by cmake to generate pdal_defines.h
+ * Do not edit pdal_defines.h!
+ * Note this is a C-style header. Do not use C++ syntax.
+#ifndef PDAL_DEFINES_H
+#define PDAL_DEFINES_H
+ * version settings
+#define PDAL_VERSION_MAJOR @PDAL_VERSION_MAJOR@
+#define PDAL_VERSION_MINOR @PDAL_VERSION_MINOR@
+#define PDAL_VERSION_PATCH @PDAL_VERSION_PATCH@
+#define PDAL_VERSION_STRING "@PDAL_VERSION_STRING@"
+/* (note this will look yucky until we get to major>=1) */
+#define PDAL_VERSION_INTEGER ((PDAL_VERSION_MAJOR*100*100)+(PDAL_VERSION_MINOR*100)+PDAL_VERSION_PATCH)
+ * availability of 3rd-party libraries
+#cmakedefine PDAL_HAVE_LIBLAS
+#cmakedefine PDAL_HAVE_LASZIP
+#cmakedefine PDAL_HAVE_ORACLE
+#cmakedefine PDAL_HAVE_GDAL
+#cmakedefine PDAL_HAVE_LIBXML2
+#cmakedefine PDAL_HAVE_LIBGEOTIFF
+#cmakedefine PDAL_HAVE_MRSID
+ * platform endianness
+#cmakedefine PDAL_ENDIAN_AWARE
+ * Debug or Release build?
+#define PDAL_BUILD_TYPE "@PDAL_BUILD_TYPE@"
+ * platform OS
+#cmakedefine PDAL_PLATFORM_WIN32
+ * platform compiler
+#cmakedefine PDAL_COMPILER_MSVC
+#cmakedefine PDAL_COMPILER_VC10
+#cmakedefine PDAL_COMPILER_VC9
+#cmakedefine PDAL_COMPILER_VC8
+#cmakedefine PDAL_COMPILER_GCC
+#cmakedefine PDAL_COMPILER_CLANG
+ * We have two modes: with GDAL and geotiff, SRS is enabled -- otherwise, it's disabled
+ * we use one macro to simplify the control
+#if defined(PDAL_HAVE_GDAL) && defined(PDAL_HAVE_LIBGEOTIFF)
+#define PDAL_SRS_ENABLED
+#endif
+#endif
diff -r 5c533adc4b0c -r ff4f5f0158f2 src/drivers/las/Iterator.cpp
--- a/src/drivers/las/Iterator.cpp Thu Jun 09 11:21:09 2011 -0500
+++ b/src/drivers/las/Iterator.cpp Thu Jun 09 11:54:34 2011 -0500
@@ -69,6 +69,9 @@
IteratorBase::~IteratorBase()
+ m_zipPoint.reset();
+ m_zip.reset();
+ m_unzipper.reset();
Utils::closeFile(m_istream);
More information about the Liblas-commits
